1 - 4 of 4 Posts
Well I was having some fun today (set in next to last triangle from the bottom - green). and I didnt put it back in auto and I went to make a turn and it was like clunk clucnk lucnklc ... you know. I thought the bushing thing took care of that? In full lock a while back it didnt make any noise, but now it seems to be hendering or so (as it seems to jitter a little) can you clone or someone try this as well and see what you get? I thought we eliminiated the "float" and if it did clunk, i figured it'd be the one clunk when you turned the wheel, not clunk clunk clunk clunk as you're turning... hmmm i'll check tire psi and ps fluid as well.
it always clunks on the slow turns (cruiselike). sounds normal to me. either power through turns or just click the on/off button before you turn in (to your driveway, for example). its pretty convenient actually, and returns you to your preferred setting (mine is permanently 55% rear). otherwise, powering out of a turn will give a chirp instead of a clunk. soon youll be clicking the switch intuitively. 8)
i understand it clunking, i just figured it clunked to engage and then would be like that until you turn the wheel back normal (and clunk again to change) now just repetitive clunking, o well, thank you!
Creating my own ground kits
no problem :wink: just remember the button.
1 - 4 of 4 Posts
