installed my handheld gps today.
went on freeway, set cruise on 60. gps read 56.1
set cruise on 65. gps read 61.1'ish
set cruise on 70. gps read 66.1'ish.
on slower speed, the diff in speed is less, like 3 MPH. like going 35, the gps would read 33.5.
hence, i believe that the tire size is 1 size smaller. will test if odometer is also affected. in previous experiences, it does. will be driving abour 70 miles tonite and will confirm...
while it's not the otherway around, ie, speedo is reading SLOWER than actual speed and hence getting a ticket, other drivers might honk or beep or flash highbeam at you for the wrong reason...
my previous experience is in my truck. where when i went to a bigger size tire, the speedo would read SLOWER. and when i went to a smaller size tire than originally, it would read FASTER. only way to fix this was when i went from 29" tires to almost 32" ones, was to re-gear the front and rear diffs (change the ring and pinion) with a diff ratio. from a 4.10 to 4.88 gears.
FYI, on my wrx, the speedo was almost dead on with the 16" OEM tires. when i went to 17" rims and 225/40 kumhos, it was slightly SMALLER so the speedo read about 1.5 MPH off...
will send something to SOA about this. i believe a recall is in order for new tires that are slightly bigger...
