1 - 2 of 2 Posts
CRAZY DEALS: PM FOR POSSIBLE DISCOUNTS!
WE WILL NEVER BE UNDERSOLD!
Turbo XS UTEC stage 1--WRX STI
http://www.importboost.com/inc/pdetail?v=1&pid=1214
Price: $899.00
Details:
The UTEC is a new concept in WRX engine management delivering the power and control of a stand-alone engine management system with the convenience and tuning ease of a piggyback system. UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over tedious and mundane functions that make the car drivable on a daily basis. Functions like cold start, hot start, intake temperature compensation, AC compensation and closed loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend your tuning time doing what we all like to do - making your WRX faster! Retail: $1049
Turbo XS TurboBack Exhaust Titanium tip muffler - WRX/STi
http://www.importboost.com/inc/pdetail?v=1&pid=1874
Price: $985.00
TurboBack Exhaust with Titanium Tip Details:
WRX/STI Turboback Titanium : T304 Stainless 4 inch Bell Mouth Full 3inch Mandrel Bends Polished Muffler w/Titanium 4 inch tip
TurboXS Front Mount Intercooler WRX STI
http://www.importboost.com/inc/pdetail?v=1&pid=3576
Price: $945.00
Brand new front mount intercooler for your 2002-2005 Subaru WRX and STI is now available from TurboXS. Details:
Brand new front mount intercooler for your 2002-2005 Subaru WRX and STI is now available from TurboXS. Very affordable and efficient for your high horsepower cars. This front mount is much larger then the original TXS kit. It bolts on with no cutting except to fit the front bumper. In additional this new FMIC includes a TurboXS blow off valve.
Turbo XS RFL Blow Off Valve & WRX \STI KIT
http://www.importboost.com/inc/pdetail?v=1&pid=2130
Price: $195.00
This is Turbo XS Rfl Blow Off Valve with the Bolt on Flange Kit. Easy to install! Details:
Designed for high performance and maximum noise, the TurboXS Blow Off Valve - Type H-RFL relieves compressor pressure surge caused by changing gears or backing off the throttle quickly. The BOV Type H-RFL is designed for turbo charged engines running 10 to 25 psi boost. The Blow Off Valve - Type H Kit includes : TurboXS Blow Off Valve - Type H Mild Steel Zinc Plated Weld-on Adaptor Aluminum Weld-on Adaptor Spring Adjusting Packer Washers Installation Guide *BOV IS VERY LOUD*
Turbo XS Dual Stage Boost Controller
http://www.importboost.com/inc/pdetail?v=1&pid=1159
Price: $185.00
All the things that you like about the Standard Boost Controller with the added ability to switch between 2 pre-set boost levels from inside the cabin
Details:
All the things that you like about the Standard Boost Controller with the added ability to switch between 2 pre-set boost levels from inside the cabin - even when under full boost! The TurboXS Dual Stage Boost Controller is installed in line with the pressure hose running from the positive pressure side of the turbo to the waste gate actuator system. A switch is wired back to the cabin to switch between boost levels. The switch is lit when on high boost. Ideal for setting street level boost, and racing level boost.
Turbo XS Standard Boost Controller
http://www.importboost.com/inc/pdetail?v=1&pid=1161
Price: $67.00
Possibly the most effective way to generate more power from your turbocharged vehicle is to simply increase the boost pressure.
Details:
Possibly the most effective way to generate more power from your turbocharged vehicle is to simply increase the boost pressure. This can be achieved quickly and very cost effectively with the TurboXS Standard Boost Controller.
1 - 2 of 2 Posts
