1 - 20 of 155 Posts
MOD LIST
Engine
B16B Engine
Password:JDM Power Chamber Intake
BME Custom Intake Box + Cold Air Feed
Spoon Ported 70mm Throttle Body
Ported CTR Intake Manifold
Spoon Adjustable Cam Gears
98-Spec ITR Exhaust Manifold and Shield
JDM-Spec Catalytic Converter
Mugen Twinloop Catback Exhaust
Yellow Painted Valve Cover
NGK Iridium Spark Plugs
*New engine bay bolts - replace the hideous PW:JDM Dress-up washer kit - 2013
*NGK Ignition Wires - Mid-2014
*Replace Timing Belt & Water Pump - Early 2015
Spoon Kevlar Intake Elbow
Drivetrain
S4C Transmission w/ LSD
Exedy Stage 1 Clutch
Exedy Lightened Flywheel
JDM ITR Shifter & Linkages
Suspension, Bushings, & Mounts
Koni Yellow Dampers + Ground Control Sleeves (400f/500r)
Swift Rear Helper Springs
OEM Strut Top Mounts
Type R-X Front and Rear Strut Bars
CTR Front and Rear Sway Bars
ASR Rear Subframe Brace
Beaks Lower Tie Bar - Not sure if this is functional, it'll be removed if it isn't
Blox Subframe Rigid Collar Kit
Hasport Engine Mounts
Alignment (-3.2*/-1.7*, zero toe)
HKS Hypermax Pro (1100f/750r) - Replaced by Koni
Brakes & Wheels
ITR 5x114.3 Front & Rear Conversion
15x6 Authentic CTR Wheels
Falken Tires 195/50
Password:JDM Front & Rear Slotted Rotors
Stoptech Street F/R Brake Pads
*Stoptech Stainless Lines - Early 2014
*16x7 Enkei RPF1 (powdercoated white) - Early 2014
*Muteki SR48 Lugs - Early 2014
Electronics & Tuning
Autometer Wideband AFR Gauge
Fuel Pressure Gauge
Crome Tuning Software
Dyno Tune by ProFunction ([email protected]/[email protected])
Interior
Genuine CTR Parts (bulleted)
- Red Recaro Seats
- Black Suede Rear Seats
- Red Carpet
- Front Door Panels
- Rear Quarter Panels
- Gauge Cluster
- Headliner
- Sun Visors
- Sunglasses Holder - To be sold
- 99-00 Center Bezel
- Floor Mats - Need to be modified with little stay pin
- Coin Tray Vent
- Black/Red Shift Boot
- Armrest Delete
Spoon Steering Wheel - Selling for OEM CTR
NRG Locking/Quick-Release Hub - Selling for OEM CTR
Spoon Shift Knob
Mugen Pedals
USDM Si Dark Gray Dash
Cleaned Up Paneling for Rear Strut Bar Opening
*CTR Steering Wheel - Early 2014
*Wood/Carpet Trunk Floor - 2013
*Any remaining trim - 2014
*Red Recaro Fixed Back Seat - Early 2015
*Custom-Fitted Half Cage - Early 2015
*Teamtech 6-Point Harness - Early 2015
*Carbon Fiber Roof - 2016
Exterior
- Headlights
- Front Bumper
- Grille
- Front Lip
- Hood
- Fenders & Sidemarkers
- Floding Side Mirrors
- Side Skirts
- Slim Side Moldings
- Red Badge Emblems
- Rear Hatch & Factory Tinted Glass
- Rear Lip
- Window Visors
- Rear Spoiler
- Front Spats
- Sticker Badging
- Painted Championship White
Tinted Rear Windows
99-00 USDM Taillights
*Swap in 96-98 Model Taillights
*Radio Antenna Delete
Fluids
Amsoil 10W30 Z-Rod Oil w/ EA Oil Filter
Amsoil Series 600 Brake Fluid
*Amsoil ATF Fluid for Power Steering
*Amsoil 5W30 MTF
*Clutch Fluid Change
Lighting
22W LED Headlight Kit
The #618 CTR is proudly sponsored by;
All Speed Innovations
2996 Henkle Drive
Suite J
Lebanon, OH 45036
(513) 228-0065
Re: The 618 LHD CTR
Nice........
Discussion Starter #4
Re: The 618 LHD CTR
Here are the first of the parts to go on the car when it arrives.
400lb fronts and 500lb rears. I also have a set of swift helper springs to help balancing the rear heights, I figure I should have enough play on the front heights in the lower mounting position. I'll find out soon enough.
I sprayed them down with some Boeshield to help with corrosion protection.
I Solve Problems
Re: The 618 LHD CTR
oh damn!!
I love me the EK CTR. kick ass. :D
Discussion Starter #7
Re: The 618 LHD CTR
I received the new fluids on Friday.
10W30 Amsoil Z-Rod & Ea Filter
Amsoil Synchromesh MTF
0W30 Amsoil Signature Series (for my D16 EK daily)
Discussion Starter #8
Re: The 618 LHD CTR
First non-car related post...
Last weekend was my bachelor party, I had an unbelievable time. Night before, me and a few friends grabbed dinner at this awesome burger place in the city. Then started rooftop drinking at around 2pm, followed by a rooftop view baseball game at 6pm, then the rest is a big blurrrr.
Anyway, some pictures.
I Solve Problems
Re: The 618 LHD CTR
sweet!!
is that a tempura avocado?
Discussion Starter #11
Re: The 618 LHD CTR
07/23/2013
Car was delivered today! Pretty much exactly what I was expecting it to be.
Snapped a few pictures on my way into work.
I Solve Problems
Re: The 618 LHD CTR
Ground controls on yet? :lol:
that suspension has to be crazy stiff.
Discussion Starter #13
Re: The 618 LHD CTR
Lol yea... it is super stiff, definitely needs the koni's ASAP. I made a hard right turn and could feel the tires hopping.
Other than that though, the chassis and car feel outstanding. The car just turns, no understeer or anything. I'm guessing it has to do with the LSD and the roll bars.
I Solve Problems
Re: The 618 LHD CTR
And the crazy stiff springs.
Go Karts turn super fast too for a reason!! :lol:
Can't wait to hear your review on the car after you get it all setup and get an event or two under your belt with it.
Discussion Starter #16
Re: The 618 LHD CTR
Unfortunately, it did scrape... Gouged the bottom of the lip pretty good. Luckily it isnt noticeable unless you're looking for it. I hope the freighter is willing to accept the pics I took and just settle with sending me a $200 check
Discussion Starter #17
Re: The 618 LHD CTR
Last night, my buddy helped me wash, claybar, and wax the car. Got a lot of little specks of buildup off of the finish, and were able to correct a good amount of the swirling. Eventually we'd like to hit it with some more aggressive polish, but this will do for now.
clay bar, 3 passes with polish, 1 coat of wax
P.S. I promise to get a real camera soon and start taking some nicer pics... The iphone is just not cutting it anymore.
Here are some more random shots from yesterday.
I Solve Problems
Re: The 618 LHD CTR
looking good!! Can't wait to see what's in store. What is this washing and waxing you speak of?
Discussion Starter #19
Re: The 618 LHD CTR
Suspension for sure has to be changed... Ordering some odds and ends, new dyno tune, alignment, security system, 205/15 BFG Rivals, etc etc.
I need to give the interior a deep cleaning though. And the seats need to be swapped driver/passenger are flipped...
We used dawn dishsoap to strip any old wax, then clay barred using Adam's polishes, then polished and wax with some different cut pads and aggressiveness of polish and finished with wax. Meguiars products were used for polish and wax.
Then in a couple of days I'll wipe it all down again with some Adam's Polishes Detail Spray. That stuff is the shiznit!
Re: The 618 LHD CTR
I must say that your are getting Civics to grow back on me... :bow:
In Québec, it's almost impossible to find one not riced out or tastefully modded, which made me loathe Civics, Honda/Acura in general, and the tuning culture associated with them. Years of hatred are not easily mended... but keep going, you just might cure me! :lol:
(that, and a nice S2000 with a hardtop/fastback conversion might do the trick too!) ;)
1 - 20 of 155 Posts
