1 - 6 of 6 Posts
I recently got tuned by a local tuner and i recently have had some issues with stalling. Before i went and got the dyno tune done I put in a JDM Long runner manifold and never had issues, now after the tune i sometimes have my car stall out. It will come to a stop and be at around 1k RPM's and then it will stall out. (This is while on 93o, will change over to e85 when tank gets empty)
UPDATE: I did a boost/vac leak yesterday and found a vac line had come unplugged, hooked it back up and now my idling problems are gone but still stalling sometimes.
UPDATE2: I am starting to wonder if I need to change out my spark plugs, im using the one step colder plugs but i switch between e85 and 93o (currently on 93o) so could this be the problem. The plugs have about 1200 miles on them since the fresh build.
Wondering if this could be a fueling issue or spark plugs? I am rueling out the possiblilty of the 02 sensor since i had just put in a new one less than 500mi ago.
Re: Idle/surge problems (now with Video)
Problem solved! Ended up having a vacuum line (boost port) had blown off. Idles better now but sometimes stalls ����
do you have the stock bpv on the car still? if you have an aftermarket bov thats in full VTA then that will happen sometimes, maybe your tuner over looked it or something. Happened to me.
Report on the plugs...Make sure the gap is copacetic too, not sure what power your putting down but for my 21psi 25-28gap seems to work nice...People tend to run much smaller with e85 because of the extra power. And unless your motor is seeing full boost for long periods of time then I'd put the stock heat range plugs back in. The colder ones need to get hotter to start cleaning themselves. They will never get hot enough unless you make it hot enough by flooring it constantly. I go WOT all the time but still not enough for me to get them, they just foul up quicker.
I'd clean the maf if you still have one, reset the ecu, and check for more leaks.
Take some logs and send them to the tuner. Might just need a fuel adjustment to catch it for idle. Mine stalled out on me today rolling to a light, but it was still relearning its idle after an ecu reset and it just wasn't enough fuel there to catch it. Widebands come in handy
1 - 6 of 6 Posts
