1 - 20 of 66 Posts
· Premium Member
Some quick notes for noob StreetTuner users who want to tune their VF39'd STI with a TBE. These comments are for those wanting to produce a better tune for your car but have no clue what to do. I am not an expert and I take no responsibility for anything that you may do to your car. This is your decision. I am not a road racer, so anything below is for 1/4 mile type racing (i.e. relatively short bursts). For extended racing and high speed, high RPM pulls for extended time, more fueling and slightly less timing than suggested would be highly advised. In fact, I would consider using a stock Cobb 2 map for road racing.
First and foremost, install your wide band and log data. At a minimum what do you want to log and why?
  • Throttle Position - (You have to know if/when you are at WOT)
  • Load - (Ignition and fuel tables are based on Load)
  • Wideband AFR - (You need to know if you are running lean or rich)
  • RPM - (Ignition and fuel tables are based on RPM)
  • Boost - (Can't tune boost if you don't know what it is)
  • Wastegate Duty Cycle - (This determines your boost. The ECM modifies this in an attempt to reach target boost)
  • Injector Pulse Width - (Very Important. The STI injectors are undersized from the factory. TBE + EM maxes them)
  • Ignition Timing, Dynamic Advance, Dynamic Advance Multiplier and Knock Activity - (Need to log all of these to tune ignition)
What are you looking for in the logs? At first, you just want to really get familiar with things. Get familiar with things? What does that mean? What will I see? What am I looking for? Well ...
  • Insert a row beside the Injector Pulse Width (IPW). Add a formula of IPW * RPM / 1200. This is your Injector Duty Cycle (IDC). Populate this formula down the entire column and check out your IDC. At this point you will be saying 'Whoa, they are really high at WOT!'. Welcome to factory STI injectors really suck if you mod your car. Now you know why.
  • Look at your Wastegate Duty Cycle (WGDC) and compare it to your actual boost while taking into account the boost target specified in your StreetTuner tune. You'll see some very interesting things at WOT in the upper RPM. What will you see? Well, most of you will see that Cobb's maps never achieve the specified target boost in the upper RPM. You'll see that the WGDC in the log will be maxed at the value specified in your WGDC (high) map in StreetTuner.
  • Dynamic Advance (DA) is all over the place ... and will vary on one day compared to the next, or one WOT run compared to the next. You may notice after a couple weeks of logging that your DA is rather small compared to a week or two previous and that your car feels sorta slow. Welcome to the world of Dynamic Advance. Reset the ECU and do a couple WOT runs. Within 3 WOT runs your DA will have completely learned and you will be running max DA (which will most likely be higher than what you just logged).
  • Look at the load. At WOT it increases and then decreases. Our VF39's can't support any midhigh-to-high RPM flow so the boost naturally tapers (even if you specify higher boost). Thus, the load decreases as RPM rise. This is an important observation in it's own right. Given that the fuel and ignition maps are based on load, you need to make sure that you look at the StreetTuner maps in their entirety. You can't just look down the column. You have to look from right to left and left to right.
  • Look at the load again. You will notice that Cobb's main ignition and fuel tables max out a 2.75 load. A standard Cobb Stage 2 map running 17.5 PSI can hit 3.0-3.10 load. This, IMHO, is unacceptable. A stock Cobb map is already off the chart.
  • Check your Ignition Timing. Compare it to your StreetTuner files. You won't be able to fully figure out how you are getting values that you are. You'll also learn that Ignition Timing changes based on Load. Load is proportional to boost. Boost varies based on gear. Thus, you will run different timing in different gears (at the same RPM) when comparing 1st and 2nd to 4th and 5th.
  • After a reset the Dynamic Advance Multiplier (aka Ignition Advance Multiplier or IAM) is at 0.5. Simply putting the car in 5th gear at low RPM and holding boost to 4-6 PSI for a few seconds will max it at 1.0 very quickly. Neato Mosquito.
  • Knock Activity sucks. It is binary - On and Off. This is a limitation to how you will tune if you want to use this for determining knock. Remember, you are only gathering so many frames a second. It can knock in one fraction of a second and not another. Plus, this assumes you want to depend on the pre-determined ECM boundary for knock (the threshold).
The above is just a start. There are a bunch of other things to see too. Furthermore, the above only considers WOT. For part throttle logging you will want to view MAF volts, A/F Learning (long term fuel trim), A/F Correction (short term fuel trim), and even the stock AFR. This type of information can be used to dial in your specific intake or to fine tune the factory intake. More on that later.
So, you've logged data and looked at it ... tens of times. You've learned a bunch of stuff. You are familiar with what's going on. Where do you go from here? This is a tuner's preference. You will see varied suggestions with various reasoning. Personally, I like Boost, then Ignition, then Fueling for a stock VF39 with a TBE (well call this B->I->F). If you have an aftermarket intake then I would suggest tuning that first.
INTAKE TUNING
You modify the MAF table (Intake Calibration). You basically look at what the A/F learning is at a particular MAF Voltage. Look up that MAF voltage in the Intake Calibration table. Take the value for that voltage and multiply it by the A/F learning.
Examples:
  • +5% A/F learning at 1.20 MAF Volts
    Let's Assume the value for 1.20 MAF Volts is 3.1 g/s.
    The new value will be 3.1 + (0.05 * 3.1) = 3.255 = 3.26
  • -7.2% A/F learning at 1.20 MAF Volts
    The new value will be 3.1 - (0.072 * 3.1) = 3.255 = 2.88
Make sure that you expand these changes to the adjacent cells and smooth things out a little. You need to modify as many of these as possible, which means you need to log a lot of various driving where you can obtain different MAF Voltages. After making these changes, you have to drive your car around for awhile and let it relearn (or reset the ECU). This is one location where using the cursor tracing feature doesn't help you right away.​
BOOST
In order to follow the B->I->F you want to first ensure that you are rich across the board once boost hits good (10+ PSI). If you are running greater than 11:1 AFR, (i.e. you are running mid 11s to mid 12s), then I would suggest first tweaking the fuel. You don't want to increase boost when you are running lean. That would just be stupid.
The reason I am suggesting that you verify that you are running rich is because Cobb does something that I do not agree with as specified above. Their fueling tables only go to 2.75 load when at the stock 17.5 PSI settings in Stage 2 you can hit 3.0-3.1 load. Thus, if you push boost up to 18.5+, you are going to be even further off the chart (3.2+).
Let's assume that you are running rich so that you can start with tuning the boost. Most Cobb Stage 2 STI maps (let's assume the 1.10 maps - IIRC, earlier maps were leaner) at sea level with a stock intake will run rich. How do you tweak the boost? What values should you target? This is a sensitive area. Again, lots of tuners have different theories here. I've seen max PSI recommendations ranging from 17.5 to 19.0. However, generally most recommendations fall at about ~18.5 PSI.
This is absolutely not a max boost across all RPM. Why? Well, first of all, the injectors wouldn't support it (as we should now know because we are hitting almost 100% with only 14-15 PSI in the upper RPM. Second, the VF39 can't support that much boost. (Yeah, yeah - some of you are going to say to replace the actuator or add helper springs to help hold boost till redline a little better. We'll get to this later. It's not a bad idea but you have to be extra cautious when doing this.)
18.5 PSI appears to be a safe value to attempt to achieve in the mid RPM. First and foremost, you cannot simply use the Boost Targets table. This is just a target. The ECM has boundaries on how it can utilize the Wastegate Solenoid in order to achieve this boost. Thus, you must also modify your WGDC tables at the same time. Take a look at Cobb's maps and you'll see 17.5 PSI as a midrange target boost. Many StreetTuner users bump those values up to 18.5 PSI, and then set the WGDC table to 75% across the board for WOT and call it a day. Been there, done that. It's not a horrible approach. It does work ok. However, don't start there and don't stop there.
Don't start with 18.5 PSI. Start lower with 17.75 PSI and log. Bump up to 18. Bump up to 18.25. Bump up to 18.5. In each instance, verify your IDCs are ok, your Wideband AFRs are still rich (<11:2), and that you're not pinging. I said don't stop there.
  • Continue to tweak the WGDC high map so that you achieve target boost at the specified high WGDC (or with a few percent to spare) - (this will also serve as a clamp to help control boost creep.)
  • You may also consider tweaking the lower WGDC map to provide more room for boost creep. However, this is a double edged sword because it will take longer on an ECU reset to get to the target boost.
Now we can address a very unique part of boost tuning: the higher RPM. Here is what you will notice with your Cobb Stage 2 setup at sea level with a stock intake: You will never reach boost targets in the upper RPM and even if you did reach them then you can extrapolate to say that your IDCs would be over 100%. You won't reach boost targets for 2 reasons.
  1. The turbo just isn't capable of providing that much.
  2. The WGDC high map is only 75% in the upper RPM.
I'd love to hit 16.25 PSI at 6400 as specified in the Target Boost map for Cobb Stage 2. In reality, you are going to be lucky to hit 15.5. You can better try to reach these targets by bumping up the WGDC (high) map at 5600 and 6400. With mine bumped up to 85%, I am only hitting 15.0 PSI and have 99% IDCs. I can't imagine hitting 16.25. Rule of thumb is that you never want to have to use really high WGDCs to achieve your target boost. If you think you need to use >90% then the turbo is just too small. Don't put 100% in the WGDC maps and consider not using >90%. Please keep in mind that diminishing returns truly applies to this VF39. Forcing this turbo to produce 16 PSI in the higher RPM (via a helper spring or actuator change) doesn't mean that you are going to be faster. For the VF39, forcing it to do anything above like 15.5 PSI in the upper RPM just means you are blowing really hot air. Keep in mind that 14 PSI of cool air creates more power than 16 PSI of hot air. If you remember that then you are golden. More boost doesn't mean more power.
Also don't underestimate the backpressure you are creating in the pre-turbo plumbing by trying to run higher boost in the upper RPM. Now, with all of that said, adding a helper spring to your VF39 if you are sure you have enough injector to do so isn't a bad idea as long as you keep the boost clamped to no more than 15.5 PSI at redline. However, this is a really sketchy area since you need to be 100% sure you have enough injector and you need to find an appropriate spring that won't produce too much boost. Cool? Cool. Another thing that I want to touch on quickly is optimizing your target boost tables at higher RPM. After pumping up the WGDCs in order to achieve higher boost in the higher RPM, you will become very familiar with the amount of boost that you can produce vs. IDC. I would highly advise that you reduce Cobb's boost values in cases where your turbo isn't capable of producing more boost and your injector duty cycle is about maxed out anyhow.
Example: Cobb specifies 16.25 PSI at 6400 RPM. With a 90% WGDC and my injectors static I am only getting about 15.0 PSI. There is absolutely no point in me having 16.25 specified. The proper thing to do is to reduce this value to a value that is safe. Reduce it to 15.0 PSI because the injectors can't support more anyhow.​
Ok, I'm done with describing very simple boost tuning on the VF39 with TBE. I know some will reply and say so-and-so said blah, blah, blah and so-and-so said blah, blah, blah. Thanks. Again, "This is a tuner's preference. You will see varied suggestions with various reasoning.". Others will reply and say that 'You just increased boost with no measurable means to record whether you made the car faster or not.'. I fully agree. I would suggest doing this on a dyno or on a drag strip. Did I do that? No. Will I go to the dyno/dragstrip and check my changes later? Absolutely. Do I like how the car drives with the new boost settings? Absolutely.​
TIMING
Now on to Ignition. Egad. This one sucks. There is enough theory here to fill up pages and pages. Lets get to the point here.
We want to run the minimum amount of timing necessary to produce maximum power and we want this timing to be consistent.
You then also need to make the decision as to whether or not you want SOA designed safety built in. In laymen's terms, we need to know what values to shoot for and we need to know how to achieve them. The values I will list here as to what to shoot for on the stock VF39 with TBE are based on other tuner's work. I don't claim to have come up with these. If you don't want to shoot for blind values listed here then you will need access to various knock indicator tools to determine your own values (knock microphone/stethescope, an indicator like a KnockLink, etc).
The values I have seen others use for TOTAL IGNITION TIMING are:
  • 18° at 4000 RPM
  • 22° at 5000 RPM
  • 24° at 6000 RPM
  • 28° at 6800 RPM
You want to be careful with timing around 3200 - 4000 RPM. Timing can be extremely sensitive in this area since this is where max boost is happening and since this is where the motor is volumetrically efficient.
Moving on, the natural next question is how the heck can you achieve these values given the SOA dynamic advance. How do KC A, KC B, and KC C work with the main ignition in order to produce a predictable ignition advance? I have no clue ... and I have truly tried to understand. I've had no luck in truly figuring these out. What I have determined is that the knock advance most clearly follows KC A and that KC B appears almost to be a max limit that the ECM can try to achieve given the right gas. I have no clue what KC C is for. Long story short, here are the various ways that people have tuned the ignition advance to my knowledge ...
  1. Smooth A and B. Leave C alone. Increase A and lower B. Add a little to Main Ign if values of 5 or greater are used for KA. (I've seen Cobb do this)
  2. Leave all of the KC tables alone. Do all your work in main ignition (I've seen Jorge do this - RiftsWRX).
  3. Smooth A and B. Leave C alone. Increase both A and B. Leave Main Ign alone. (various users).
  4. Smooth A, B, and C. Subtract from B and C. Leave Main Ign alone. (various users).
  5. Set all KC tables to be 100% equal. Leave Main Ign alone. (various ECUTek tuners do this).
  6. Use a custom base map from Cobb that only uses KC A and thus converts the Dynamic Advance to be similar to a WRX. Leave main ignition alone and put all extra spark advance into KC A. This is very similar to #5 above.
I have had the greatest success with #5 and #6. I am currently using #6 for simplicity and easy tuning since KC C isn't a realtime map. It's pretty easy to tune the WOT timing once you can predict what the values will be. Hypothetically, if you need an extra degree of advance at 5600 RPM and 2.50 load then you simply add 1.0 degree of advance in KC A at 5600 RPM and 2.50 load when you are using method #5 or #6. With #5 you need to copy those changes over to KC B and KC C. With #6 you make the change to KC A and forget about KC B and KC C because the new base map replaces all pointers to KC B and KC C with pointers to KC A. It works and it works great.
The only thing that you need to be concerned about is safety. I can't make that determination for you. However, I can say the following: Any additional knock advance is still in an 'extra map' that is dependent on the Ignition Advance Multiplier. You have added no extra advance to the main ignition so the overall 'additive dynamic amount' will still change based on bad gas due to the IAM. This is how ignition is done on the WRX so it can't be that bad. Last, but not least, it is safer than UTEC because you are still using a base ignition table and an additive table. It is as safe as many ECUTek tunes because they are going to do the same thing that I just explained. You make the call.​
FUELING
Now on to fueling. This one isn't so bad and is relatively easy to do. In my opinion, this is the easiest thing to do. Again, as with ignition timing, there is enough theory here to fill up pages and pages.
This one is definitely dependent on not only the tuner, but also on how you will be driving your car. I drive mine for short bursts of power: stoplight to stoplight, 1/4 mile, etc. I don't road race or high speed race on the highway. To keep this relatively short:
  • I strive for very high 10:1 AFR at peak torque and then lean it out to lower 11's as RPM increase. For me this means 10.9:1 at peak torque (often peak boost on a VF39 + TBE STI) with the AFRs leaning out to 11.3 toward redline. You'll often see the exact opposite of this: Lower 11's on boost to high 10's at redline.
  • The opposite approach is better for road racing since the extra fuel at extended high RPM driving in the higher RPM can help to slow the burn and thus act as an anti-detonation mechanism.
  • Some tuners shoot for 11:1 across the board to provide a good compromise on power and safety. The choice is yours.
Another debated topic is if you should run lean on spoolup or rich on spoolup. Again, you will find many opinions on both and I won't claim to be a good opinion. There is enough information on NASIOC about this that would take you days to read. I like the lean on spoolup theory but, honestly, that means nothing because I am no expert.​
Also, I wanted to add in that I will be updating this later after adding a Walbro Fuel Pump. I will then be updating it again after adding a Perrin EBCS.
t
Update: Tuning for the Perrin Solenoid
Hi Tim,
Have you been to the track or Dyno to test out your maps?
I just ordered the Accessport, will play with stock maps till next spring when I get the StreetTuner software.
SUL
· Premium Member
Discussion Starter · #4 ·
TurboQueef said:
Hi Tim,
SUL
I'm a horsepower junky. My old Camaro had 400whp+ and when I got the STI I missed the power of the Camaro. I immediately resorted to modding and actually didn't even want to go to the track. When you are use to running 11's and then you are looking at running 13's it kinda ruins the desire to go (for me at least). 11's felt slow to me so you can pretty much guess what I thought about running 13's. I haven't gone to the track yet with this car ... but, rest assured, I will be going :) Right now I am caught up in optimizing what I have. Once I get things dialed in to where I like them then I will go to the track and run the stock Cobb Stage 2 stuff and then run my own map too. So, everything right now is road tuning. I have no proof to offer anybody for what I mentioned above in terms of it actually increasing horsepower. SOTP and Butt dynos suck so I won't say the car feels better ;)
t
t
You should see if you can borrow someone's G-tech or other meter. Heck, if your near Houston, I'll lend you mine - I'm curious as heck.
I'm getting ready to buy the Street Tuner and your post will really help, even though I am really clueless when it comes to tuning.
Very well written! I mean that I am just beginning to teach myself how to do what you described. I just received the books Maximum Boost and Car Hacks & Mods for Dummies in hopes of getting my mind around this tuning mystery. Your write up is easy to read and it's disarming in a converstational sort of way. I very much appreciate your efforts in giving the noob community (and the advanced too) something to ponder and begin with. I've been following your comments with a guy (Dave Hall) on Cobb's site and at this site (whatever it's name ends up as..sigh) and I was thrilled to see your post over here. Thanks again for sharing your findings! Wolfplayer = stud. :tup:
· Premium Member
Discussion Starter · #8 ·
Sweet! ... and I only thought my wife thought that ;)
I'm glad that I can relay my experience to everyone in an attempt to make things easier. Granted, there is tons more to talk about. However, at least there's a starting point that might be of help to those just starting out? I hope so. I know how difficult this can be. The cool thing is that all of us can expand upon this post and grow it. That's the best thing of all. This post can turn into a living breathing tuning post. We have a start :) Now we just have to keep it rolling along with everybody else's experiences. I'm just one small guppy in the sea - lol.
t
I've been using the Delta Dash software dyno to see how my changes have worked. Very useful tool. I might eventually pick up a G-Tech so I don't have to be running Delta Dash to do it. Even these pseudo dynos help to determine if what you changed actually did anything.
Wolf,
I'm curious about the tuners who choose to push the timing further and run less boost. Some tuners here have talked about running less boost at peak torque (~17.5 max). The question is are these guys the ones running more timing in the peak torque area?
The reason I'm interested is my S4 used to respond very well to timing in the mid range (Always had to run good fuel). Timing gave the car a much more "responsive" feel out of boost. This was a great feel and seemed to help with spool up times, not that the S4 has problems in that area ;)
This is a tuning school would like to try (I'm still logging the AP like crazy and trying to learn before the ST is installed), I'm was curious what you thought of this route and if you had been down this tuning route?
There is one more question about MBT. The theory that I understand at this point is you want the peak reaction to happen right at TDC or slightly after and this is why we create the spark before TDC. Given this MBT depends on the stroke of the particular engine or time it takes for the piston to travel that stroke correct? This is why when you push beyond MBT, no more power is gained correct?
Thanks,
Rob
Quick question,
You modify the MAF table (Intake Calibration). You basically look at what the A/F learning is at a particular MAF Voltage. Look up that MAF voltage in the Intake Calibration table. Take the value for that voltage and multiply it by the A/F learning. Examples ...
The new value will be 3.1 + (0.05 * 3.1) = 3.255 = 3.26.
Are the values logged for intake learning the percentages (0-100) or the decimal equivalents (0.0-1.0)? That is, given the above example, what number is in actual the "A/F Trim Learned" log column? Is it 5.0 or 0.05?
Thanks...
Just from my little bit of logging, etc... it almost appears to me that the ECU is interpolating (or maybe just hard-switching) between KC A and KC B based on IAT (or IAT + other factors). On the same tank of gas I have seen what appear to be changes in the timing that look like going from B to A without any sign of knock, running plenty rich, and the only real difference I can tell is the IAT. If that's the case, then increasing A could be dangerous depending on climate and whether you have a short ram, etc. And, of course how you are tuning in general would decide that ultimately. But IMHO, I'd keep the danger zones in A lower than in B. But what do I know. ;) Admittedly very little at this point.
Looking at it some more, timing definitely seems to be reduced, but it seems to be happening in a stage after knock correction is applied. Subtract my logged knock correction values from my logged ignition when IATs are very high, then it seems very apparent that something else is also reducing the final ignition values. The knock correction values are lower (closer to A map), but still positive. And the total ignition is lower than what my ignition map + knock correction should be.
I have been playing around with a short ram out of curiousity. Definitely of no real power value on stock turbo/stock IC. No surprise.
The section on intake tuning helped me, thanks.
For my injen limited (wrinkle red) CAI, I had to add +12.5% on the low end and +6.25% on the high end, it feels much better now and idles like normal.
· Premium Member
Discussion Starter · #17 ·
... and people say that the injen uses the proper MAF size ;)
t
My A/F learning was at +15 at idle a day (75 miles, multiple drives) after installing the injen CAI, and my LC-1 readings at WOT had jumped from 10.9:1 to 11.7:1.
1 - 20 of 66 Posts
