1 - 5 of 5 Posts
Re: sti an everyday car?
OK, trying to decide how much to mod my exhaust (price vs hp gain). The following are also in order of what I would likely do. All else being equal, see if you can fill in the missings numbers:
stock DP + stock Cat Back + stock muffler = 300 hp (just for reference)
stock DP + stock Cat Back + high flow muffler = A
modded DP + stock Cat Back + stock muffler = B
modded DP + stock Cat Back + high flow muffler = C
mod DP + mod cat back + stock muffler = D
mod DP + mod cat back + high flow muffler = E
Any takers?
Discussion Starter · #2 ·
ecu update...
OK, since no one wants to venture a guess, I'll post a reply to my own posting. Here is what I think given 300hp stock:
A= 305hp
B= 320
C= 325
D= 335
E= 345
The max HP gain that I have seen {dynos online} has been approx 30 HP. This is with with an after market turboback catless high flowing {loud} muffler. I think the range would fall between A. 305 and E. 330.
I believe that 30 hp gain was at the wheels. Hayasa's looking at flywheel hp (300 stock), in which case we might very well see 345 or more hp with a turbo-back.
I know there has been a discussion of whether or not the driveline loss percentage changes as hp increases, so this may or may not be a simplistic argument...
ya I think you're right chobos... because if you're losing 10% hp or more to the wheels 10% is 30 of 300 and 100 of 1000, so it'd vary as you got higher in the hp range. We'd need an actual dyno of these tests. APS seemed to have a good review on different products, but nothing like each exhaust piece broken down. Good luck and I will try searching as well.
1 - 5 of 5 Posts
