1 - 3 of 3 Posts
I've decided that my aftermarket uppipe has to be replaced because no matter what it just will not stop leaking.
The only uppipes that are already fabbed up for an external wastegate that I've seen are the Ultimate Racing and Element Tuning uppipes.
Are there any others that are already setup for an EWG?
I already have one of these and the other one is very expensive for just the uppipe, so I think I'm just going to try to find an aftermarket uppipe that is catless, stainless steel, and possibly with a flex section so that I can have a local shop weld on the extension for the EWG.
What I need to know is which uppipe will fit perfectly, just like the OEM one does?
PS: this will be using the stock manifold
Inertia said:
Cobb has an up thats probably as high a quality as your going to find and you can even get the exotic inconel one if you feel froggy.
http://cobbtuning.com/sti/power-i.html#uppipe
Yes, I was checking those out.
I'm kind of leaning towards something with a flex section though..
Does anyone have any experience with the APS uppipe?
1 - 3 of 3 Posts
