1 - 9 of 9 Posts
So i put in Tanabe GF210, My back looks fine, but my front still looks high. I can fit 3 fingers in (mind you my fingers aren't the biggest. what's a good way i can measure this to find out if it dropped the right amount?
that sounds about the right height. you dont want the front and the back to be even with each other. once you star lowering it much more than it already is your going to loose some handling ability.
yep you have to allow the car to settle, and always remember the way you park will make the car looks like it sits different at certain angles.
To measure the actual ride height (fingers vary greatly in fatness!) measure from the center of the hub to the fender lip. Make sure the car is on flat, even ground and measure both sides of the car. Should only take a minute.
1 - 9 of 9 Posts
