21 - 40 of 171 Posts
Discussion Starter #24
Re: My STI
I got all season tires for the 5 spoke rims...i like the 5 spoke look a lot better...planning on using the bbs rims for autocross...
Re: My STI
Why so horrible?
Snow tires need to be narrow with a small diameter to allow them to cut through snow. You don't want a wide tire that floats over snow or requires a lot of force to plow a wider plain to get through the snow. Plus 18's will be heavy and that just requires more force to move. You want torque getting to the snow/Tarmac not being lost trying to rotate a large mass.
225 max width. That is tough to fit on an 18. Also you want the rolling diameter to be small. 16 or 17" rim is better suited.
Discussion Starter #31
Re: My STI
<a href="http://s1133.photobucket.com/albums/m586/supadupagj/?action=view&current=0313011250a.jpg" target="_blank"><img src="http://i1133.photobucket.com/albums/m586/supadupagj/0313011250a.jpg" border="0" alt="Photobucket"></a>
Discussion Starter #34
Re: My STI
Factory subwoofer goes will with the navi unit and speakers...now it sounds good!!!!:D
Discussion Starter #37
Re: My STI
you just have to try to pull off the trim.....start from opening the door and then attempt to pull it off....after you take it off.... your going to have to take time to remove the 3m tape that is going to be left behind.....and then replace the trim with the new piece
Discussion Starter #40
Re: My STI
Your going to need to buy the left and right side....they are sold individually...
