1 - 6 of 6 Posts
Vendor
We are proud to offer you guys a Special price on Sparco Seats, Harnesses, Harness bars, Steering Wheels, and accessories.
If you call in to order the seats, an additional 5% discount will be given when ordering all the hardware and brackets required for one seat. When ordering 2 seats and the hardware with brackets, an additional 10% will be given!
Sparco Roadster 2 Seat 629.00
An evolution of our world famous competition seats, this seat is designed for highway use (not recommended for competition purposes) and designed for use in high performance sports cars. The special shape provides maximum lateral support and the bolsters still allow for ease of entry. The shell is constructed of fiberglass and is covered in high quality Jacquard material assuring a long life as well as good looks.
Performance Seats:
Features -
Dual Density Foam : Ultra high-density foam surrounds the seat's shell to reduce the amount of vibration transfer into your body. The decrease in vibration transfer helps to battle driver fatigue allowing you to maintain focus and concentrate on driving.
Abrasion Resistance : Perforated abrasion resistant inserts are strategically placed to protect the seat against excessive wear in high wear areas
Restoration System : A high-tension spring and wire system have been used to secure the cover of the seat to the shell. This cover can be removed by unfastening the spring located under the seat shell. This system will allow you to easily clean the seat cover and restore it to a show quality condition. This feature will also allow you to replace your seat cover after many years of use giving you a brand new seat without having to purchase the entire shell.
Sparco Fighter Seat 549.00
The Fighter seat was designed to give the extreme support of one of our competition seats with ease of installation found in our street performance seats. The Fighter incorporates perforated abrasion resistant inserts to protect against excessive wear and also features a high-tension spring-and-wire system to secure the cover to the shell. This system will allow you to easily remove and clean the seat cover, restoring it show quality condition. Also included are a pair of the Sparco dual-density lumbar pads that enable you to customize the seat to fit your specific body type.
Sparco Milano Seat 989.00
One of the most advanced adjustable sport seats ever manufactured by Sparco. The back rest can be reclined to the millimeter and features the exclusive QTS (quick tilt system) technology for rapid return to the upright position. It also features a revolutionary contoured injection molded memory foam and Touring car inspired g-force absorbing side bolsters. Another noteworthy feature is the lumbar adjustment system that ensures proper ergonomics and ultimate comfort in all driving conditions.
Features
Lateral Support : Lateral side bolsters keep the driver in the optimum seating position at all times which is especially vital when cornering at high speeds. The side bolsters keep your body in an upright driving position helping to fight driver fatigue.
Lumbar Support : An integrated internal lumbar adjustment system ensures proper ergonomics and ultimate comfort at all times.
Micro Adjust : The micro-fine recline mechanism can be adjusted to the millimeter to guarantee the perfect seating position. Extensive research and development has been performed by Sparco Master Certified Safety Engineers to insure that the strength and integrity of the Micro Adjust Mechanism exceeds our strict homologation standards.
Memory Foam : As body heat transfers into the high-density injection molded memory foam, the seat contours to your body.
Sparco Monza Seat
699.00
For over 25 years Sparco engineers have made safety their number one priority. Their highly experienced research and development teams are constantly searching for new technologies and evolving their products from the feedback of professional racing drivers, car manufacturers and automotive enthusiasts. Continuing with Sparco's longstanding tradition of passion, performance and safety Sparco is proud to debut the next standard in high performance seating.
TUV Homologated
Tested and Approved to ECE 17 (Europe) and FMVSS 208 (USA)
Competition Seats:
Sparco Circuit Seat 799.00
Truly the ultimate competition seat. Developed in collaboration with the top racing teams in the world, the unique design of the Circuit offers the driver the ultimate in comfort, control and protection. With key features such as the integrated impact-absorbing head restraint system and unparalleled lateral support, the Circuit is fast on its way to becoming the most widely used seat in road and rally racing. Other features include fire retardant covers with anti-slip fabric in the shoulder and seat areas, pre-formed thigh support to keep legs in the optimum position and special shock absorbing material in the head and side areas.
Sparco Corsa Seat 729.00
Designed in conjunction with the top World Rally Championship drivers, this competition seat offers maximum lateral support. Its unique design will provide the most demanding of drivers with the ultimate in safety and performance. Side mounting only.
FIA homologated
Sparco EVO Seat 699.00
Evolved from the Rev seat, designed and developed in co-operation with the most prestigious Sparco drivers of the DTM and ITC Championships. Designed specially for a free driving position, even in extreme competition conditions. The special shape of the shell and the new construction technology which sandwiches carbon-kevlar-carbon, have given increased rigidity for excellent driving sensibility (while keeping the weight extremely low). Films of homologation crash tests confirm the Evo?s first place in the rigidity/resistance ratio.
Cushions and back can be customized in various colors.
Back and cushions can be removed to customize the back rest, height of the leg rest and the cushion padding.
FIA homologated
Sparco Pro2000 Seat Fiberglass 729.00
Sparco Pro2000 Seat Carbon Fiber 1799.00
Winner in its debut during the 1995 season, the Pro 2000 won the British Touring Car Championship with John Cleland and Vauxhall. The shell is available in fiberglass or carbon fiber and is extremely light-weight but rigid enough to stand up to any test. Other key features include excellent lateral grip on the whole body, and special adjustable lateral lumbar supports.
Steering Wheels:
Prodrive Competition Steering Wheel Black Suede 309.00
This Prodrive steering wheel is made by Sparco and is very high quality. These are extremely rare and very hard to obtain. Will directly bolt onto a Sparco Bolt Pattern Hub.
Sparco Mugello Steering Wheel 279.00
330mm/ Dish 35mm
Will require the use if a hub adapter
We also Stock many other Steering Wheels, As well as gloves, Shoes, And harnesses!
If you guys have a request for a specific Sparco or Prodrive: Seat, Steering Wheel, or Accessories pleas PM, Email, Or call in!
Thanks
Kirill
RallySportDirect.com
801-748-4910 ext 1006
[email protected]
Is that 330mm??? No red stiching on the inside?
Vendor
Discussion Starter #6
Its a 330 with out red stitching. We have it in stock. So let me know.
Thanks
Kirill
1 - 6 of 6 Posts
