1 - 20 of 261 Posts
Banned
Looking for combo deals? Send an e-mail to [email protected] with the parts you want and we'll make a combo just for you. The list below is just a small selection of brands and parts we carry - if you need other parts please send us an e-mail!
Tomei
If you're looking for the best in the business, look no further than Tomei. From headers to turbos to cams and more, Tomei has some of the best quality products in the industry, and awesome pricing too.
Expreme Equal Length Headers: $730 shipped
For a smooth exhaust sound and best top end performance.
Compatible with 2002-2011 WRX and STI models.
Expreme Unequal Length Headers: $730 shipped
If you want to keep the boxer rumble and gain low end torque.
Expreme Ti Full Titanium Cat-back: $981 shipped
At around 12 pounds this is one of the lightest cat-back systems on the market! The Expreme Ti has an amazing racing sound and full 80mm piping for maximum flow.
Fits 2002-2007 WRX and STI models.
Expreme Catless Bellmouth Downpipe: $390 shipped
Tomei's new catless bellmouth downpipe uses their famous lost wax casting method for the bellmouth and flanges, leaving only the smoothest surfaces behind for excellent flow.
Fits 2008+ WRX and STI models.
ARMS M7760/M7960/M8265 Turbos: $1,341 shipped
These turbos support 380 hp / 400+ hp / 450+ hp respectively, depending on supporting mods!
Compatible with 2002-2007 WRX and STI models.
Tomei Fuel Pressure Regulator Type-S + Subaru fuel rail adapter plate: $138 shipped
When upgrading your fuel system, we always recommend getting a new FPR, and the Tomei Type-S is perfect for your Subaru! The Type-S supports fuel flow up to 500 hp. FPR Kit contains 2 -6AN ports and 2 8mm straight hose nipple ports.
Tomei FPR Type-L + Subaru fuel rail adapter plate: $188 shipped
The Tomei Type-L FPR is larger than the Type-S and allows for higher peak power, well over 500 hp! FPR Kit contains 2 -6AN ports and 2 8mm straight hose nipple ports.
Poncam Camshafts (252/252, 10.4mm lift, AVCS compatible): $750 shipped
These cams are drop-in fitment and require no alteration of the heads.
Compatible with 2004-2007 STI EJ257 engines.
Poncam Camshafts (260/256, 9.8/10.8mm lift, dual AVCS compatible): $750 shipped
Tomei's Poncams are drop in fitment and require no alternation of the heads.
Compatible with 2008+ STI EJ257 engines with dual AVCS.
Procam Camshafts are also available - please inquire for more information on these!
Invidia
The exhaust masters - Invidia makes some of the finest cat-backs available for Subarus. Invidia uses thicker piping for extra strength and thermal resistance, SUS304 stainless steel that won't rust or degrade, and excellent mandrel bends for great fitment and flow. You really can't go wrong with an Invidia exhaust system, so it's no wonder they're so popular.
V2 catless bellmouth downpipe: $274.99 shipped
The classic catless bellmouth - no restrictions and smooth flow.
V2 catless bellmouth downpipe with extra O2 bung: $277.20 shipped
Includes an extra O2 bung in the bellmouth for a wideband O2 sensor hookup, perfect if you want to run an AEM UEGO or Innovate MTX-L gauge in your car.
V3 catless divorced wastegate downpipe: $291.20 shipped
One of the most popular downpipes ever, the V3 divorced catless has a divided flange that keeps the exhaust from the turbine exit and the wastegate opening separate.
V4 catted divorced wastegate downpipe: $509.60 shipped
The same divorced flange as the V3, but with a very effective high flow racing cat.
Q300 single exit catback: $611.80 shipped
The Q300 single exit is quiet enough to not attract too much attention but louder than stock and with a much better sound. Its full 3" design means it has flow comparable to the N1 street, while looking similar to the stock STI exhaust. Perfect for flying under the radar!
N1 Street catback: $582.40 shipped
The N1 Street is a racing style, angled tip exhaust. The Street version comes with a resonated and flex jointed mid-pipe. Available in stainless or titanium exhaust tips.
N1 Race catback: $509.60 shipped
The N1 Race is just like the N1 street, but comes with a straight through mid-pipe (no resonator, no flex joint). Also available in stainless or titanium exhaust tips.
G200 catback: $641.20 shipped
The G200 catback is halfway between the Q300 and N1 exhausts. It's got a 4" titanium tip, and a rich, deep tone. It's louder than the Q300 but quieter than the N1, and it really makes the boxer rumble stand out.
Exhaust manifold with integrated up-pipe (1 piece): $1,022 shipped
This manifold is compatible with all 2002-2011 WRX and STI models.
Big runner exhaust manifold with integrated up-pipe (1 piece): $1,022 shipped
This manifold is compatible with 2005-2011 WRX and STI models only - it will not fit earlier models due to oil pan clearance.
Big runner lower exhaust manifold: $875 shipped
This lower manifold section can use Invidia's up-pipe or any 2 bolt flange up-pipe, including the stock one.
Compatible with 2005-2011 WRX and STI models only.
High flow up-pipe: $147 shipped
A great mod for the WRX owners that want to remove their catted up-pipe, but it's also very worthwhile for everyone else too. Invidia's up-pipe reduces turbulence and improves flow to the turbo, and better exhaust flow is exactly what turbochargers need. Also compatible with their lower exhaust manifold, and any other 2 bolt flange manifolds.
2008+ WRX and STI
Please note that hatchback and sedan fitment is different - please specify when ordering!
Q300 single exit for WRX / STI sedan: $611.80 shipped
The Q300 single exit is quiet enough to not attract too much attention but louder than stock and with a much better sound. Its full 3" design means it has flow comparable to the N1 street, and its single exit design means less turbulence and better flow. Perfect for flying under the radar!
Q300 dual exit for WRX / STI sedan: $714.00 shipped
The Q300 dual exit is a great looking and great sounding dual exit exhaust system. It's extremely popular with WRX sedan owners because of its high flow and deep sound. Makes any WRX sedan sound awesome!
Q300 single exit for WRX hatchback: $641.20 shipped
If you're looking for a stealthy exhaust for your WRX hatch, look no further. Invidia's Q300 single has full 3" piping and excellent packing material for a quiet sound. Best of all, the exhaust tip attaches with a slip joint so you can adjust how it sits to your liking!
Q300 quad exit for STI / 2011 WRX: $968.80 shipped (titanium tips) / $910.00 shipped (stainless tips)
By far the most popular exhaust for the STI, the Q300 quad also fits the 2011 WRX! This full 3" system has great flow and shines even more in the looks department. The large exhaust tips fill the gaps in the bumper nicely and gives your WRX or STI a very clean look and sound.
Fitments available for both hatchback and sedan models.
Cobb Tuning
Cobb's AccessPORT technology is by far the most advanced and user friendly ECU tuning solution on the market for Subarus. That's not all, however, as Cobb also makes a number of other parts that all have the same precision and attention to detail that goes with the Cobb name.
AccessPORT V3: $650.00 with free UPS overnight shipping
Just released! The brand new V3 has a much larger screen, faster CPU, and more internal storage space. View up to 6 gauges at a time as you drive! You can change the faceplate color, and it includes a versatile mounting system so you can keep it within view as you drive.
AccessPORT V2: $595.00 with free UPS overnight shipping!
If you want to use all your mods to the fullest, it's hard to think of a better way than with the Cobb AccessPORT. It allows the entire ECU to be re-tuned to match your car perfectly so you can maximize power and torque. The AP also includes base maps provided by Cobb so you can drive around safely. That said, we recommend taking your car to a professional tuner for a custom tune just for your car.
2002-2007 WRX / STI
2002-2007 SF Intake System
Without airbox: $165 shipped
With airbox: $285 shipped
Cobb's SF intake system is CARB certified and directly compatible with the Cobb AccessPORT. It's easy to install and really opens up the sound of the turbo and bypass valve.
SS 3" turboback exhaust system: $1250 shipped
Cobb's SS turboback system includes Cobb's 3" SS catted downpipe and Cobb's SS catback system. Combined with an AccessPORT, it's an easy way to hit stage 2 power!
SS 3" catted downpipe: $595 shipped
Cobb's SS catted downpipe is a full 3" catted downpipe with Cobb's cast bellmouth. It includes an extra O2 bung in the bellmouth just after the turbo, perfect for a wideband gauge like the AEM UEGO or Innovate MTX-L!
SS 3" catback: $700 shipped
The SS 3" catback is below the 95 db sound limit established in many states and is a big performance boost over the stock catback. You can have the best of both worlds: low key sound and great power!
SS 2" up-pipe: $215 shipped
If you want better performance from your setup, switching to Cobb's SS up-pipe is always a step in the right direction. The Cobb up-pipe is a smooth, 2" design that flows much more exhaust volume, which helps to drive the turbo and generate more boost. 2002-2005 WRX owners will see even more benefit as this up-pipe replaces the stock catted one.
SS turbo heat shield: $68 shipped
Keep your intercooler and engine bay cool with Cobb's SS turbo heat shield. It blocks most of the radiant heat coming from the turbo so your car stays cooler and runs better.
XLE bypass valve: $295 shipped
The XLE bypass valve is a must have if you want to run higher boost levels without leaks, or if you want a more noticeable blow-off sound. Its unique design means you can run it fully recirculating, half recirculating and half atmospheric, or full atmospheric - it's all up to you! The XLE has very fast response and is also fully compatible with water/meth injection!
2008-2011 WRX / STI
2008-2011 SF Intake System
Without airbox: $195 shipped
With airbox: $315 shipped
SS 3" turboback exhaust system HATCH ONLY!: $1745.00 shipped
SS 3" quad tip catback HATCH ONLY!: $1195 shipped
Great fitment and great flow are crucial parts of any catback system, and Cobb's SS quad tip catback definitely has both. Full 3" piping, efficient Y pipe and muffler system, and mirror polished tips.
DeatschWerks
Let's say you're tired of stage 2 and you want more power. More power means more fuel and you're going to need injectors and a pump that can keep up. Luckily, our friends at DeatschWerks have just what you need. Your fueling system is in good hands with DW products.
All sets of injectors are flow matched within 1-2% and come with calibration sheets with injector flow and latency data, making tuning very easy.
DeatschWerks includes a rebate offer with every set of injectors. If you send in your stock injectors, you will receive the following amount as a rebate:
2007+ STI, 2007+ LGT: $200
2006+ WRX: $200
2004-2006 STI, 2004-2006 LGT: $160 for a set of 4 stock injectors
2002-2005 WRX: $100
Simply print out the following form and follow the directions for your rebate! http://www.deatschwerks.com/images/stories/downloads/deatschwerks_rebate_form.pdf
Side feed injectors (2004-2006 STI, 2004-2006 LGT)
4 matched 740cc side feed injectors: $549 shipped
4 matched 850cc side feed injectors: $599 shipped
4 matched 1100cc side feed injectors: $679 shipped
Top feed injectors (2007+ STI, 2002+ WRX, 2007+ LGT)
4 matched 650cc top feed injectors: $349 shipped
4 matched 750cc top feed injectors: $439 shipped
4 matched 850cc top feed injectors: $549 shipped
4 matched 1000cc top feed injectors: $549 shipped
4 matched 1300cc top feed injectors: $549 shipped
Fuel pumps
DW301 300+ LPH fuel pump with free install kit: $169 shipped
The DW301 pump is a 300+ liter per hour fuel pump, and includes a free install kit.
Fits the 1997-2007 Subaru Forester, 1993-2007 Impreza (including WRX and STI), and 1990-2007 Subaru Legacy.
DW65c 255+ LPH fuel pump with free install kit: $149 shipped
The DW65c is DeatschWerks' newest fuel pump, designed for the 2008+ Impreza. This pump is not yet released but we'll have it as soon as it becomes available.
AEM
We carry all AEM Induction and Electronics products - let us know what you need!
Cold air intake for 2002-2007 WRX / STI: $279.67 shipped
Short ram intake for 2002-2007 WRX / STI: $176.08 shipped
Short ram intake for 2008-2011 WRX / STI: $255.65 shipped
One of our most popular products and possibly the best intake for the GR! Although it's a short ram, the filter is placed just outside the engine bay and is covered by a heat shield, which keeps your intake temps nice and low.
Digital wideband UEGO gauge: $200 shipped
AEM's digital UEGO gauge has an LED readout in the center, and LEDs around the edge of the gauge that act like a needle. Very readable!
Analog wideband UEGO gauge: $207.43 shipped
The analog UEGO gauge features a physical needle and backlit gauge face.
Water/methanol injection kit: $416.51 shipped
Water/methanol failsafe device and gauge: $273.38 shipped
AEM's new WMI failsafe device monitors flow and can trigger a failsafe via multiple conditions, all of which can be configured via PC. Upper and lower flow bounds can be set to ensure you never have too much or not enough meth being injected.
Tru-boost electronic boost control system: $325.62 shipped
AEM's Tru-boost takes the place of the stock boost control system for faster response and more consistent boost control. Easily configured and includes AEM's EBCS as well.
Twin-Fire 4 channel CDI ignition system: $421.11 shipped
If you're running a high power setup and want to prevent misfires at high RPM, the AEM Twin-Fire will do the trick. This system uses the factory spark triggers to drive it's CDI ignition, which provides much higher voltage than stock.
Universal fuel pressure regulator: $130.14 shipped
Innovate Motorsports
MTX-L wideband AFR gauge: $199 shipped
Innovate's MTX-L wideband uses their Direct Digital measurement technology, which means you get extremely quick response and accurate measurements. The MTX-L responds up to 180 milliseconds faster than the competition, allowing you to see individual misfires and other combustion events with ease. Includes Bosch O2 sensor and direct serial port output as well. We highly recommend this wideband gauge!
LC-1 wideband controller: $199 shipped
If you're looking for data logging without a gauge, the Innovate LC-1 is the setup for you. Features direct serial port output and Innovate's high grade wideband controller. Includes Bosch O2 sensor and cables.
TC-4 4 channel EGT controller: $135 shipped
For the finest tuning possible, a 4 channel EGT controller will allow you to tune individual cylinders based on EGT to balance fuel and timing for the most even combustion. Well recommended for customers with aftermarket headers or intake manifolds that wish to perform fine tuning.
LM-2 basic kit: $331.55 shipped
Includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide. The perfect wideband companion for professionals and self-tuners alike!
Okada Projects
Plasma Direct high voltage coil on plug system for 2002-2010 WRX / 2004-2007 STI: $778.80 shipped
Plasma Direct high voltage coil on plug system for 2010+ WRX / 2008+ STI: $726.45 shipped
Okada Projects' Plasma Direct system replaces your factory coil packs and boosts spark voltage up to 4 times. It also features multi-spark discharge - up to 10 sparks per ignition event - for a more thorough burn. Fully compatible with the factory ECU, and drop in fitment!
Plasma LIFT ignition voltage booster: $399 shipped
The Plasma LIFT system is wired before the spark plugs and helps keep the voltage driving the plugs as high as possible. It allows for adjustment of the voltage boost as well, so you can control the spark voltage as well as your plug gaps. Great for engines running high boost that have misfiring problems, but it also works very well on stage 2 setups and can help increase fuel efficiency as well.
Cosworth
One of the biggest names in the engine business, Cosworth has been making high performance engines and parts for over 50 years. Their reputation for high precision and longevity continues into their Subaru parts. You can't go wrong with Cosworth.
High volume, high pressure blueprinted oil pump: $566.00 shipped
High volume intake manifold: $1,151.00 shipped
Cosworth's intake manifold features a large plenum volume and tuned runners for maximum flow and performance - a great addition for cars with mild upgraded turbos and cars with fully built race engines alike.
High strength kevlar timing belt: $284.00 shipped
High RPM single valve spring set: $315 shipped
Strongly advised with any Cosworth cam upgrade, especially if RPM limiter is raised. Features a beehive shape so you can keep the stock retainers.
Ultra-high RPM dual valve spring set with titanium retainers: $811 shipped
Optional upgrade to the high RPM single valve spring set. Includes full titanium retainers.
S2 grind single AVCS cams for 2004-2007 STI: $1,212 shipped
Duration: 278/274
Lift: 10.7mm/10.0mm
Only compatible with North American 2004-2007 STI with single AVCS.
S2 grind dual AVCS cams for 2008-2011 STI: $1,360 shipped
Duration: 278/274
Lift: 10.7mm/10.0mm
Compatible with USDM 2008-2011 STI and JDM EJ207 dual AVCS engines.
Short and long blocks, pistons, rods, and other internals are also available, please e-mail at [email protected] for inquiries!
Kelford Cams
KVS-109STi single valve spring: $275 shipped
These valve springs are strongly recommended when using any Kelford camshafts.
Single AVCS cams (2004-2007 STI, 2006-2011 WRX, 2005-2009 LGT, 2004-2009 FXT)
R-199-A: 252/260 duration, 9.5/9.5mm lift: $945.00 shipped
Best suited for mild turbo upgrades, up to around 400hp. No head clearancing required.
At .25mm: Inlet 252, Exhaust 260
At 1.0mm: Inlet 212, Exhaust 222
Lift at 1:1: Inlet 9.50mm, Exhaust 9.50mm
Centerline: Inlet 130, Exhaust 113
R-199-B: 264/264 duration, 10.7/10.2mm lift: $945.00 shipped
400-500hp range, no head clearancing required.
At .25mm: Inlet 264, Exhaust 264
At 1.0mm: Inlet 225, Exhaust 225
Lift at 1:1: Inlet 10.70mm, Exhaust 10.20mm
R-199-C: 272/272 duration, 11.3/10.7mm lift: $945.00 shipped
450-600hp range, slight head clearancing required. Great for street and track performance.
At .25mm: Inlet 272, Exhaust 272
At 1.0mm: Inlet 232, Exhaust 232
Lift at 1:1: Inlet 11.30mm, Exhaust 10.70mm
R-199-D: 280/278 duration, 11.55/11.0mm lift: $945.00 shipped
Full race cam, requires cylinder head work for proper fitment.
At .25mm: Inlet 280, Exhaust 278
At 1.0mm: Inlet 240, Exhaust 236
Lift at 1:1: Inlet 11.55mm, Exhaust 11.0mm
Centerline: Inlet 130, Exhaust 115
Dual AVCS cams (2008-2011 STI, 2006-2011 WRX, 2005-2009 LGT, 2004-2009 FXT)
220-B: 264/260 duration, 10.7/10.2mm lift: $945.00 shipped
Mild upgrade for street cars and fast spooling, smaller turbos. No head clearancing required.
At .25mm: Inlet 264, Exhaust 260
At 1.0mm: Inlet 225, Exhaust 222
Lift at 1:1: Inlet 10.7mm, Exhaust 10.2mm
Centerline: Inlet 130, Exhaust 126
220-C: 272/268 duration, 11.3/10.5mm lift: $945.00 shipped
Suits built motors from 400-500 hp. Head clearancing is required.
At .25mm: Inlet 272, Exhaust 268
At 1.0mm: Inlet 232, Exhaust 228
Lift at 1:1: Inlet 11.3mm, Exhaust 10.5mm
220-D: 280/276 duration, 11.55/11.0mm lift: $945.00 shipped
Best for fully built engines and high power race use. Head clearancing is required.
At .25mm: Inlet 280, Exhaust 276
King Bearings
CR4125XP race rod bearing set: $60 shipped
CR4125XP STDX +.001" race rod bearing set: $60 shipped
...and much more!
If you don't see what you're looking for, shoot an e-mail to [email protected] and we'll be happy to help you with any parts inquiries!
Free shipping offers are only valid within the 48 contiguous states - if you live elsewhere please e-mail us to discuss shipping costs. Customers that do not qualify for free shipping will receive a discount equal to the value of the free shipping offer.
Banned
AccessPORTs are available for $535 with free overnight shipping for a limited time! Get yours while the discount is still available!
Banned
Discussion Starter #16
Making power is our business! Please let us know what we can do for you! If there are parts you have in mind that are not listed, please PM or call us at (909) 235-9526! We can get just about anything you need!
1 - 20 of 261 Posts
