41 - 60 of 487 Posts
Discussion Starter #41
Re: S'poreSTI Redux - 08 WRB/Gold. Now Stage 1.
you installed the rad cap incorrectly.
look at the two oem rad caps, the one on the rad is rated at 137Kpa and the one near the intercooler is rated at 108Kpa.
if you install the 1.3bar or 130Kpa rad cap on the radiator, the rad cap near the intercooler will release the coolent at 108Kpa. making the new cap useless.
now if you install the 1.3bar or 130Kpa rad cap near the intercooler, it will release coolent at 130Kpa, and the OEM rad cap near the rad, will release at 137Kpa, if the STI rad cap was to fail to open.
Good catch, man. Nice to know someone looking at that level of detail:tup:
But i gotta admit, my reasoning for getting the cap was pure bling.:p I figured swapping the front was virtually the same pressure trip point, (7kPa less), and the stocker on the manifold tank would handle any over-temp/boiling issues, tripping at 108.
Any flaws in my reasoning, or any potential danger doing it that way, do give me a shout. much appreciated:tup:
i would advice for the use of the 1.3 bar rad cap, and the 1.37bar stocker.
reasoning: as the coolent heats up, lets say due to high engine load, or high rpms. the temp will rise in the coolent, and if the recirculating coolent cannot keep up, then the pressure will vent extra fluid at 1.08bar. then the temp guage will rise, and overheat if the load/rpm is not reduced.
now if the coolent will vent off at 1.3bar, the higher pressure will have a greater capacity to hold heat, thus, more heat can be transfered to the rad. its basic thermodynamics, the greater the pressure, the more heat that can be held within the coolent. with more heat in the coolent, the higher the temperature, which will lead to a higher temperature gradient between the air flowing through the rad, and coolent. so, the greater the temperature gradient, the greater the heat mass transfer to the air going through the rad.
basically, under heavy load or rpm, for extensive time, the tranfer of heat from the motor to the rad will be more effective at higher pressures.
with the stock rad cap, which is placed on the rad of 1.37bar, the system is obvously engineered to be capable of operating at that pressure. so why not switch it, such that both the 1.37bar and 1.3bar rad cap are used. it doesnt cost anything more, and will make the cooling system more effective when higher loads are placed on the engine.
Discussion Starter #43 (Edited)
A busy couple of days, got the front bumper off the car and took care of a few things
Switched out the foglight bulbs, turn signal bulbs, disconnected the DRL's, and took out the intake silencer. Afterwards i did notice quite a bit more sound, especially when giving it a boot when it 3rd at ~40mph, a real strong growl from ~3k to 4.5k.
But the main reason for removal was to 'de-civic' the grille, got that done and ended up making it into a 'semi-sport' grille, by dremmeling out some additional air holes to feed into the snorkle. Got the idea when removing the grill i saw the bumper cover has some holes pre-cut in front of the snorkle
Continued in next post
Discussion Starter #44 (Edited)
Grille strip was painted as per instructions in another post
http://www.iwsti.com/forums/1856497-post66.html
To create some air slots i covered the side in painters tape and sketched out 4 slots, then used a dremel to carve out the plastic
Finished the slots by sanding with the dremel, then hand finishing with 400grit emery paper
Installed::D
That flat black grill looks perfect! I also like your intake air slot mod. From the pictures it looks like you really took your time and cut it out really nice. :tup:
Discussion Starter #47
Thanks for the props guys.:)
the most time consuming part was sketching out the slots on the tape, the grille is slightly curved,and it tapers, so the outer slot is ~10mm wide, the inner is ~12mm, and they kind of flow together. it wasnt as simple as just drawing a straight line, i made ~ 10 measurements to keep the bottom & the top of the slot at ~3mm from the edge of the plastic. Rounded corners simply made by drawing round a socket.
After getting that done it was simple a matter of patient dremel work, used a cutting wheel to do the edges, and a cutting bit to get the corners, then finished up with a sanding wheel & hand finish. all in all it took ~2hours, but i think it was worth it.
dude!!! im gonna have to bite your idea on the grill~ that is some real nice work you did there! how many clips are there to remove the front bumper? im getting my fog lights this week and gonna be doing a mod day real soon!
Discussion Starter #49 (Edited)
I ended up removing 4 from the edge of each wheel well, and 4 underneath. I think it was a bit different from the stock bumper because of my front lip, others reported 3 at the wheel & 6 underneath IIRC.
Finally, there are the 4 on top of the grill that need removal.
There is a foglight install manual available on techinfo.subaru.com if you want to read up in advance
Getting the clips out is the easy bit, they are really obvious which ones to remove. The hard bit for me was then getting the bumper to move, its kind of locked into place with some press-fit device that runs from under the headlight round and up the front wing. The bumper kind of locks into that, and removing it for me needed a good hard pull, with resulting noises of breaking plastic as the clips broke free. No damage done at all, but the first time it sounded bad, like i'd f'ed something up. Dont be afraid of it, just pull on the bumper, it should flex and come free.
^^^ sweet!! thanks for getting back to me so quickly! i let youe know when all this crap is done~ its gonna be a whole days of modding ! :D
More grille pics! Close that hood!
Looks good. I want to either do that or get the sport grille. There is the issue that you are then left with the awkward amount of silver trim around the fogs....I gotta figure something out there.
Discussion Starter #52 (Edited)
Thanks Mikael!
Yeah, i'm thinking to take a look at the fog surrounds next, matte black would tone them down nicely. Depends if they can be dismantled easily or not, but so far everything cosmetic on this car seems easy to pull apart:lol:
A few more pics i took, as requested:)...
lookin good man... pretty creative idea you got there with the grill...
Discussion Starter #54 (Edited)
Finished the cosmetic mods on the front today, took off the foglight surrounds and painted the silver parts flat black, same as the grill stripe above. The covers dont dismantle, the silver seems to be molded in somehow, so no choice but to mask them up for painting. Pretty straightforward stuff...
After installing i took some shots indoor & outside, looks pretty good IMO...
good work M~~! that looks f'ing sweet!!! i've still not had the chance to install my parts cuz my friend who was gonna help me has been busy... :( the good thing is that my fogs are not installed yet so i can paint them before the install ~!
very well done with the fog lights, I would have gone a bit lighter black on the grille and darker for the tails but best blue 08 STI overall I've seen
Discussion Starter #57
Thanks, man:tup: appreciate it
If you saw it now you'd be less impressed, ive been too busy to wash it for the last 3 weeks:p. The BBS are just nasty, and the paint is covered in haze from all the smoke in the air here. Its almost as bad as the Mondeo gets back in Shanghai:lol:
What do you think about removing that front STI logo on the grill?It might look good....
Discussion Starter #59
I dunno, i never thought about that. I'm pretty sure i'm sticking with the logo though, to me it looks good. :)
Discussion Starter #60
Intercooler to Throttle Body hose finally installed...
