1 - 5 of 5 Posts
Do you have a rotated turbo setup and don’t know what to do with your factory high fill coolant reservoir? Or is your factory high fill reservoir an eye sore to your clean and tucked engine bay? Killer B Motorsport has the solution for you.
Our Killer B Upper Turbo Reservoir utilizes the OEM high point location, factory mounting points, and the Subaru filler cap to maintain proper cooling system function, and most importantly, provide clearance for the big rotated turbo setups. All while looking like it belongs there.
Our reservoirs are machined from a billet piece of aluminum with a durable textured black power coat finish. We deliver the best bang for your buck solution for your high fill reservoir needs. Backed by our lifetime warranty guarantee and quality craftsmanship.
Oooo, I like it:)
Not sure if you might know if the top coolant hose angle is the same as stock? Reason is since I installed my aos the hose angle rests on the corner of my top mount...if I tuck it under it it might create a rub point on the hose, if I bend it too much it kinks the hose..
Either way killer product I could see where guys with rotated set ups would love it!!!!
Oooo, I like it:)
Yes, the top coolant hose is the factory coolant hose used with the stock high fill reservoir. The angle should be similar. Your AOS hose rubs the top mount? Can you send me a picture via email [email protected] and we can verify the correct fitment.
1 - 5 of 5 Posts
