1 - 14 of 14 Posts
hey any of you guys ever see metal shavings. when you change your oil ?
i use amsoil and recently found that my car uses about a quart every 5000 or so........
2019 WRX
That's absolutely normal.
your consumption is normal, but you should not see shavings in your oil unless this is your first oil change, which i doubt.
define shavings...shiny metallic flakes, bad. Tiny bit of cloudy particles, possible. When I do the tranny fluid the magnet always has a fair amount of particles stuck to it...but then again I'm not easy on the gears.
shavings are very small silver and are not flat. i guess you could call them particals. i can feel the texture when i press them.
thats really not a good sign either, I would watch that very very closely. As far as the consumption goes that is normal for a turbo car....
Why not just send in a sample to blackstone labs? That's what I do (and why I'll never use Mobil 1 in these cars).
Bearings may be going out.
IWSTI Club Level 11ty
can you elaborate on why you would never use Mobil 1, and what you use for oil?
How often do you change it? I thought most of us agreed that 3000k was a good interval.
Mobile 1 has one of the worse shear ratings out of any of the oils. I dont even use it in my Ranger anymore. Amsoil, royal purple, Motul and Schaffer are among the best for shear ratings...I use Motul 15W50 in the STI....
totally normal. I use Amsoil and have been for the past 12K miles. It's time for a filter change now. I burn about a 1/4 or less every 3-5K.
I will be sending it out to blackstone as soon as I do the filter change this weekend.
1 - 14 of 14 Posts
