1 - 8 of 8 Posts
Anyone here know how to tilt my headlight beam down on my STI? I have looked thru my manual and cant find a thing.
Apparently there is a bolt somewhere that u twist...anyone?
Do you have HID? I would assume not or you'd know about the switch next to the intercooler spray button:D
There should be something in the manual about aiming your headlights. Yes,there is a screw you turn near the lights.
Yes it's a white screw that you turn behind the headlights.
yea you have two options, basically the switch by the intercooler spray inside the car or the white screw that you need a 10mm(correct me if im wrong) socket to turn.
Gee on the 06, a phillips screwdriver works awfully well. There is even a guide for the screwdriver shaft.
Interesting. My lights are just about right with the electric control set to highest. At lowest they point into the ground.
Why do you want to go lower. Not criticizing, just curious.
Do you have really heavy friends in the back seat all the time?
1 - 8 of 8 Posts
