1 - 20 of 29 Posts
Read Only
My outside thermometer is not working.
Sometimes it works correctly but intermittently it shows --°, sometimes it says 94°, and most recently it is showing -22° (lower limit).
I am in Boston and I know it is about 30° outside +/-10° variance.
Other than going to the dealer (still under warranty) any recommendations on how to fix this? Does anyone know where the Temp Probe is located?
Thanks.
I bet you recently took it through a car wash....
I'm up in NH and this happens every time I take it through a car wash (touchless). I think it needs to be at or below freezing temps for it to happen. The first time it happened to me, it took a couple of days to go away...but, it eventually did.
There is a service bulletin on that just came out Jan 22nd. Under the fuse box there is a resistor pack that some of the pins corroded. Take it to the dealer it is a quick fix. Unless your car is like mine and the pins rusted right off. They had to replace a part of my wiring harness.
:i had the same problem. i also live in boston. whenever i went through a car wash or if it rained and then got cold it would act funny. I found that after it sat for a day in dry weather it went back to normal. i sprayed the sensor (behind the front bumper, accesable from the bottom grill) with wd-40. i have never had the problem ever since! going about 8 months now!!!:)
For shame, you should be hand washing your STIs! (just kidding, I've been hitting the carwash also... way too cold!)
Do you happen to have more info on this?...I can't find any information on it anywhere?
Where is there a comprehensive list of all the TSBs for our cars anyway?
Read Only
Discussion Starter #16
after more than a week, it seems to have come back to normal. Hopefully it stays that way. I will try the WD40 deal if I can find the sensor. I dont suppose anyone has more specific location than gungaslow?
On a maybe or not related note, My Highbeams have now stopped working. When i flip the stick forward, they illuminate, but very, very dimly. Any recommendations?
1 - 20 of 29 Posts
