1 - 7 of 7 Posts
This is a 5th gear pull. STi temp gauge read 61 degF. Please feel free to comment. I think my knock correction #'s look strong? Also, can someone show me how to organize this so we can read it easier?
Time,Engine Speed (RPM),Intake Air Temperature (°F),Ignition Timing (°BTDC),Vehicle Speed (MPH),Knock Correction (°BTDC),Manifold Relative Pressure (PSI),Air Flow Sensor Voltage (V),Accelerator Opening Angle (%)
992,3512,62.60,21,65,7,7.545,3.620,97.27
1132,3519,62.60,15,66,5,10.882,3.880,99.61
1272,3570,62.60,13,66,5,14.365,3.980,99.61
1412,3623,62.60,12,66,4,16.541,4.000,99.61
1553,3636,62.60,13,66,4,17.267,4.020,99.61
1693,3715,62.60,14,67,5,17.122,4.020,99.61
1833,3758,62.60,14,67,5,16.976,4.020,99.61
1973,3785,62.60,15,67,5,16.831,4.080,99.61
2274,3861,62.60,16,70,6,16.831,4.080,99.61
2284,3861,62.60,16,70,6,16.831,4.080,99.61
2394,3901,62.60,17,70,6,16.686,4.120,99.61
2534,3985,62.60,18,72,7,16.686,4.060,99.61
2674,4029,62.60,18,72,7,16.831,4.120,99.61
2814,4040,62.60,18,72,7,16.831,4.140,99.61
2955,4117,60.80,18,72,7,16.831,4.160,99.61
3095,4142,60.80,19,75,7,16.831,4.120,99.61
3235,4168,60.80,18,75,7,16.831,4.160,99.61
3375,4217,60.80,19,75,7,16.831,4.160,99.61
3515,4258,60.80,19,78,4,16.686,4.160,99.61
3656,4298,60.80,15,78,4,16.831,4.200,99.61
3796,4338,60.80,15,78,4,16.976,4.240,99.61
3926,4410,60.80,16,81,4,16.831,4.260,99.61
4076,4475,60.80,16,81,4,16.831,4.260,99.61
4216,4468,60.80,16,81,4,16.831,4.280,99.61
4357,4532,60.80,16,81,4,16.686,4.260,99.61
4497,4540,60.80,16,84,4,16.831,4.300,99.61
4637,4582,60.80,16,84,4,16.831,4.280,99.61
4777,4610,60.80,16,84,4,17.122,4.320,99.61
4917,4686,60.80,17,86,4,16.976,4.320,99.61
5058,4729,60.80,17,86,4,16.976,4.320,99.61
5198,4751,60.80,17,86,4,16.831,4.340,99.61
5338,4786,60.80,17,89,4,16.831,4.340,99.61
5478,4828,60.80,17,89,4,16.831,4.380,99.61
5618,4890,60.80,18,89,5,16.686,4.360,99.61
5759,4890,60.80,18,89,5,16.686,4.380,99.61
5899,4960,60.80,18,91,5,16.686,4.380,99.61
6039,4973,60.80,18,91,5,16.686,4.380,99.61
6179,5007,60.80,18,91,5,16.541,4.400,99.61
6319,5090,60.80,18,94,5,16.396,4.400,99.61
6460,5121,60.80,19,94,5,16.396,4.400,99.61
6600,5150,60.80,18,94,5,16.396,4.420,99.61
6740,5197,60.80,19,94,6,16.251,4.420,99.61
6880,5225,60.80,19,96,6,16.251,4.420,99.61
7020,5222,60.80,19,96,5,16.396,4.440,99.61
7161,5264,60.80,19,96,6,16.106,4.420,99.61
7301,5342,60.80,19,99,6,16.251,4.440,99.61
7441,5310,60.80,19,99,6,16.106,4.440,99.61
7581,5410,60.80,20,99,7,16.106,4.460,99.61
7721,5440,60.80,20,101,7,16.251,4.460,99.61
7862,5427,60.80,20,101,7,16.106,4.460,99.61
8002,5471,60.80,20,101,7,15.961,4.460,99.61
8142,5544,60.80,20,101,7,15.961,4.460,99.61
8282,5577,60.80,21,104,7,15.816,4.460,99.61
8422,5609,59.00,21,104,7,15.816,4.480,99.61
8563,5606,59.00,21,104,7,15.816,4.480,99.61
8703,5634,59.00,21,106,7,15.816,4.460,99.61
8843,5671,59.00,21,106,8,15.816,4.480,99.61
8983,5740,59.00,21,106,8,15.671,4.460,99.61
9123,5726,59.00,22,108,8,15.671,4.480,99.61
9264,5813,59.00,22,108,8,15.671,4.480,99.61
9404,5803,59.00,22,108,8,15.525,4.480,99.61
9544,5863,59.00,22,108,8,15.525,4.480,99.61
9684,5902,59.00,22,110,8,15.380,4.480,99.61
9824,5884,59.00,22,110,8,15.380,4.500,99.61
9965,5914,59.00,22,110,8,15.380,4.480,99.61
10105,5927,59.00,23,112,8,15.235,4.500,99.61
10245,5962,59.00,23,112,8,15.235,4.500,99.61
10385,5994,59.00,23,112,8,15.235,4.500,99.61
10525,6020,59.00,23,114,8,15.235,4.480,99.61
10666,6050,59.00,23,114,8,15.235,4.500,99.61
10806,6131,59.00,24,114,8,15.235,4.500,99.61
10946,6156,59.00,24,114,9,15.090,4.480,99.61
11086,6135,59.00,24,116,9,15.090,4.500,99.61
11226,6212,59.00,25,116,9,15.090,4.480,99.61
11367,6176,59.00,25,116,9,14.945,4.500,99.61
11507,6261,59.00,25,118,9,14.945,4.480,99.61
11647,6231,59.00,25,118,9,14.945,4.500,99.61
11787,6254,59.00,26,118,9,14.800,4.500,99.61
11927,6339,59.00,26,118,9,14.800,4.480,99.61
12068,6360,59.00,27,120,9,14.800,4.500,99.61
12208,6325,59.00,27,120,9,14.800,4.500,99.61
12348,6352,59.00,26,120,9,14.945,4.500,99.61
12488,6368,59.00,27,122,9,14.800,4.500,99.61
12628,6392,59.00,27,122,8,14.655,4.480,99.61
12769,6407,59.00,27,122,8,14.800,4.500,99.61
12909,6437,59.00,27,122,8,14.800,4.480,99.61
13049,6652,59.00,31,122,7,8.996,4.060,0.00
Copy and paste the above data to a Notepad text file just as it looks right now. Open Excel and click "Data", "Get External Data", "Import Text File" and select the text file you just created and click "Import". Select "Delimited" and click "Next". Deselect "Tabs" and select "Comma". Click "Next", "Finish" and "OK". Then you can go back and put in column headings, etc.
Discussion Starter · #4 ·
Thanks man! Only one problem though, I still dont know how to post it on iwsti, im a computer newb . I opened it with excel viewer and its all organized. What do I do next?
Thanks X a million
Steve
maf voltage indicates not much horsepower, time for a turboback and retune :)
4.52volts max? Is that bad or something, I do have the APS inlet pipe. Maybe you could be more specific caause I thought the number agreed with the stock size(65mm) of the stock box. Im a newby!! but im going to be in here ALOT!!.
1 - 7 of 7 Posts
