hatchy said:
How about just a bigger TMIC? Porsche uses TMIC in the 911s and they seem to work fine.
Well, if I may talk out of my ass for a minute, it doesn't seem like a TMIC is the best solution for the Sti.
In the 911 it works because the added pressure drop in plumbing an intercooler to the front of a rear engined car isn't feasible, attractive or, in all probability, a viable solution to the AIT issue.
Considering the Scooby has a front mounted boxer, as opposed to the 911 rear engine, an FMIC solution has been proven to work. You only have so much space to work with under there, and ultimately, the heat from the motor, especially the exhaust manifold and turbo (read:hot as Satan's nipple) will only leand to earlier heat soak. This isn't even mentioning the direct airflow that you get from a FMIC and don't tell me about how the hood scoop helps the TMIC work better. Those that have been down the road of forcing air onto a heat exchanger know that a perpendicular flow path is better than trying to force the oncoming air to change direction through a hood scoop onto a FMIC.
I'd rather have an efficient FMIC design coupled with water injection in this case...but water injection's a whole other post.
Okay, I'm done talking out of my ass about theory now.
8)
