1 - 2 of 2 Posts
Is the stock muffler the $800 STI one or just a fancy tip...
Does any material need to be placed between the strut par and the sheet metal to protect it from scratching and abrasions?
Can anybody recommend any material?
Has anybody installed one without any material?
I wouldnt think so, as I was not supplied with any and didnt use any. I have installed both front and rear without anything under it, so Im sure you will be fine, MAKE SURE TO USE THE RIGHT TORQUE SETTINGS WHEN SCREWING THE BOLTS DOWN. 14.5lbs is the torque I believe, otherwise you'll have to replace the mounts like I am going to have to :( <<shoulda downloaded the manual sooner
That and if anything was abriasive, I'd think they would supply something to keep the nut (caps/top) from scraping and such (in stock form/without a strut bar and just the bolt caps on top).
1 - 2 of 2 Posts
