1 - 13 of 13 Posts
BUYER PAYS FOR SHIPPING unless otherwise stated. The prices listed are PICKED UP prices. Located: 92886
Most of the following parts are for 02-07wrx/sti, the 08+parts will be listed on the bottom.
Oem Parts
- 07 Sti Longblock w/ Built Shortblock w/ accessories, manley, acl, etc: $3800
- 07 Sti Transmission By itself: $2900
- Oem Sti bpv w/o elbow Crushed top to hold more boost: SOLD
- Oem 07 sti Intake filter, etc.:$10
- 02-05 wrx Intake manifold Wiring:$100
- Mid 07+ sti Intake manifold Wiring w/ one chipped plug but useable!:$120
- Oem maf sensor for 02-07wrx/sti:$50
- Oem map sensor for 02-05wrx or 04-06 sti: $40
- Idle Air Control Valve: $80
- TPS Sensor: $25
- Oem Metal Coolant Reservoir: $50
- Oem Turbo Inlet for 06/07wrx/04+sti: $35
- Oem 02-05 wrx Throttle body bare: $50
- Oem 02-05 wrx Intake manifold: $70
- Oem TGV bare Sets for 02-07wrx and have some 04-06sti: $80
- 07 Sti Starter: sold
- 07 Sti ABS Pump w/ some hardlines: $100
- Oem Fuel Rails w/ lines:$30
- Oem FPR: $20
- OEM Secondary air pumps complete!: $150
- 07 Sti Clutch Slave Cylinder: $30
- 07 Sti AC Condenser with lines: $160
- oem Sti Dark blue top feed injectors set: $190
- oem Sti Yellow Sidefeed injectors set: $160
AFTERMARKET PARTS!
- HYDRA EMS off 04sti, just missing serial cable, comes with cut wb o2 sensor: $600
- Perrin Rotated up and downpipe for EFR Turbo Kits: $650
- 02-07 Cobb catless Downpipe a bit beat up: $220
- High quality Catback 2 piece downpipe, forgot which shop made it, used to pass smog: $220
- Alta Rotated Turbo inlet (4'' inlet, 3'' outlet): $120
- Custom Rotated Intake: $100
- Greddy and AP Knockoff bovs: $40
- Turbosmart bov for Fmic setups w/ 1'' fittings: $100
- Turbo Xs Bov for Fmic setups w/ 1'' fittings: $80
- Tial Alpha Q adonized blue Bov, comes with v-band clamp: $150
- HKS v1 ssqv bov +20 for tmic flange: $100
- HKS v2 ssqv bov +20 for tmic flange: $110
- Power Enterprise Short Ram Intake: $90
- Socal Porting PnP Sidefeed TGV Deletes: $180
- Socal Porting PnP 02-07wrx Top Feed TGV Deletes: SOLD
- Socal Porting PnP Crosspipe: $100
- 02-05 wrx Socal Porting PnP Intake Manifold: $200
- 06-07wrx/04-06sti PNP Intake Manifold: $240
- DBC PNP Socal Porting Throttle Body: $90
- DBW PNP Socal Porting Throttle Body: $110
- 02-07 Blitz Turbo Timer w/ pnp harness: SOLD
- Bride Brake or clutch reservoir custom sock/cover: $40
- Zerosports Radiator cap 1.3bar, NEW: $40
- Outfront Motorsports Fuel Pressure regulator w/ 3bar and 3.5bar pill settings: $120
08+ Parts!
- Oem '11 wrx intake manifold: $80
- Oem '11 wrx Purge Control solenoid valve Pairs: $80
- Oem '11 wrx MAF Sensor: $60
- Oem '13 sti Map Sensor: $65
- Oem '13 sti Boost Controller used for under 200 miles: $50
- Oem sti intake box w/ filter/etc.: $80
- Oem '13 Sti Injectors set used for less than 200 miles: $200
- Oem '13 Sti Purge control solenoid valves Pair: $90
- Socal Porting PnP Top Feed TGV Deletes: $210
- Socal Porting PnP Exhaust manifold w/ crosspipe: $320
- Socal Porting PnP Crosspipe: $120
- Socal Porting PnP Throttle body: $120
- 08+sti Socal Porting PnP Intake manifold: $260
- Oem '13 sti FPR with under 200 miles: $45
- Oem '13 sti fuel rails w/ under 200 miles: $60
- Oem Turbo inlet off '13 sti used for under 200 miles for 08+sti: $45
I may have forgotten some engine related parts so pm me if you need anything specific I may have it, as for specific pigtail/ Harness plugs i can cut them for you with plenty of wiring.
DO NOT REPLY IN THIS THREAD. PM ME instead.
This thread will only be updated to lower prices or updated sold items!
complete with, gt3076 .82a/r garrett dual ball bearing turbo
perrin rotated turbo inlet with maf housing and k&n filter
perrin rotated up and downpipe
tial 44mm ewg
oil and coolant lines.
1 - 13 of 13 Posts
