1 - 20 of 290 Posts
I want to get a head count on how many people are running an upgraded turbo on stock internals without any serious problems. Not including the supporting mods for them, such as FMIC, fuel pump, injectors, etc. Also, how many miles have you driven with the upgraded turbo and do you drive aggressively or conservatively? Do you track/autox the car? What turbo are you running? Sorry if this is in the wrong thread, if so then could you move it to the correct one.
Hmm I'm looking to do that same !! Because I was thinking instead of doing internals first then upgrade turbo.. But I suppose you could just upgrade Turbo and wait for pistons to blow then do I internals. Makes sense that way doesn't it.. Lol
You are better off staying with the stock turbo, get some bolt-ons and a protune. If you have access to E85, you can make good power on stock turbo, and still be pretty reliable.
From what everybody answered above, I think we're trying say we don't want you to be part of the blown motor thread.
I asked my tuner to get me a bolt on stock placement upgraded turbo, and just tune it, and he simply told me "No" because he was interested in keeping my motor in one piece and retaining a happy customer. You NEED (not want) to do fueling upgrades along with upgraded / bigger turbo at the minimum. You're asking the motor to breath more air and produce more heat without cooling it adequately. Even a simple Stg 2 tune with stock turbo and dp should really look at upgraded injectors and fuel pump because at that power level, the stock injectors and pump are going to be pushed to max efficiency and you ALWAYS want headroom for added safety margin in the fueling to keep AFR and EGT temps at acceptable levels.
BTW, I was only trying to upgrade to a FP HTA68 with 8cm upgrade which in terms of upgraded turbos is a "milder" upgrade.
Just my $.02
You need supporting mods and look in my journal for the list. I've been running a GT3582 at >400whp for the past 30,000 miles without any problems. It is a daily driver that sees redline mutiple times a day.
Very interesting. Will look at your thread. I'm pretty set on getting the newer Dom 1.5 this time next year.
You can do whatever you want to the car and with a great tune you shouldn't run in to a problem for a while. The ringlands will blow eventually, but it's not like if you install a new turbo with the supporting mods it's gonna blow up right when you turn it on. There are some that have been thousands of miles with tons of power at the wheels. Check out the Forged Performance STi and you'll see.
Discussion Starter #9
All great info. Is there anyone else like user 1029 that has been running an upgraded turbo on stock internals
Hey i just went to a dom 1.5 xtr with and e85 conversion. Stock internals on a new block. I had a rod bearing fail with only 10k miles on a stock car. After SOA rebuit my motor from a short block...10k in parts. I decided to go for stage 2. After 2 which was normal stage 2 requirements plus a tmic and protune i decided i wanted the saftey and performance of e85. After doing some research i decided to go with the dom 1.5 xtr stock location turbo. 1000cc injectors, cooler plugs, grimspeed bcs, perrin turbo inlet, tomei el headers and uppipe, and a new act clutch for the bigger power. The car is super stout and runs strong. My power levels are good. Ill let you know them if your interested but im not here to say my power is any better than anybody elses. Im trying to keep e85 in the car the whole time becuase it burns cooler and is safer for the stock internals. I run the car spirited but i am not hard on the car. Havent tracked the car yet as i have just got it back from TopSpeed. Will be taking on that challenge this summer.
Now yes there is always a chance for failure when you push increased power through the block. But its all about the tune. So do your research find a great tuner and take your time. All the best and have a good one.
I ran a dom 3r for about 6 months, e85, perfect afr's, 406 to the wheels, blew a ring. Bought a rallispec block and after the lomg a grueling task of breaking it in, getting it tuned next week. Proly stay around 420. Your motor can blow at 7k with a stock turbo, its the game we play with these cars. I had an 08 wrx blow a ring at 5k. But like people have mentioned, do your research and pick a well reviewed tuned.
Just my $.02
You my friend have a great tuner, who is it BTW? I cant stand shops that push stock motors too far after after "explaining the risk" to the customer, but the whole time knowing they will make big bucks to rebuild the motor later.
There are also cars that dont make it 1000 miles with a bigger turbo. Depends on the car, depends on the tuner. Bottom line is, if you have the money to build it, you will save money as opposed to letting it blow.
ringlands should never blow lol...AMR themselves have said that the stock motor can put out double its stock horsepower in its stock form. A good tune that runs safe afr's, egt's, and safe timing tables will ALWAYS net stock driveability, fuel economy, and safe performance.
And this crap right here is what gives Subaru owners a false confidence. Shops that tell you this, are the same shops offering to build it after it blows.
just keep being the mechanic and ill be the engineer how about that?
as army personel you should know the impact of putting out false or bad information. please stop.
I agree! The thing is if you want to make more power you run the risk of failure. You just have to have that in the back of your mind when you go bigger and have the cash stashed if you do run into issues. I hope you dont and are able to enjoy the car for many more miles!
I've got a 20G on my STi running 93 octane currently. I will be switching to E85 this Spring, but I'm going to keep the power below the 400whp mark until I build a motor (already got a spare block). I haven't done much with this car this year as I've been helping others get their cars going.
I am my own tuner, so if I see an issue, I address it immediately. One of the places I find I have to put some extra time into is temperature compensations as weather changes (have to scale OL and CL MAF in one shot for base). This completely alleviates the need to have a "winter tune" and "summer tune". I've actually spent more time tuning friends cars this year than mine as I've been driving my Taurus SHO around more. I should have considerably more mileage on my 20G next year... I know I'm at a point where a ring land can go, but that's the game.
I dont give a **** what you are, you obviously have zero experience on the subject and are reciting crap that you read. I speak from first hand experience only. PLease tell me your experience with cars over 400whp on stock block, and dont say this shop or that shop, I want personal experience. As I said before "engineer" when you let crap like this spill out of your mouth with such confidence, people actually believe it.
1 - 20 of 290 Posts
