1 - 20 of 203 Posts
***See last page for most recent updates.
This tale all began when I first purchased my Aspen White 06 sti back in 2011. It was magical. After an unfortunate accident in which the vehicle was in a rollover (I was ok luckily), I then found a beautiful, low mile SGM 06 sti that was even nicer that my previous unit.
Now this brings us here.
Non-Current Mod List:
Engine and Go Fast Bits:
Cobb Accessport V2 - Protuned
Invidia N1 Race exhaust
Invidia V2 Catless Downpipe
GT Spec UEL Header & Uppipe (Ceramic Coated & Wrapped)
Kartboy Exhaust Hangers
Grimmspeed Heatshield
Cobb Intake and Cold Air Box
Cobb Crank Pulley
Walbro Fuel Pump
Killer B Oil Pickup Tube
Grimmspeed EBCS
Grimmspeed AOS
APS Twinvent BPV
Bushings and Mounts
Custom PitchStop Mount
Cusco Engine Mounts
Cusco Transmission Mounts
Kartboy Short Shifter
Kartboy Front and Rear Shifter Bushings
Whiteline Transmission Crossmember Bushings
TIC Clunk Killer Race
Kartboy Subframe Bolts
Beatrush Prop Shaft Bushings
Suspension Goodies
TiC SST Coilovers (7k/5k Springs)
Vorshlag Camber Plates
Whiteline Sport ALK
Whiteline Roll Center Kit
Whiteline Steering Rack Bushings
RCE Sway Bars
Kartboy Endlinks
Group-N Trailing Arm Bushings
Group-N Lateral Link Bushings
Custom Strut Bar
TIC Fender Braces
Oswald Front Bumper Beam
Oswald Rear Bumper Beam
Oswald Performance Rear Strut Brace
17x9.5 + 38 Enkei RPF1's
Falken RT615K 255/40R17
10mm 5mm Wheel Spacers (front) & Nismo Extended Lugs
Stopping
Girodisc Front & Rear 2pc Rotors
Front Ferodo DS2500 Pads
Rear Hawk HPS Pads
Stoptech SS Lines
Grimmspeed Master Cylinder Brace
Motul RBF600
Appearance and Randoms
Weathertech Floormats
JDM Red Hazard Button
OS Handle Delete's
V-Limited Style front Lip
08-10 STI Trunk Badge
Rally Armour Mudflaps
GrillCraft Upper Grilles
Black Painted Headlight Housing
TSX-R Clear Projector Lens Swap w/washer mod
LED Park Lights
Ixiz Hood Dampers
Ixiz Dead Pedal
04/05 Tailights
Subaru Foglights
Subtle Solutions Front Plate Delete
Rennenmetal Front & Rear Tow Hooks
CS Replica PU Sideskirts
Pioneer Touch Screen HU
Alpine Type S front Component Speakers
Wingless and Winged Trunk
Defi BF Advance Control Unit
Defi BF Oil Pressure, Boost, EGT Gauges
**For current mods, sift through the pages.
Coles notes:
-Outfront closed deck block w/ forged internals
-rotated Holset HX35
-rotated intake manifold + fmic
Here are some of the parts that I have built myself.
Pitchstop Mount
Modified Gtspec Strut Bar
Continued......:banana:
Re: Street Machine --> A tale of an 06 Sti
And now this brings us to the part where I crave MORRREEEEE POWWWWWAAAA! Classic, I know.
So I have now decided to increase power in the car, thus pushing it past the stock blocks "safe" capability. I am all about properly building my car, and not taking any shortcuts. This is why I decided to build the motor and not just go straight to the rotated turbo setup without properly strengthening the engine first.
As of now, the time line looks like this:
pull engine (done)
disassemble engine (in the works)
sell good shortblock/order new shortblock (February)
install new shorthblock (March)
break in motor (March)
install rotated turbo setup (May/June)
be very cool :cool::cool: (Anytime after May/June)
Shortblock Build list (subject to change)
Outfront Closed Deck EJ25
CP Pistons
Manley H-tuff Rods
King bearings
ARP 2000 rod bolts and head studs
Heads (keeping stock for now)
deck
refresh if needed
This is all in an attempt to safely and consistently run a streetable 425-475 whp. The car will mainly be a summer DD with the occasional track session.
The rotated turbo parts list looks as follows:
Have:
Holset Hx35 7 blade w/ 0.63 a/r hotside
T1 billet fuel rails
Injector Dynamics 1000cc top feed injectors
ACT HD pressure plate w/ 6 puck clutch disk
ACT streetlite flywheel
Uppipe and Downpipe fabricational components
To Be Purchased (subject to change)
Tial BOV
Tial 44mm EWG
Turbo oil feed and drain lines
Fuel lines
FPR with fuel pressure gauge
FMIC core (making own endtanks)
Custom intercooler piping
Make up/down pipes and rerouted EWG dump tube
A/C delete????
Custom intake
IAT and MAP sensors to run speed density
Reversed intake manifold
TGV delete
Every gasket ever
Tigwerks engine mounts
EL header (tigwerks or techworks)
Here are some pics of some parts and the process so far:
Obligatory standing in engine bay greaser photo
I can hardly wait to make more progress on her. When I get my week off here coming up I will be going hard on tearing in down and getting it fully ready for the new block.
Enjoy!!!
Beautiful car man!! Exactly the way I wan't my CGM to look hopefully later this summer
Two quick questions, where did you find the RPF1s? I can't seem to find them online also what all you do to make them fit just spacers in the front and roll in the back? It looks like your noticeably lower than other cars running the same rims...
Great build btw subscribed for sure
Sent from my SGH-M919 using Tapatalk
Epic update:
SHORTBLOCK HAS BEEN ORDERED !!! As you can tell im very excited.
On todays order list was:
-Outfront Motorsports closed deck EJ25
-Manley H-tuff rods
-CP pistons (stock compression)
-Sti crank
-King bearings
-Gates racing timing belt/pullies and water pump kit
-JE head gaskets
Should see it later next week and will be posting pics then.
Epic update:
-Manley H-tuff rods
-Sti crank
-King bearings
-JE head gaskets
Great choices on all these parts, especially the closed deck. I need more guinea pigs to test this closed deck for me before I buy it myself lol, so far everything has been positive :tup:
Nicely done.........in for updates and images.
Discussion Starter #13
I did a border run the other day and picked up a ton of shiny goodies. The short block is beautiful. I can't stop staring at the bloody thing.
Pretty soon here I will start putting this thing back together!
Hey! Didn't realize you were on here.
Will it be done for the summer so you can run sessions at Gimli?
Discussion Starter #15
haha Im everywhere! The motor will for sure be in and running this March, then the turbo and other parts really just depend on cash flow and how work goes this summer. I sure hope to have it all running my late june though!
Discussion Starter #17
i had to use 5mm spacers up front and had to grind the fender lip in the rear for them to fit with 255's
Discussion Starter #18
The countdown is on until I get to head home from northern Alberta and can begin installing my new block. Im like a little child who cant sleep on xmas eve.
Are you working in the patch right now? No wonder you can build so quick!
Still riding for NS/Lama?
Discussion Starter #20
Haha yes I am. Im up working as a geo in what I would basically consider the Arctic. Shes cold, real cold.
I actually called NS/Lama earlier this winter and told them to count me out. Don't have the time to meet their requirements anymore. However, I do ride alllllll the time still.
1 - 20 of 203 Posts
