1st I will respond to the techincal side of the install
1) Wing removal- Remove nuts, then using a special Snap On tool specifically designed for this aplication the safety strap was removed. (IE Death Wheel)
2) The caps are made from billit Aluminum that was drilled & countersunk for the flathead internal wrenching fasteners. The lower elemnent of the wing was drilled & rivnuts installed for the fasteners to thread into.
Simple
These were only prototypes to see how fisable it was to make caps for the lower element since none are currently available commercialy. I am in the process of getting a quote to have some done up at a CNC shop in polished & color coded. Check back for details.
Now I shall respond to the visual critasism-
1) No matter what bull you have been fed by SOA, the upper element is functionless, even at high speeds. Trust me, I've worked on enough winged racing cars to know what works and what dose not.
2) I was pulled over in a group of traffic where everyone was going 15mph over the limit in a 40 zone, after taking it in the shorts, I asked the officer who was quite candid, why me? "That huge wing you bolted on makes you a target" enough said. Now at least I'll be able to see him comming before he parks in the trunk
3) Trunk swapping. As is I can always reattach in the future when it comes time to sell. If the time ever comes.
4) New Trunk - $250 + New Spoiler - $350 + Paint - $300.
My fix cost me less than 3 Tanks of Gas.
5) The look. While I will be the first to admit it is far from ideal, it is a far cry better than the 'handbag handle' look that the car was originally equipped with. (Hows that for a masculine look)
All of the people I have come in contact with, most of whom are in the custom car or motor racing buisness agree that I have improved, but not prefected the overall look of the car.
