1 - 19 of 19 Posts
How many use synthetic oil?
Which brand do you recommend?
Do you use other than the stock oil filter?
You might want to dig around a bit. There might have been a pole done on this topic. I use factory filter and mobil 1. --Sin52
Drive True
There is. Search around. Mobil 1 Synthetic with Bosch Premium filters have been recommended, but don't go synthetic for the first 6000 miles or more.
Why 6,000 miles? A friend at work bought a mini-s this summer and his first oil change is at 10,000, included with purchase. They start the mini out with synthetic.
I asked the head of the service dept. the same question when I picked up my STI, according to him, when he went to AZ. for the STI roll-out last summer, they were told by the Subaru factory techs not to use syn. oil in the STI. Our cars are designed to use SL grade conventional motor oil. I think he(head of the service dept.) said it's because something about the all aluminum motor with syn.oil... hell I was so exited about getting the car I didn't listen to all of it. Anyhow, since I'm (was) a faithful mobil 1 supersyn 20w50 user, I've contacted Subaru of America, and they told me the same thing, which is not to use syn. oil.
search, search, search...there have been dozens of posts about this...
I was told differently. Anyway as norcal-sti said it's been discussed plenty times!
If synthetic wasn't OK, it'd say so in the manual.
I use Mobil 1 and OEM filters.
i use Royal Purple 5w30 I was told its the best oil out there! I hope its true im not here to hurt my baby!=)
Discussion Starter #12
Thanks for all the answers. I will continue looking, but, as with so many things car, I doubt if I will find the definitive answer.
FYI, this year is the 25th anniversary of the book, "Zen and the Art of Motorcycle Maintenance." Maybe I should read it again.
I heard its too late becasue by then the seals have adjusted to the regular mineral oil, But if you were to put synthetic you will cause a few problems such as shrinking in seals which may cause leaks underneath the car, and the motors lubrication isnt used to that sort of light weight oil.....so if i were you what i did with my other car was buy the syntecblend by castrol, that is the SHIT you will love it so you will get both worlds partial synthetic and mneral oil. I hope my .02 cents work for ya!
Agent Chobos said:
I have a question: Is it ever too LATE to switch to synthetic? Like, say, after 60-70k miles?
No, it's never too late. Back in the olden days of synthetics--the 70's--there were some problems, but, since then, synthetics have been adjusted to be compatible via the addition of additives.
Synthetic blends are OK, but they're a compromise: you won't get the full benefits of full synthetic.
First change at 980 miles dino oil
Second change at 2410 miles dino oil
Third change done today at 4816 miles Mobil-1
All changes done with OEM filters.
rattling- don't get too shaken up guys!
gee, the shop i go to swears by that purple sythetic oil and i am planning on making the switch. thay use it on their own shop car....and my dealer reccommended synth oil cause it's better for racing(which i do...at the track) is that worth two cents? i dunno but research you'll see... check nasoic
Discussion Starter #18
I took the plunge today. Did my first oil change--okay, that's a white lie--I HAD my first oil change done today by Curry's Auto Service. They recommended Mobil1, so, based on your advice, I said yes. So far, so good.
Next mod, Lasik eye surgery so I can see better what's coming down the road.
Fully synthetic after 1k miles is the only way to go, especially on a turbo motor with serious hot spots that will burn dino-juice. I'm on Mobil 1 5W-30 for the winter (factory filter) and 10W-30 Mobil 1 for the summer. Check the manual, it says synthetic is just fine. After SOA saying the pistons were forged I'm not sure I trust anything technical from them...
1 - 19 of 19 Posts
