1 - 20 of 487 Posts
Baseline (Stg1) Dyno plots in Post #155
Stg2 + E85 Dyno plots in Post #210
Mods:
Exterior:
STI front lip & skirt - Installed, pics in post#2
Debadge - Post#7
IWSTI licence plates - Post #16
LED coolwhite licence plate lamps (superbrightleds)
Laminex Gunsmoke Rear light tint kit - Post #17
Red STI painted on intercooler - Post #37
Silverstar front turn bulbs, DRL Disable. - Post #43
Grille mods; painted 'civic strip' flat black, added snorkle air holes to stock grille (ghetto sports grille:tup::lol:) - Post #44
Foglight Surrounds painted flat black to match grill - Post #54
VisualGarage Sharkfin Antenna fitted - Post #106
R205 fender badges fitted - Post #138
R205 rear underspoiler fitted - Post #144
Flexfuel badge - Post #218
Liberal LED Reflectors - Post #243
Seibon CW Carbon Hood, Painted - Posts #301-309
Rear end collision & repairs - Post #344-352
JDM Multicoated Fogs & Prolightz DRL harness - Post#391-399
California Black Vanity Plates - Post#443
Interior:
Subaru (PIAA) LED Dome light - Post#35
LED coolwhite map lights & trunk light.
JDM 2Din AV panel - 'in stock' in case needed later...
JDM Subaru Boost Gauge and Oil Temp Gauge - Post #63
JDM STI Shiftknob - Post #143
Valentine V1 hardwired with Blendmount kit - Post #156
Pioneer AVIC X920BT - Post #157-8
Clustermaker gaugepod - Post #190ish
Canadian Floormats - Post #205
:DGTSpec wheel - Post #244, installed Post #246
Maddad Ultra white needle Oil Pressure & EGT Gauges installed - Post #283
Blackvue DR500 - Post #299
COBB AP v3 mounted - Post #315/317
Better Trunk Insulation - Post #402
Subaru Trunk Cover - Post#436
Recaro Sportster CS with airbag & heater wiring- Post #413-423
:DRecaro Sportster CS with airbag, custom JPM upholstery - Post #440-447
:DGTSpec wheel with custom JPM re-skin- Post #445
Engine:
STI 1.3bar Radiator Cap - Post#34
STI 46mm Red Intercooler to Throttle Body hose, - Post#34, installed Post #60
COBB AP - Stg1 on 5/23/08 - Post #38
Intake silencer removal - Post #43
Subaru's Engine Reflash done - couldnt tell any difference:lol:
Spec-C IC Spray kit installed - Post #139
SPT Catback installed - Post #142
AEM CAI - Post #161, #165
Stg1 Protuned - Post #166
DW 850cc Injectors, 300lphFuel Pump & HOA boost solenoid - Post #206
(pump changed to Aeromotive 340lph due to breakage during install)
COBB catted DP, Swaintech coated - Post #208
:DStage2 + E85 Protune - Post #210
Removed Air pump & ancillaries - Post #222
Perrin Radiator Shroud - Post #234
Shorai 5lb LiFeOH battery & STI 'strutbar' tie-down - Post #273
3ft fuel line addition, stumble fix - Post #282, Improved Post#319
STI Oil Filler Cap - Post #298
STI 52mm Red Intercooler to Throttle Body hose, - Post#318
Stock Catback re-installed - Post #411
Cobb Flexfuel kit installed & EQ retuned - Post#460-5
Suspension & Handling:
STI JDM Flexible Strutbrace- Post#79, installed Post#80
:DSTI JDM Pink Springs, - Post#79, install Post #84-5
Whiteline Rear Subframe, Diff, Steering rack bushings - Post #114 - Installed Post #124
Whiteline RSB brace kit (painted red to match Perrin RSB) - Post#118 - Installed Post #124
Perrin 19mm RSB - Post #118 - Installed Post #124
STI Front brace kit - Post #154 - Installed Post#200
Perrin 22mm FSB - Post #200
GrpN Engine Mounts, Pitchstop, Trans mounts - Post#200
Cusco H brace - Post #252 & installed #253
Group N powersteering cooler - Post #280 to 282
:D2015 STI 13:1 ratio steering rack - Post #371/379
Brakes:
Harman Motive SS Brake Lines - Post#102, Installed Post#103
ATE Superblue Fluid, Post #102
:DCarbotech XP8 pads front & rear - Post #223
Girodisc 2pc Front Rotors - Post #223
Carbotech Bobcats for street use, keep XP8 for the track
Girodisc Ti Shims - Post #253
Quantum Motorsports brake duct plates - Post #254, Installed #270
500F hose installed to homemade inlet ducts - Post #272
BBS Wheels & Bridgestone Tires:
Perrin 15mm Spacers & extended wheel studs - Post #358
RE01-R's on 18" Gold BBS, 245/40 18 Changed- Post#483
Blizzak ws70's on 17" GoldBBS, 225/50 17 - Post #356/369
RE970 AS on 18" GoldBBS, 245/40 18 - Post #341/369/382
RE71-R's on 18" White BBS, 245/40 18 - Post#483
Re: S'poreSTI Redux - 08 WRB/Gold
Post 2 for the Car pics....
Collection
Lip Installed...
Drive Home...
Laminex Gunsmoke Rear light tint kit - received
that's a pretty dark tint! :) i've got their "headlight" tint on the tails
did you get the bulk film, or the pre-cut ones ?
anyway, looking forward to seeing more pics with everything installed!
oh, where are you getting your windows tined, that's one of the things that i still need to get done asap.
J.
J.
On the website it said gunsmoke allowed 90% of light thru, seemed to be the lightest smoke available for the pre-cut kits? We'll see how it looks soon, the package i thought was my tails turned out to be something else, not car related. should be here any day now
The window tint's getting done (is already done) over in Santa Cruz, somewhere. I didnt go into too much detail with the dealer, i'll ask the name of the shop tomorrow when i get the car:D. I already got my 1-way car rental setup so i can go get it tomorrow. Didnt feel like carrying a V-limited lip on the VTA light rail & bus:lol:
FWIW; here's a comparison, tint vs. smoke
J.
Discussion Starter #8 (Edited)
Re: S'poreSTI Redux - 08 WRB/Gold. Woot! for collection & pics
The dealer told me newly shipped STI's have more rear fender protection, there is now film on both the door and the wheel arch behind the door, which wraps the edge where folks were reporting a lot of chips. This pic tries to show that...
but still nothing above the rocker panel...
Discussion Starter #9
J.
Dang, where is my package, i can't wait to see what the hell i ordered for the tails :lol:
Beautiful!
The lip really looks good on your car! However I'm a bit sad hearing the extra work needed to get the skirt on the car :(
Looking at your pics though, I think the work is well worth doing ^.^
Discussion Starter #12
Beautiful!
Yeah,as you can probably tell from the pics i bailed on the DIY, got the dealer to install it when picking up the car, it was worth the ~$50 it cost.:)
Discussion Starter #14
nice 08! Make your tails look like this
I was thinking that way, but then i saw JPH's tinted tails and they looked great, even better than red. I have some tint overlays ordered, should be here very soon.
When i showed the pics to my wife, first she complained the 08 didnt look like my old 05 (no huge wing, no huge hoodscoop). then she said she loved the rear lights. Women! So i might have to keep them stock:lol:
that's funny ;)
J.
Discussion Starter #16 (Edited)
Re: S'poreSTI Redux - 08 WRB/Gold. Now with smoked tails
Pic before the taillight tint - rocking the iwsti.com plate frame
Discussion Starter #17 (Edited)
Laminex gunsmoke pre-cut tail overlays - installed by Juan @ Tints R Us. Well worth the $30 to get his 17 years of experience on the install:tup:. he's available at 408 971 7009
The gunsmoke tint is really awesome, not dark at all, but it tones down the gaudy stock lights. Finally i'm happy with the exterior look.:D
Very subtle difference, maybe a little darker would be better. But if you like it that's all that counts, I'm going with red overlays. Nice work. :tup:
looks great!
i guess it does makes a difference on how light or chrome looking your tails are.
the gunsmoke was too dark on my mx-5 :)
J.
1 - 20 of 487 Posts
