1 - 6 of 6 Posts
The Japtrix Performance Service & Parts Special Thread! Serving the South East Region
ABOUT US,
Japtrix is a performance & service shop as well as a tuning facility located in West Palm Beach, Florida. We also sell performance and OEM parts for the entire line of Subaru. Please check out our line card for all products we sell.
Japtrix has been serving Subaru owners in the South East Region and nationally since 1994. With that many years of experience Japtrix has become an expert in performance modifications and servicing Subaru's.
We have recently purchased a BRAND NEW, state of the art, Mustang AWD DYNO and we are making a lot of additions and changes to our current facility in an effort to secure our place as a leader in the fast growing performance auto industry. Our customers' satisfaction and comfort during service is our number one priority. We want you returning for more! In addition we want to offer competitive prices. So we would like you to please give us the opportunity to try to match or beat prices you come across on the internet or at your local shop. If we CAN we WILL!
Wheels/Tires
*Prices bellow are for parts and labor*
Maintenance
• Oil change (Includes oil filter and drain plug gasket)
1. Royal purple $68.50
2. Mobil One Synthetic $65.50
3. Your own oil and filter $25
4. Your own oil our OEM filter $28.50
• JAPTRIX Performance Subaru Scheduled Maintenance Services
1. 15K mile service -Starting @ $110
-Oil change using your choice of Royal Purple, Mobil 1 or Castrol Synthetics. Subaru OEM Oil Filter & new drain plug washer included
-Inspect tires & rotate
-Inspect A/C & P/S Belts w/ NEW Subaru belts
-Inspect brake pads and rotors
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect brake lines and check operation of parking brake
-Inspect Steering & Suspension
-Inspect clutch operation
2. 30K mile service -Starting @ $450
-Replace fuel filter and inspect fuel system ***
-Replace spark plugs w/ NGK plugs ***
-Coolant flush and inspect cooling system, hoses and connections. Prestone antifreeze ***
-Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter) ***
-Inspect brake fluid w/ your choice of EBC Sport Brake Fluid BF307+ or Brembo Sport.EVO 500++ (other fluids available upon request) ***
-Inspect PCV Valve ***
-Top-off all fluids ***
3. 60K/120K mile service -Starting @ $599
-Replace Transmission Fluid w/ Royal Purple or Mobil 1 75w90 ***
-Replace Differential Fluid w/ Royal Purple or Mobil e 75w90 ***
-Flush & replace brake fluid w/ your choice of EBC Sport Brake Fluid BF307+ or Brembo Sport.EVO 500++ (other fluids available upon request)***
-Inspect PCV Valve
-Top-off all fluids
4. 90K/180k mile service -Starting @ $1250
-Inspect PCV Valve
-Top-off all fluids
-Replace Timing belt w/ NEW Subaru OEM belt (other belts available) ***
-Replace water pump & water pump gasket w/ NEW Subaru OEM parts ***
-Replace thermostat & thermostat gasket w/ NEW Subaru OEM parts ***
-Inspect Crank Seal ***
-Replace A/C & P/S Belts w/ NEW Subaru belts ***
-Inspect Cam Seals ***
-Replace Timing belt tensioner w/ NEW Subaru Part ***
Engine/Power/Exhaust
• Performance Engine Rebuild kits
1. Stage 1 $3784.99
NEW OEM EJ25 engine short block
Wiseco stock bore pistons
(Short block complete: assembled and installed in your Suby)
2. Stage 2 $4438.99
ACL rod bearings
Eagle rods
Wiseco pistons
3. Your own $1999.00
(Complete engine rebuild)
• Turbo kit install/replace
1. Your own $Please email, pm, IM or call for estimate
• Turbo install/replace (stock mount)
1. Your own $270
• Cooling system install, includes coolant flush (02-07 WRX/STI)
1. Gimmick radiator/hose kit & thermostat COMBO $642 Installed
2. Gimmick radiator/hose kit COMBO $531 Installed
3. Gimmick radiator hoses $160 Installed
(choice on RED, BLUE or BLACK hoses)
• Catback exhaust install/replace
1. HKS Hi-Power $649 Installed
2. HKS Carbon-Ti $895 Installed
3. HKS Legamax Premium Ti $1165 Installed
4. Perrin Sport stealth (black) $554 Installed
5. Perrin Quad tip stealth (black) $869 Installed
6. Cobb 3” $738 Installed
7. Invidia (08+ STI) $989 Installed
8. Invidia Type R (02-07 WRX/STI) $594 Installed
9. Invidia N1 (02-07 WRX/STI) $666 Installed
10. Invidia G200 Titanium Tip (02-07 WRX/STI) $724 Installed
11. MagnaFlow 3” piping 4 tip exit (08+ STI) $498 Installed
12. MagnaFlow 3” piping single tip exit (08+ WRX hatch) $486 Installed
13. MagnaFlow 3” piping (08+ WRX Sadan) $529 Installed
14. MagnaFlow 3” piping bigger oval muffler (02-07 WRX/STI) $500 Installed
15. MagnaFlow 3” Piping oval muffler (02-07 WRX/STI) $486 Installed
16. MagnaFlow 3” Piping round muffler (02-07 WRX/STI) $486 Installed
17. Your own $90
(Other brands are available. Please email, pm, IM or call with inquiry)
• Uppipe install/replace
1. HKS $432 Installed
2. Perrin $445 Installed
3. Gimmick $420 Installed
4. Invidia $415 Installed
5. Your own $270
• Downpipe install/replace
1. Invidia V2 $394 Installed
2. Invidia divorced wastegate (08+ STI) $422 Installed
3. HKS (bellmouth) $562 Installed
4. HKS $292 Installed
5. Perrin Single peace (Cat) $572 Installed
6. Cobb $707 Installed
7. Your own $135
• Headers install/replace
1. Perrin equal length $805 Installed
2. Invidia $1134 Installed
3. Your own $135
• Intake install/replace
Cold Air
1. Perrin $371 Installed
2. Injen $386 Installed
3. Your own $135 Installed
Short ram
1. K&N $335 Installed
2. Injen $251 Installed
3. Cobb $234 Installed
4. Perrin $256 Installed
5. Your own $90
• Turbo inlet pipe install/replace
1. Perrin $327 Installed
2. Samco $459 Installed
3. APS $374 Installed
4. Gimmick $254 Installed
5. Your own $135
Suspension/Brakes/Handling
• Springs install/replace
1. Cobb $420 Installed
4. Your own $180 Installed
• Coilovers install/replace
1. HKS Hipermax III $1985 Installed
2. HKS Hipermax III Sport $2070 Installed
3. BC Racing BR 02-07 WRX/STI & 08+ STI $1203 Installed
4. BC Racing ER 02-07 WRX/STI & 08+ STI $1335 Installed
5. BC Racing Inverted 02-07 WRX/STI & 08+ STI $1975 Installed
6. Your own $225
• Swaybars, springs, mounts and bushings package install/replace (front $ rear)
1. Cobb stage 2 Std. $812 Installed
2. Cobb stage 2 Adj. $908 Installed
3. Cobb stage 1 Adj. (08 ST) $475 Installed
4. Your own $270
• Rotors install/replace (with or without resurfacing) FRONT ONLY
WRX
1. EBC OEM Premium (02-09 WRX) $191 Installed
2. EBC OEM Premium (02-07 NA) $191 Installed
3. EBC Ultimax (02-09 WRX) $279 Installed
4. EBC Ultimax (02-07 NA) $275 Installed
5. EBC Sport (02-09 WRX) $307 Installed
6. EBC Sport (02-07 NA) $303 Installed
7. DBA Street Slotted (02-09 WRX) $329 Installed
8. DBA Street Slotted (02-07 NA) $293 Installed
9. DBA Street Slotted & Drilled (02-09 WRX) $353 Installed
10. DBA Street Slotted & Drilled (02-07 NA) $293 Installed
11. DBA 4000 Slotted (02-09 WRX) $379 Installed
12. DBA 4000 Slotted (02-07 NA) $341 Installed
13. DBA 4000 Slotted & Drilled (02-09 WRX) $420 Installed
14. DBA 4000 Slotted & Drilled (02-07 NA) $365 Installed
15. Resurfacing $40
16. Your own $90
STI
1. EBC OEM Premium (04 STI) $289 Installed
2. EBC OEM Premium (05-09 STI) $290 Installed
3. EBC Ultimax (04 STI) $386 Installed
4. EBC Ultimax (05-09 STI) $386 Installed
5. EBC Sport (04 STI) $432 Installed
6. EBC Sport (05-09 STI) $433 Installed
7. DBA Street Slotted (04 STI) $386 Installed
8. DBA Street Slotted (05-09 STI) $386 Installed
9. DBA Street Slotted & Drilled (04 STI) $410 Installed
10. DBA Street Slotted & Drilled (05-09 STI) $410 Installed
11. DBA 4000 Slotted (04 STI) $441 Installed
12. DBA 4000 Slotted (05-09 STI) $441 Installed
13. DBA 4000 Slotted & Drilled (04 STI) $477 Installed
14. DBA 4000 Slotted & Drilled (05-09 STI) $477 Installed
15. Resurfacing $40
16. Your own $90
• Rotors install/replace (with or without resurfacing) REAR ONLY
WRX
17. EBC OEM Premium (02-05 WRX) $131 Installed
18. EBC OEM Premium (06-09 WRX) $197 Installed
19. EBC OEM Premium (02-07 NA) $131 Installed
20. EBC Ultimax (02-05 WRX) $213 Installed
21. EBC Ultimax (06-09 WRX) $285 Installed
22. EBC Ultimax (02-07 NA) $213 Installed
23. EBC Sport (02-05 WRX) $231 Installed
24. EBC Sport (06-09 WRX) $315 Installed
25. EBC Sport (02-07 NA) $231 Installed
26. DBA Street Slotted (02-05 WRX) $293 Installed
27. DBA Street Slotted (06-09 WRX) $293 Installed
28. DBA Street Slotted (02-07 NA) $293 Installed
29. DBA Street Slotted & Drilled (02-05 WRX) $293 Installed
30. DBA Street Slotted & Drilled (06-09 WRX)$293 Installed
31. DBA Street Slotted & Drilled (02-07 NA) $293 Installed
32. DBA 4000 Slotted (02-05 WRX) $336 Installed
33. DBA 4000 Slotted (06-09 WRX) $336 Installed
34. DBA 4000 Slotted (02-07 NA) $336 Installed
35. DBA 4000 Slotted & Drilled (02-05 WRX) $360 Installed
36. DBA 4000 Slotted & Drilled (07-09 WRX) $360 Installed
37. DBA 4000 Slotted & Drilled (02-07 NA) $360 Installed
38. Resurfacing $40
39. Your own $90
STI
17. EBC OEM Premium (04 STI) $215 Installed
18. EBC OEM Premium (05-09 STI) $209 Installed
19. EBC Ultimax (04 STI) $305 Installed
20. EBC Ultimax (05-09 STI) $298 Installed
21. EBC Sport (04 STI) $337 Installed
22. EBC Sport (05-09 STI) $330 Installed
23. DBA Street Slotted (04 STI) $343 Installed
24. DBA Street Slotted (05-09 STI) $343 Installed
25. DBA Street Slotted & Drilled (04 STI) $367 Installed
26. DBA Street Slotted & Drilled (05-09 STI) $367 Installed
27. DBA 4000 Slotted (04 STI) $398 Installed
28. DBA 4000 Slotted (05-09 STI) $398 Installed
29. DBA 4000 Slotted & Drilled (04 STI) $434 Installed
30. DBA 4000 Slotted & Drilled (05-09 STI) $434 Installed
31. Resurfacing $40
32. Your own $90
• Rotors install/replace (with or without resurfacing) FRONT & REAR
WRX
40. EBC OEM Premium (02-05 WRX) $322 Installed
41. EBC OEM Premium (06-09 WRX) $388 Installed
42. EBC OEM Premium (02-07 NA) $319 Installed
43. EBC Ultimax (02-05 WRX) $492 Installed
44. EBC Ultimax (06-09 WRX) $564 Installed
45. EBC Ultimax (02-07 NA) $492 Installed
46. EBC Sport (02-05 WRX) $538 Installed
47. EBC Sport (06-09 WRX) $622 Installed
48. EBC Sport (02-07 NA) $534 Installed
49. DBA Street Slotted (02-05 WRX) $622 Installed
50. DBA Street Slotted (06-09 WRX) $622 Installed
51. DBA Street Slotted (02-07 NA) $586 Installed
52. DBA Street Slotted & Drilled (02-05 WRX) $646 Installed
53. DBA Street Slotted & Drilled (06-09 WRX) $646 Installed
54. DBA Street Slotted & Drilled (02-07 NA) $586 Installed
55. DBA 4000 Slotted (02-05 WRX) $715 Installed
56. DBA 4000 Slotted (06-09 WRX) $715 Installed
57. DBA 4000 Slotted (02-07 NA) $677 Installed
58. DBA 4000 Slotted & Drilled (02-05 WRX) $780 Installed
59. DBA 4000 Slotted & Drilled (07-09 WRX) $780 Installed
60. DBA 4000 Slotted & Drilled (02-07 NA) $725 Installed
61. Resurfacing $80
62. Your own $180
STI
33. EBC OEM Premium (04 STI) $504 Installed
34. EBC OEM Premium (05-09 STI) $499 Installed
35. EBC Ultimax (04 STI) $691 Installed
36. EBC Ultimax (05-09 STI) $684 Installed
37. EBC Sport (04 STI) $769 Installed
38. EBC Sport (05-09 STI) $763 Installed
39. DBA Street Slotted (04 STI) $729 Installed
40. DBA Street Slotted (05-09 STI) $729 Installed
41. DBA Street Slotted & Drilled (04 STI) $777 Installed
42. DBA Street Slotted & Drilled (05-09 STI) $777 Installed
43. DBA 4000 Slotted (04 STI) $839 Installed
44. DBA 4000 Slotted (05-09 STI) $839 Installed
45. DBA 4000 Slotted & Drilled (04 STI) $911 Installed
46. DBA 4000 Slotted & Drilled (05-09 STI) $911 Installed
47. Resurfacing $80
48. Your own $180
• Brake pads install/replace FRONT ONLY
WRX
63. EBC Red-F (08+ WRX) $202 Installed
64. EBC Red-F (06-07 WRX) $202 Installed
65. EBC Red-F (02-05 WRX) $192 Installed
66. EBC Red-F (02-05 Non Turbo) $192 Installed
67. EBC Yellow-F (08+ WRX) $212 Installed
68. EBC Yellow-F (06-07 WRX) $212 Installed
69. EBC Yellow-F (02-05 WRX) $202 Installed
70. EBC Yellow-F (02-05 Non Turbo) $202 Installed
71. Hawk HPS-F (06-07 WRX) $185 Installed
72. Hawk HPS-F (02-05 WRX) $184 Installed
73. Hawk HPS-F (03-07 Non Turbo) $184 Installed
74. HP Plus-F (06-07 WRX) $215 Installed
75. HP Plus-F (02-05 WRX) $215 Installed
76. HP Plus-F (03-07 Non Turbo) $215 Installed
77. Your own $90
STI
1. EBC Red-F (04-08 STI) $212 Installed
2. EBC Yellow-F (04-08 STI) $222 Installed
3. Hawk HPS-F (04-08 STI)$224 Installed
4. Hawk HP Plus-F (04-08 STI) $246 Installed
5. Your own $90
• Brake pads install/replace REAR ONLY
WRX
78. EBC Red-R (08+ WRX) $116 Installed
79. EBC Red-R (06-07 WRX) $116 Installed
80. EBC Red-R (02-05 WRX) $126 Installed
81. EBC Red-R (02-05 Non Turbo) $126 Installed
82. EBC Yellow-R (08+ WRX) $126 Installed
83. EBC Yellow-R (06-07 WRX) $126 Installed
84. EBC Yellow-R (02-05 WRX) $136 Installed
85. EBC Yellow-R (02-05 Non Turbo) $136 Installed
86. Hawk HPS-R (06-07 WRX) $130 Installed
87. Hawk HPS-R (02-05 WRX) $130 Installed
88. Hawk HPS-R (03-07 Non Turbo) $130 Installed
89. Hawk HP Plus-R (06-07 WRX) $155 Installed
90. Hawk HP Plus-R (02-05 WRX) $163 Installed
91. Hawk HP Plus-R (03-07 Non Turbo) $163 Installed
92. Your own $45
STI
6. EBC Red-R (04-08 STI) $136 Installed
7. EBC Yellow-R (04-08 STI) $146 Installed
8. Hawk HPS-R (04-08 STI) $131 Installed
9. Hawk HP Plus-R (04-08 STI) $155 Installed
10. Your own $45
• Brake pads install/replace FRONT & REAR
WRX
1. EBC Red-F&R (08+ WRX) $318 Installed
2. EBC Red-F&R (06-07 WRX) $318 Installed
3. EBC Red-F&R (02-05 WRX) $318 Installed
4. EBC Red-F&R (02-05 Non Turbo) $318 Installed
5. EBC Yellow-F&R (08+ WRX) $338 Installed
6. EBC Yellow-F&R (06-07 WRX) $338 Installed
7. EBC Yellow-F&R (02-05 WRX) $338 Installed
8. EBC Yellow-F&R (02-05 Non Turbo) $338 Installed
9. Hawk HPS-F&R (06-07 WRX) $315 Installed
10. Hawk HPS-F&R (02-05 WRX) $314 Installed
11. Hawk HPS-F&R (03-07 Non Turbo) $314 Installed
12. HP Plus-F&R (06-07 WRX) $370 Installed
13. HP Plus-F&R (02-05 WRX) $378 Installed
14. HP Plus-F&R (03-07 Non Turbo) $378 Installed
15. Your own $135
STI
1. EBC Red-F&R (04-08 STI) $348 Installed
2. EBC Yellow-F&R (04-08 STI) $368 Installed
3. Hawk HPS-F&R (04-08 STI) $355 Installed
4. Hawk HP Plus-F&R (04-08 STI) $401 Installed
5. Your own $135
• Brake lines install/replace FRONT & REAR
1. Your own $90
Drivetrain
• Manual Transmission Rebuild Kits
STI $ Please email, pm, IM or call for estimate
1. PPG
2. RA
3. Subaru OEM (stock)
4. Your own
WRX $ Please email, pm, IM or call for estimate
1. PPG
2. RA
4. Your own
• Clutch/flywheel replace (includes flywheel resurfacing and new fluids)
WRX
1. Exedy Stage 1 $874 Installed
2. Exedy Stage 2 $948 Installed
3. ACT HDSS $1044 Installed
4. ACT HDG6 $1028 Installed
5. Your own $399 Installed
STI
1. Exedy Stage 1$920 Installed
2. Exedy Stage 2 $1060 Installed
3. ACT HDSS $1197 Installed
4. ACT XTSS $1236 Installed
5. ACT HDG6 $1139 Installed
6. Your own $450
Re: The Japtrix Performance Service & Parts Special Thread! Serving the South East Re
referring to the engine rebuild stage 2, u guys say its a "new NEW OEM EJ25 engine" so that means the rods and pistons get put on a brand spanking new block? not the one that we give you on our car?
and what kind of eagle rods? I beams or H beams?
thanks
Hey guys how busy are you this week for a tune?
1 - 6 of 6 Posts
