1 - 7 of 7 Posts
Im runnng the run of the mill ver110 91oct map. Should I be ussing something else? I will be getting protuneed when I get my dp but im wondering if I have anything to worry about untill then. Im hitting 17.1 max in 6th, 16.7 in 5th, <16psi 3-4.
Thanks,
Steve
there's no other map that you should be running. I remember hearing thats the aps inlet isn't great to run untuned, but i could be wrong. i would just get protuned as soon as you can.
Discussion Starter · #4 ·
Uh oh. I figured since the MAF sensor stays in the stock box everything would be fine? Now im scared.
I emailed cobb concerning their cali map and the agressiveness of it. Heres what Justin said.
"Steve,
The California mapping is actually less aggressive. This is because of
the fuel that is currently available in the area. Its much safer to run
the cars with the California mapping there."
I'm running the basemap with the Typhoon and hitting the same target boost as you're. Car feels great to me, but I'm getting it Pro-Tuned on Tuesday by Mike to make sure everything is good.
When is your Pro-Tune session?
^I dont have one scheduled yet. I still dont have the TBE. The typhoon and turbo inlet are a little different.
1 - 7 of 7 Posts
