Where did you get your smoke tester? Some of these smoke testers can go up to 100 PSI? I heard if you shoot high pressure through smaller lines it can damage them and other components.Neither. You do it with the car off and see if smoke is escaping from anywhere. I put mine in the turbo inlet just past the MAF so all the connections and potential leak points are tested.
