I'll do you all a favor.
Even though I don't own a Subaru, I really like their cars. One of my closest friends is a Suby tech at one of the largest Suby dealerships in NC. He has the 00 impreza and just can't seem to find the time to put the JDM WRX (ej something something something) motor in it.
They had this guy bring in a WRX that had engine codes indicating cylinder misfire on two of 2 and 4. He had done some mods, like a turbo timer, yet because of his adamat bickering, they decided the would cover his motor under warantee.
A whole new block came in, and all the appropriate peices from his old motor were taken off and put back on his new block. When my friend took the car for a test drive, it still ran a little rough at idle. A bit concerned (mechanics get paid ALOT less for warantee work) he opend in the trunk of the car to do some investigating. What did he find? Four nice neat screw holes.....the type you'd drill to mount a bottle.
He showed the holes to the subaru master tech who made a phone call, then told him to remove the ecu. The sent the ecu away.
Basically, your ecu keeps a basic record of what your car does. Essentially, if your stupid and put nitrous on a turbo car (instead of turning up the boost) subaru can find out about it.
Big Fuji is watching you.
BTW, if your check enine light flickers while you're at max boost.....it means you're destroying your pre-cat.
