1 - 1 of 1 Posts
$150 a pair + shipping from New York
Package dimension and weight: 23" x 4" x 4.5" 8.8lb.
Used, in good condition. No damage, just normal wear and tear, no rust. Bushing is in great shape, no cracks. Sold my 2015 Sti so I'm parting things out. The arms had about 10K milage on them.
A must if you're lowing the ride. This hi-strength adjustable lower rear camber arm provides +/- 2.0 degree of change.Get the ultimate in performance and handling with this stamped arm featuring our new xAxis(TM) Sealed Flex Joint which performs like a pillow joint but lasts like an OE joint. This kit is easy to adjust with a cam located at the outboard end of the arm. SPC's control arm is the only kit on the market to include an offset toe bushing to increase the range of your factory toe cam.
According to Subi Speed this part fit:
  • 2015-2017 Subaru STI SPC Adjustable Lower Control Arms (Rear) w/ Toe Kit
  • 2015-2017 Subaru WRX SPC Adjustable Lower Control Arms (Rear) w/ Toe Kit
  • 2015-2020 STI SPC Adjustable Lower Control Arms (Rear) w/ Toe Kit
  • 2015-2020 WRX SPC Adjustable Lower Control Arms (Rear) w/ Toe Kit
  • 2013+ Subaru BRZ SPC Adjustable Lower Control Arms (Rear) w/ Toe Kit
59294
59295
59296
59297
59298
1 - 1 of 1 Posts
