1 - 7 of 7 Posts
I cut my injen CAI into RAI, it definitely better for me, cause I put an HKS SMF filter on it instead of the one supplied! I just cut it to make sure I can fit the filter on without hitting the side wall!
It can be shorter, for eg) HKS racing intake is about 4 inch shorter, AEM RAI, is about 2-3 in shorter then mine... etc etc
but if you think sucking in too much air is your problem, you will feel the car suck in more air in RAI, becuase the distance of travel is less.
here's a picture of what I got...
OM3GA, did you remove your silencer.....have you seen the scooby mods diy c a i....i made that alteration and now the car is a bit quicker and it goes swoosh!
Do you have the URL for the DIY CAI?
Thanks,
Rich
no, I havn't seen the scoobymod DIY CAI, can you provide a link? tried searching on scooby's, but no show!
I took off the silencer and bought an universial intake pipe (soft rubber, bendable once) to connect from the intake duct, out to fender, around the U, then point it directly at the cone! that way, when I get up to higher speed, cold air will shoot directly at my intake filter, I find it quite effective.
This way, I don't need the long CAI pipes, and still get cold air!
Also, I made a heat shield to block the hot air coming from the fan and engine and turbo!
the link is in the modification section under silencer removal.....it was so easy and cost me about 6 bucks.....and a couple of scraped knuckles....but now woooosh!!!!!!!!! 8)
Discussion Starter #7
schwing!!!!!
Did you cut both end of the injen? how did you cut from the left side of the intake? you just repaint it w/ red right. can I see the pix of the heat shield that you made and the side wall of the intake thank you again.
1 - 7 of 7 Posts
