1 - 6 of 6 Posts
With all the torque that the Impreza puts out it is easy to start out in 2nd gear from a stand still. Is this bad on the tranny?
I've started in 2nd a time or two. 1st gear is sorta short, but I'd advise starting in 1st, at least till you're moving. I don't believe slipping the clutch to get it going in 2nd would prove too "kind" to your tranny over time. My .02
Yes, you have to slip the clutch more, and harder, to get it moving in a higher gear.
It can be done, and its no big deal once in a while, but on a regular basis, it's not a good idea.
An STi isn't geared like my old Chevy 3/4 ton pick up. Unburdened I always started in second. First on that beast was a granny gear and un-synchronized. First was very useful with a car on the trailer grossed out at 10,000 lb...
With my STi I start in first and jump to a high gear when at speed.
they put first there for a reason...
in the owners manual for the it states that you can start in 2nd gear in the snow for better traction. i've thought about this a little and all i can figure is that you don't get as much torque multiplication so you'll have less tire spin in the snow and ice. on occasion i have accidentally taken off in second. no harm done just takes a bit more gas. but yes, i do usually start in 1st.
1 - 6 of 6 Posts
