1 - 20 of 22 Posts
Found this off mauromotorsports.com & another website that had posted as well. I just thought I'd share this:
_____________________________________
This might help answer some Questions:
Below is a list of parts that ARE and ARE NOT compatible with the 2004 WRX/STI.
Do Not Fit
Five-speed WRX shift knobs
Five-speed short shifters
TurboXS UTEC (coming soon, though!)
All non-STi WRX brake parts
Cusco front strut bar
02-03 Body Kits
02-03 Springs will not fit in the rear without 02-03 Strut tops
Will Fit
All turbo-back, cat-back, and axle-back exhausts
All up pipes
All headers
All interior parts EXCEPT shift knobs and short shifters
All wheels
All intakes
All badging and emblems (except for side markers)
All blow-off valves and bypass valves
All rear strut bars
Wheels that fit the STi
17” wheels (sizes, offsets, weights):
Rage Breaker = 17x7_ET42
5Zigen FN01R-C = 17x8_ET48__(16 lbs)
Enkei CDR9 = 17x7_ET40
Enkei ES-Tarmac = 17x8.5_ET48__(16 lbs)
Enkei ES-Tarmac = 17x9_ET50_(16 lbs)
Enkei RS5 = 17x7_ET40__(19.8 lbs)
Enkei RPF-1 = 17x8_ET45__(15.5 lbs)
Volk SE37K = 17x8_ET44
Volk TE37 = 17x8_ET44
Volk CE28N = 17x7.5_ET33__(13.8 lbs)
Volk CE28N = 17x8__ET38 & ET44
Volk CE28N = 17x8.5_ET40 & ET44
Volk CE28N = 17x9_ET43__(14.8 lbs)
Gram Lights 57S = 17x7.5_ET48
Gram Lights 57C = 17x7.5_ET48__(16.8 lbs)
Gram Lights 57F = 17x7.5_ET48__(13.7 lbs)
Gram Lights 57PRO = 17x7_ET40__(18.4 lbs)
Gram Lights 57PRO = 17x8_ET40
STi RS-ZERO by Rays= 17x8_ET40
ASA KA3 = 17x7.5_ET48__(23.4 lbs)
Advan RG = 17x8.5_ET43__(16.5 lbs)
Advan TCII = 17x8.5_ET45
OEM JDM STi = 17x7.5_ET53
Rota Tarmac II = 17x7.5_ET48
Rota SDR = 17x7.5_ET48__(18 lbs)
Compomotive TH3 = 17x7.5_ET53__(22 lbs)
WedSports RS-5SS-TSSC = 17x7.5_ET48__(15.6 lbs)
SSR Competition = 17X8.5_ET48__(15.3 lbs)
SSR GT7 = 17X7.5_ET48
18” wheels (sizes, offsets, weights):
Crimson K6 = 18x8_ET46__(20.8 lbs)
Black Racing Pro N1 = 18x8_ET45
Advan RCII = 18x8.5_ET45
Prodrive Special Edition P1=18x7.5_ET46_21 lbs)
Prodrive GC-010 = 18x8_ET43
Prodrive GC-06 = 18x8_ET43
Prodrive GC-07 = 18x8_ET43
Volk CE28N = 18x7.5_ET33
Volk CE28N = 18x8_ET38 & ET44
Volk LE37T = 18x8.5_ET40
Volk TE37 = 18x7.5_ET43__(17 lbs)
Work Emotion CR KAI = 18x7.5_ET42
Work Emotion Forged = 18x7.5_ET42__(17.4 lbs)
STi RS-ZERO by Rays = 18x7.5_ET53
SSR Competition = 18X8.5_ET48
SSR GT7 = 18X8_ET48
Over at Nasioc, a vendor is offering the Prodrive GC-06s but in 17x7.5 +48mm offset, 5x100.
They weigh around 16.5lbs each according to Prodrive USA.
retired mod
i think they maybe referring to those ones that were right up the front on the bug eye model, know what i mean? just behind the headlight?
7.5 is too small for STi. We use LE28N's in 18X8.5 +44 here. Perfect fit. I think those needto be added to the above list.
Nice list. I thought it was going to be like "do not jump more than a foot off the ground" or "sledge hammers and your STi don't mix well." I guess this is even better though... Thanks!
RN
You can add Rota Battles 17x7.5 48mm offset to your list of wheels that fit had a set they have more clearance than the BBS I sold them to another STI owner to use for track wheels.
Discussion Starter #12
... Thats good to hear cuz I am getting the same wheels (Volks) installed on Tuesday. :p
i think guru meant that bigger is better...i've heard that in the handling section as well,in relation to how the evo handles etc...
not tooooo big =) i dont want to see an sti sitting on 24's becasue if that ever happens that guy deserves to be shot and keys taken away from him!!!!!
I am pretty sure that the 18inch oz rally superlegras(or however you spell it) fit.
although i'd do the same thing as well... I think they mean bigger is better, by WIDER tires, not running 20s or something. But like 18x8.5 vs 17x7.5. Wider = more tire = more grip/better handling/better traction/better braking, etc...
Cusco front strut bar fit on my STi,,,,slight relocation of AC lines. I also wrapped the AC lines in foam just in case.
Rudy
Unless I find some really lightweight 18 inch wheels (no more than 17lbs) I would do them.
1 - 20 of 22 Posts
