1 - 16 of 16 Posts
ok so i have a 06' STi and it sounds like the rear passenger side passenger door is adjar or the window is open when i reach a speed of around 30 mph and it just gets louder and louder with speed. anyone got anything on this???
My car only has 4800 miles just got it 2 months ago
not really.
there is a bit of windsheild noise and occasional i doubel check to make sure all my windows are up. but usually i just drive with the windows down.
its normal, its a howl and i also have it
Yeah, I have this noise and it sucks. My first STi didn't have it but my current one does. It always sounds like my driver's side door isn't closed all the way or the window is slightly rolled down.
The 2006 I had did the same thing. When I was on the highway at around 45-60mph or so I would start hearing the air leaking in. Putting the window down a bit and then back up would fix it. You should take it to the dealer and have them fix it under warranty. The seals were probably put on a tiny bit off or something.
Dont feel bad i have all kinds of weird noises!
got the same noice here.. :(
:yeahthat:
Try this with each of your windows...I sometimes have to do this with my driver's door window.
is it just me or are you guys seeing a trend? it seems to only happen on the 06-07?
I have a SERIOUS noise when at high speeds (over 100mph) Almost makes me def!!
Its from the side merriors from what people have told me!
However, I have no other noises when doing 30 or more in my 06!
Jay
At least the back end of your car does not squeak and rattle the entire time you are under 20mph. Its super annoying (that plastic squeak sound).
no big deal your just blowing the doors off... thats why u bought it.
1 - 16 of 16 Posts
