1 - 20 of 24 Posts
I've been looking around for Rpf1s that clears the 15+ sti brembos and all I saw was 18x9.5 +38 and some spacers.
Anyone know an offset that clears the brembos? I don't mind sticking with 8.5-9" width.
Thanks
I've looked at them a bunch of times and there isn't an offset that works without a spacer for the front brembo's, the rears usually clear depending on offset.
Even something like 18x8.5 +35-40?
Or anything along those lines.
I have 17x8 +40 and they clear. PS: they are for sale, gold, no rash, snow tires/hub rings/caps included. PM me if interested.
I'd buy, but rather have 18s, and a bit wider width because I'd like to run stock tires or wider tires.
What?
It's a link to TireRack's wheel suggestions from Enkei's Racing catalog that have confirmed fitment on the 2015+ STi.
* Apparently the link didn't work. It just takes you to TireRack's wheel catalog for the STi in general, not filtered by Enkei. Sorry about that. If you use their site though, it's only a couple clicks and you can narrow down to the RPF1 and see what they confirmed would fit.
Discussion Starter #11
Thanks
Image Link
So look like 18x8 35 would work...!kinda wish it's 8.5 width
Thanks
Call LSD Motorsports in Cypress, CA. Mike helped me out a ton and is really knowledgeable about what clears our brembos and what doesn't. They'll be able to ship you whatever you want that Enkei offers and their prices were the best. They also sell on Amazon in case you want to use gift cards/rewards points.
Discussion Starter #13
Thanks again!
These are the 18s RPF1 that clear brembos
18X10.5 +15
18X8 +35
18X8.5 +30
18X9.5 +15
And These sizes require spacers to clear brakes
18X10 +38 / 3mm spacer
18X7.5 +48 / 10mm spacer
18X9.5 +38 / 10mm spacer
18X9.5 +35 / 13mm spacer
18X9.5 +45 / 15mm spacer
Discussion Starter #16
18X10.5 +15
18X8 +35
18X8.5 +30
18X9.5 +15
If that's 100% accurate then you're literally an angel
RussellX Re: Rpf1s that fits 15+ STI
18X10.5 +15
18X8 +35
18X8.5 +30
18X9.5 +15
This is super great information, Russell. Thank you.
(To all) I am just curious,
(1) How did we get this information? Is it from someone actually trying?
(2) If I go with the 18X8.5 +30, then the tires will stick outward by 25mm (stock offset is +55). Will this rub inside of the fender?
I have a 2018 and looks like 18 inch is the smallest I can go. I really like these RPF1's, but the fitment and spacer scares me quite a bit. Thank you all for chiming in. :)
18X10.5 +15
18X8 +35
18X8.5 +30
18X9.5 +15
The fitment information was provided by TireRack a while ago on nasioc forums.
1 - 20 of 24 Posts
