1 - 20 of 506 Posts
Well, here we go! Another journal, another tale to tell.
I have finally got my car to a point where I am proud of it inside and out, from rods to bolts and my journey is pretty common among the members of the community with mod paths in the beginning and then I digress...
You know how it started with me, that silly little COBB accessport and a hint of boost from the OTS Stage 1 map. The rest is history. I began with a TurboXS RFL exhaust and then I became addicted to boost from that day forward. I found as many bolt-ons as I could find and made my way to 484whp on a DOM3 turbo, high on life - my motor popped about a week later. This is truly where my real journey began; new friends, new passion, new material to learn and before you knew it, lots of money - in my eyes well spent. My personality doesn't allow me to do something without fully understanding why I am doing it or why it works so I was forced to learn my car from the inside out.
I began by seeking the help of Slowboy Racing for my motor build and with Mike Huml's help, we built a beast. It took months of going back and forth and shipping from MA to FL and when the day came for delivery finally, UPS dropped the motor off the back of the trunk. You can see how this is going right away, lol. The motor ate the bearings about 1300 miles later and I was sent back to the drawing board for a second time. I was introduced by a good friend of mine to someone I consider one of my best friends, his name is Tony Pinto. Tony took the time to show me the internals of my motor and took the time to explain to me what we should do for the next build. Without holding back, everything was taken apart, rebuilt coated, re-balanced and set up for the future. He drudged on tireless building my entire block with the same care and precision that he took on his motor.
With all things aside, I love to work on my car, cleaning, driving, beating it senselessly and installing parts. Below is my current mod list:
Shortblock:
2010 nitrided STI crankshaft
ACL rod bearings
ACL main bearings
Manley H-Beam rods
ARP rod bolts
ARP head studs
CP pistons @ 8.2:1 with coated skirts
Fluidampr harmonic engine damper
Cylinder heads:
5 angle valve job from Slowboy Racing
Kelford R199-C camshafts 272/272 11.3mm lift
RacingAxis Intake Valves (flat face, nitrided)
RacingAxis Exhaust Valves
RacingAxis Manganese Bronze Valve Guide
RacingAxis Dual Valve Springs (Chrome Silicone Vanadium)
RacingAxis Valve Stem Seals (Viton Valve Seals)
RacingAxis Shims, Buckets and Ti retainers
* beautiful port work by Slowboy Racing
Turbo setup:
PTE6262 turbocharger /w .84 housing
Prosport T3 turbo blanket
Treadstone uppipe
Treadstone downpipe
Treadstone recirculated wastegate setup
Tial 44 MVS
Tial 50mm BOV
P&L rotated intake manifold FMIC
Hallman MBC
AMS catback exhaust
Agency Power equal length header
Grimmspeed TGV delete
Grimmspeed 8mm phenolic spacer
* rotated OEM intake manifold
Fuel:
Fuel Injector Clinic 1100cc top-feed injectors
Aeromotive fuel rails
Custom equal length -6 AN feed and return lines
Fuelab fuel pump regulator
Assorted AN fittings
Russel Performance Y distrobution block
Walbro 255
Misc engine:
Koyo radiator
Mishimoto radiator hoses
Mishimoto carbon fiber catch can as coolant overflow tank
Crawford AOS
Torque Solution pitchstop mount
Subaru group-N engine mounts
Gate Racing kevlar timing belt
Grimmspeed 160 degree t-stat
NGK iridium one step colder spark plugs
JNA billet oil cap
Hella Supertones in gold
Gold fluid caps
Redline Tuning hood struts
Evap delete
AC delete
Drivetrain:
Exedy twin disc
clutch rapid engagement delete
Kartboy short-shifter
Kartboy front shifter bushings
Kartboy rear shifter bushings
TIC transmission subframe bushings
Advan 18x9 +45 wheels in Advan gold
Muteki black lug nuts
Hankook Ventus R-S3 tires @ 245/40/18
TIC Unabomber sexy rear end kit
Suspension setup:
Fortune Auto 500 series coilovers
- Swift springs @ 10k front/8k rear
- Swift helper springs for the rear
Perrin ALK
Perrin 25mm front sway bar
Perrin 25mm rear sway bar
Perrin helical front endlinks
Perrin rear helical endlinks
Perrin rear stout mounts
Oswald Performance tubular front subframe mount
Oswald Performance rear triangle brace
Brakes:
Harmon Motive SS brake lines
AXXIS ULT front pads
AXXIS ULT rear pads
DBA5000 series rotors (next purchase)
Exterior:
Chargespeed bottomlines V1
Voltex rear diffuser
Mines rear wing
OEM Impreza trunk OBP
OEM Impreza hood OBP
35% window tint
JNA raingaurds
Interior:
RED hazard button
Custom harness bar
SPARCO 4-point harnesses
Red hazard button
ATI gauge pod
ATI carbon fiber insert
STRI X-Line V2 EGT gauge
STRI X-Line V2 boost gauge
STRI X-Line V2 oil pressure gauge
AEM AFR gauge
Fluids:
Amsoil 10w-30 engine oil
Amsoil 75w-90 severe-gear gear oil
Amsoil power steering fluid
ATE super blue brake fluid
Management:
hYdra EMS
* Car is currently running 22psi on an open source tune with rom-raider but will be finalized with hYdra before the end of the summer.
A few of my favorite shots of my pride and joy.
A more up to date few pictures of the engine bay.
Re: t00mes 2007 OBP STI, Sweet Garage Ornament
well there's no doubt that it's going to be fast as all hell
Re: t00mes 2007 OBP STI, 484whp/461wtq, Engine rebuild time.
Pictures of the head and block build:
so sad,all that work and money spent only to let a pos shop like sbr touch it.im sure it will be fast but if sbr touched/assmebled/sourced parts for it theres no doubt youll be redoing the work.
We shall see in time. I was a little disappointed to hear that EFI logics is like an hour and twenty minutes from me, but Slowboy has been extremely well with sending updates/taking care of the engine so far. I pretty much hand picked the parts and just had them assemble it - it wasn't some off the shelf block that they advertise or anything like that.
Discussion Starter #8
I have been debating going EWG while the car is down for another few weeks. Probably going to get a Grimmspeed Uppipe and Turbosmart 38mm. Along with a Grimmspeed Downpipe to match the HKS Carbon Ti I just picked up.
Discussion Starter #9
Re: t00mes 2007 OBP STI, ongoing engine rebuild. Fuel rail install pics!
Posting some pics of the fuel rail install. Pretty simple stuff actually.
Getting everything ready to go!
Removed old orings and put new ones in the baggie to lube up with the super lube.
All cleaned up.
Discussion Starter #10
Motor is being torn down tomorrow, updates to follow!
Discussion Starter #11 (Edited)
On a good note, the engine turned out to be okay. It is being put back together, and should be shipped home this week! Thank god. It's been 5 months. What a fiasco with UPS :[
I recently purchased a used HKS, and it needed some SERIOUS, TLC.
Okay, this was the remains of a doughnut gasket SHOVED into the flange and baked on -- as you can see the flange needed to be cleaned up rather intensely. The surface on it was like a piece of bread with cavities and mounts. I dremeled the surface down for about 30 minutes until it was 90% smooth and then hit it with a grinder and now its back to a glassy surface.
Discussion Starter #13 (Edited)
Re: t00mes 2007 OBP STI, ongoing engine rebuild. New exhaust! Refurbishing pictures.
Just picked up this lip. Partly because I haven't see anyone running it and also because of how aggressive it is. Who knows, it might be going back. Have to mock it up before making the final decision!
Thank you UpscaleAutomotive!
Lip is currently back ordered 6 weeks, don't really feel like waiting for it.
Discussion Starter #14
New parts on order:
  • GT SPEC Uppipe /w exernal wastegate flange
  • TIAL 38mm wastegate with 1.0 bar spring, possibly looking to go 1.5 bar?
  • TiC Unabomber Sexy Rear End kit
  • TiC tranny cross member bushings
  • Invidia V2 Downpipe
Discussion Starter #15
So.... I ordered the TiC parts about 30 minutes ago and thanks to Clint -- they are now on their way already. HAHA, these guys don't mess around! Can't wait to install these!
TY turninconcepts.com
Discussion Starter #16
The motor is on it's way home!! Finally!!
Discussion Starter #18
Re: t00mes 2007 OBP STI, ongoing engine rebuild. GrimmSpeed parts and new Downpipe!
GrimmSpeed galore!!
Discussion Starter #19
Re: t00mes 2007 OBP STI, ongoing engine rebuild. MOTOR IS ON ITS WAY HOME!!! SO CLOS
Day or two left before motor lands in my garage.
Discussion Starter #20
Confirmed, Tomorrow is D DAY!
1 - 20 of 506 Posts
