Try swapping crank sensors if you can get your hands on one, Double check your fuses, and make sure the tune is set for startup
Next check fuel return -- makes sure fuel is getting past the injectors and running through the return -- just pop off the return line and cycle the key -- fuel should come out of the line.
Check for spark -- make sure the coil packs arc when you attempt to crank her -- the simple method is remove the coil pack, pull off the boot and then hold the sucker close to the block -- the professional method is a spark test kit if you want to try to borrow one from advance auto or something.
When in doubt, post up plenty of pictures of it all in, and maybe post up a link to a startup map that is unlocked.
