1 - 20 of 194 Posts
Hey all.... its been more than a decade, 11 years to be exact, since i drove my 2004 JBP STi off the lot. 4 years and $35k later, i had a pretty mean 11 sec car. Sold the car at 59k miles... sold the mods and reverted to stock before selling. That car was the best car i'd ever owned..... until NOW!!
I have to say I think Subaru took a step in the right direction when they produced this machine. The body roll isn't there anymore... much smoother less jerky ride... 54 miles on her and i can already see how much fun i'm going to have. And i decided that its definitely worth chronicling my mod path, to help others in their mod quest. So..... here goes. First pic in the dealership last night at 9 pm.... just before i took delivery.
Mod list as of: 04/12/18
IAG stage 3 extreme short block.
Headgames head work. valve guide replacement, valve job, polish cams, repair journals, drill for 1/2" head studs
APR head studs
IAG fuel rails
IAG fuel lines
visconti 485 basket w/pumps
ID750 fuel filter
GTR fuel pump controller
I-wire hardwire kit w/ fuel pump controller bypass kit
GS coolant hoses
GDT coolant mod kit
sti oil pump
Cobb flex fuel kit w/ pressure sensor
Koyo radiator
Cobb Acessport
protuned by Brentuning 550whp/473wtq (09/17) corn fed E65
Blouch Dom 3.5XTR turbo 10cm 2
Killer B EL full race EWG holy headers w dump tube
Tial 38mm EWg
ETS burnt titanium CAI
ETS Black FMIC burnt titanium pipes 4" core
ID1700cc injectors (flex fuel friendly)
Perrin 3 in turbo inlet
IAG Competition AOS
Sti radiator caps
Cobb EBCS
Invidia Divorced catless downpipe w/ewg
Perrin 3 in resonated Exhaust
Cusco Earth grounding kit
Optima Red top (2nd one)
Cusco master cylinder brace
Perrin Pitch Stop mount
Cusco engine mounts
STi oil cap
Perrin radiator shroud
Perrin belt cover
Perrin boost solenoid cover
Drivetrain:
DSS carbon fiber 1 piece driveshaft
DSS 800hp rear axles
Cusco tranny mount
OEM short throw shifter
Kartboy front and rear shifter bushings
Raceseng Mirror shift knob (red)
Beatrush rear diff carrier brace
Exedy stage 4 twin disc clutch (rebuildable) 05/20
Suspension:
Whiteline steering rack bushings
Whiteline roll center adj. Kit (tie rod ends and ball joints)
whiteline front and rear end links
whiteline front sway bar bushings
whiteline 24mm rear sway bar with braces (broke)
Perrin 25mm adjustable rear sway bar
whiteline rear diff power kit (bushings and collars)
Cusco front lower chassis brace type 2
cusco rear crossmember brace
cusco rear power brace
Cusco rear lower control arms
cusco rear trailing rods
Megan Racing rear toe arms
RCE Yellow springs
performance alignment (-2.0 front/-2.7 l/r -2.5r/r)
Wedsport SA-10r limited edition (current setup)
Michelin Pilot Sport Cup 2 tires 265/35/18
brakes:
Stoptech slotted rotors
Hawk hps plus pads
goodridge SS lines
Motul fluid
exterior:
Carbon fiber front and rear badge overlays (red)
Carbon fiber fender badges
Carbon fiber front plate delete
STi side skirts
STi rear spats
Velox aggressive rear diffuser
JDM front grille
APR Carbon fiber brake ducts
APR Gtc300 cf rear wing
APR front canards
Chargespeed F1 style rear light
Hella sharptones
Rally armour UR mudflaps red lettering
Cusco rear tow hook
Custom red pinstriping
DRL delete mod
Custom aluminum front splitter (wrapped carbon fiber)
APR support rods for splitter
Electronics:
K40 removed due to too many false alarms/ passport 9500ix installed
Pioneer Nex 7000
JL Audio ZR front separates 6 1/2" woofer/ 1" tweeter(removed)
Focal expert 165v fr. separates 6 1/2" woofer/ .75" tweeter
JL Audio coaxial rear speakers
JL Audio 450/4 (running front separates, bi amped)
JL Audio 1000/1
JL Audio 13wAE7 anniversary edition subwoofer in sealed box (made from birch wood)
2.5 farad cap
1/0 cable from battery to Dist. block
Nokya Hyper Yellow LED fogs
SMY IPF fog lights
all other bulbs converted to LED (interior and exterior)
Tapturn
Tail as turn kit
SMY dual gauge cluster
Defi water temp
Defi voltage 52mm gauges
JSC triple A pillar pod
Defi Oil temp
Def Oil pressure
AEM UEGO wideband L2
custom spare tire stepped amp rack with built in cooling fans (1 push. 1 pull)
JDM MFD hood w red stitching
auto/dim compass mirror
JPM coachworks alcantara shift boot and E brake boot
Carbon fiber e brake handle
Cusco Red e brake button
Raceseng shift knob
stock motor blown (spun bearing) 8/12/15
Rallispec Street series standard short block
replaced at Brentuning 9/21/15
dyno after engine break-in..... 465whp/445wtq 93 octane, meth injection
latest numbers 509whp/456wtq 10-14-16
rallispec motor overheated 04/10/17 , block cracked (8268 miles)
IAG stage 3 closed deck block , being rebuilt by wicked performance for Brentuning.... more details to follow
see post for more info....
current numbers 470whp/435wtq pump gas, Vpower 93 octane ( no more Meth injection)
569whp/523wtq E67
we are maxed out now, the only way to get more power out of this engine would be to change the turbo, injectors and fuel pump... i think this is enough for now. Gonna focus on coil overs, and interior now....
i'm sure i've forgotten some things....
Re: Salisburyv is back!! The Beast part 2
Welcome back! Great color choice.
just ordered the jdm rear fog light kit from SMY performance tried to order the led bulb upgrades from subi speed.... they had a problem with my amex. argh!! didn't have any issue at SMY.... looking forward to ordering more stuff from them!!
I was thinking of that, you still have to fab an L bracket correct?
JDM rear fog is the mod that intrigues me the most - looks so awesome. Good luck with it!
Discussion Starter #8 (Edited)
So.... thus far.
AP installed OTS map at 750 miles, following standard break-in procedure.
JDM rear fog installed
Nokya Hyper lime yellow led fogs installed
Rally Armour flaps installed
Led interior lights
Hella supertones
STi front license plate delete
My new rims arrived!!! Prodrive GT 1 in Glitter Gold!!!
audio system concepted,designed, components chosen
falken azenis rt 615k 245/40/18
tapturn installed
On the way:
led lights from Subispeed (fr/rr turns, reverse, olm led drls) arrived!!
JDM front grille (group buy over on NASIOC)
first stereo bits start arriving
first trip to EFI to see what my power goal is going to cost
I don't know, maybe its because i'm older now, but this one seems quicker out of the box than my last one. i do know I want to see 400/400 out of it. so whatever it takes to get there and stay there without breaking is what i'm going to need to do.
Awesome car! I love those wheels. I wish that the Launch Edition would have had wheels that look more like that. So much better IMO.
Discussion Starter #11
Thanks! I wanted the Launch edition wheels to go on my car at delivery. The Stealer wanted $989 per rim. i think the GT1's look really good.This is an option that it should've come with
Hi. I really don't see you'r laser jammers. I have the same car color with the laser jammers.
Could you show me where they put it? Because they have to be visible in order to work 100%. I got 2 up front 2 in the rear. You can't hide a 2500 dollar system . I had my installed by a lambo guy:)
They look way better than the Launch wheels! Not a fan of the Limited / Launch wheels this time around tbh.
I just got the 2014 version of this design...same color scheme and all. Beginning to think I should have just waited for the 15 to come special ordered. Actually got mine used certified pre-owned through Frederick Motor Cars in MD. with 1600 miles. Just got 1st oil change couple days ago. New to the site and considering doing some mods. What do you guys recommend with my being new to the Subaru game?
Discussion Starter #16
start with an access port, get some decent tires, and get used to driving it.
Discussion Starter #17
they weren't installed at the time i took the pics, i'll post the ones my installer took as soon as he sends them my way, i'm a bit behind in my mods list.
Discussion Starter #18
so.... since my last posting i've done a bit more. Including a pretty nice audio set up. The sound quality was better than i had hoped. I had MB Quart Q series in my 04, we all know MB Quart isn't the same anymore, so i took a shot with the JL Audio ZR series separates up front. They are Bi-amped using the JL Audio 450/4. I got a screaming deal on an anniversary edition sub, i always wanted one of these. Now i remember why. I'm really digging the NEX-7000 very easy to use, and has worked flawlessly thus far. and last but not least, i changed the lighting configuration so the C lights and the fogs can run by themselves.... with a little red in the scoop..... it looks just like the pic... Menacing. esp at night coming at you..... oh.... and i got some Michelin Alpin4 snow tires mounted on the stockers. I have to say i like how that looks too. This car has failed to disappoint me so far, and i had real high expectations.
You don't miss the trunk space? I really like the fogs - wondering if my next upgrade should be LED fogs that match the headlights or ones like yours.
1 - 20 of 194 Posts
