After reading many failures of DW pumps, wondering what other choices than Walbro pumps is there? No E85 needed, just regular pump, would like a drop in without mods but if it's reliable I'm good with it. Price doesn't matter.
So the Aeromotive is not a rebranded unit of something right?
Why? Not versatile or easily modded? New one looks nice. Plastic but if it works I won't hold that against it.I have read that the Evo guys were having issues with the AEMs failing.
Not fair having a GD....I would give an arm to have the old fuel pump setup.
Doesn't "need" to be hardwired but you may lose a little flow up top due to factory wiring. If you are running gas on a stock or smaller turbo you will be fine, this only really starts to matter when you are pushing a lot of E85, etc.do you guys know if the aeromotive is a direct swap, in particular it does it need to be hardwired?
Why not get the aeromotive stealth 340lph? Its not that much more. Is that one not a direct drop in?
The 340 requires trimming similar to the Walbro 255. I would say for the minimal amount of LPH drop and the simple drop in of the 325...the 325 is totally worth it.:tup:From what I understood the 340 was not direct drop in oh the stealth 325.
It can be easily modified to fit the Walbro 255 or Aeromotive 340 but you have to get creative beyond that and do lots of trimming and test fitting. Nothing beats the ability to basically bolt in whatever you want and go. As I have seen, most people pull out the stock filter on the GD, install an aftermarket inline and go with whatever fuel pump fits their fancy.Why? Not versatile or easily modded? New one looks nice. Plastic but if it works I won't hold that against it.
What exactly is plastic? The 325 is true drop in or what does it need to modify?
Can I expect OEM reliability on the 325 with all temperature (-25C winters and +38C summers)?
Last thing I want is the pump to fail if I'm on a road trip 3-4 hours away.
Ya I never took apart the pump before so not sure what I'm looking at. I never touched fuel systems on my GR before.
So you're hitting 80% IDC but why would pump change injectors?
Sounds great. Anyone else?Knock on wood but no issues with mine. Been running strong
