^Yup just put that in my WRX, no problems at cheap at $6 a pop.
what is the torque spec in ft/lbs for the oem oil filter?I use an oil filter wrench to tighten mine... but that's because I use a torque wrench to tighten to Subaru's exact specifications. No issues yet.
8.7 ft-lbs or 2/3 - 3/4 rotation past the seal contacting the mating service.what is the torque spec in ft/lbs for the oem oil filter?
Used to always do hand tight with my bikes and cars but I prefer torquing to OEM spec if I have the service manual.I'm somewhat amused by needing torque specs for a rubber gasketed, oil lubricated mating surface. Hand tight plus a little, that's all folks.
At your next oil drain you should *just* be able to turn it off without a fight barehanded. To be honest the range of "tightness" which will still offer no mechanical problems is huge. The torque spec best serves to ensure you don't lock the thing on there playing he-man oil changer.
I totally agree.I'm somewhat amused by needing torque specs for a rubber gasketed, oil lubricated mating surface. Hand tight plus a little, that's all folks.
Same blue can? This is the first I've heard that the OEM filter has changed. Any pics?So, I got a Subaru oil filter recently, to save myself time before a trip, and noticed they have changed it again. It is better constructed than the ones they switched to from the blacks. It has a better gasket and a noticeably thicker lip around the gasket as well. I'm satisfied. Anyone else notice these changes?
No pics. I noticed right away it was different though because the lip was not rolled back. I even ask the parts guy to double check to be sure it was the right one. It is also stouter than the older one (I could flex the walls on the older one when I squeezed it). I don't know if the innards changed. I've gone through two of 'em now, no problems.Same blue can? This is the first I've heard that the OEM filter has changed. Any pics?
Just to clarify, Purolator PL14610, PL14612, L14610, and L14612 are all rated 14-18, not just the taller version. I was worried for a second.Saw this in another post and wanted to add it here, info that the 09+ mazda rx8 oil filters, tokyo roki part # N3R1-14-302, are very similar to the discontinued tokyo roki subaru "black" subaru filters, and can be used on our cars.
See: http://legacygt.com/forums/showthread.php/mazda-rx-8-tokyo-roki-oil-filter-2-5gt-147113.html
"Same diameter and threading as the Subaru filter except it's physically longer... And most importantly the relief valve is set to 20-26 psi, which is the same as Subaru."
I'd been using the longer PureOne which has a lower relief valve range (I forget exactly what but is was documented on a thread on bobtheoilguy)
Does the PureONE PL14610 (oversized), work on the 2011s?
Yes, yes, and yes. The PureONE PL14610 Oversized will fit. Subaru uses the same threads for all of their modern cars.Let me rephrase then: what oversized filter fits the 2011?
... As for the blue filters, I will NEVER run those. My mechanics at the dealership don't like them because they tend to leak at times, and thats a risk I will not take...
For < 5k OCI I'm still all about the Subie Blues. More than half the guys I see in the hobby shop tighten their filters with gorilla paws, thinking tighter is better.... not having heard from any one I trust that they leak, I still consider them best for normal intervals. ....
I'm using the Blue Subaru filters. I firmly hand tighten mine until the can body touches the filter mount base. Haven't had any instance of leaking.... I'm using the blues too. So maybe some people just need to learn to tighten their filter appropriately.
Sorry to bump this old thread, but that NASIOC thread is hard to read. Uncle Scotty is a friggin idiot that thinks he knows everything. He makes blanket statements with no data to backup his words. I have worked in the petroleum chemical industry, and seen a lot of testing with oils/filters. That guy is really passing along a lot of misinformation. This reminds me why I hate NASIOC and never visit the site anymore.Sorry to revive this thread but I thought I should add something about the concern on the relief pressure non Subaru Blue OEM filters like PureONE, Bosch, K&N, etc.
I found this post on NASIOC when I did my filter research and I tend to agree with what Nicklz has to say about this:
" I should have said technically only the blue can (Subaru OEM Blue) BUT the pureone filter has the same relief valve found in the correct part# for the wrx 2.5 and 2.0 motors but the PL14610 (honda filter) has a larger filter media. (bigger can) So you have more filter media, which lowers the effective pressure needed for the relief valve."
ref: NASIOC - View Single Post - What oil filter are you running?
