1 - 6 of 6 Posts
Re: Turning a stock STi into a rally car
hmmm ... i dont see it up there ,but I bet UTEC will give all the tuners a run for their money. www.turboxs.com
im kinda a newb when it comes to Engine management systems, and was wondering what exactly does UTEC do? ive heard a lot about it, and was also wondering if u can raise the rev limiter with it and eliminate the fuel cut?
thanks
:D
check out turboxs.com for all the info. Basically in a nutshell, you plug it in (no splicing or anyting), then you can use their preset maps or you can create your own for FULL engine tuning. Very awsome product.
Here are their major points, but theres still more to it:
Plug-&-Play
End-user programmable
Pre-programmed base maps
Four (5) maps plus “stock mode”
Fuel, ignition timing, and boost are programmable
-Complete ignition timing control
-Fuel control
-Load reference
-Closed loop boost control
Knock control
On board data logging
Built in programmable solenoid controller
Drag racing launch control
Free software upgrades
Primary rev limit control
MAP to MAF signal conversion
and more... check out their site and read up, download their instructiosn as well andread those, that will help.
im not sure when it comes out... too many dfferent release dates to be sure
1 - 6 of 6 Posts
