1 - 4 of 4 Posts
My ground connection has become corroded and won't allow ground to rear diff temp sensor. I have cleaned this area up and seems to help but still doesn't make a clean connection. I want to take out the the stay earth bracket to clean but it is attached to a bolt that keeps the diff casing together. Is it okay to remove one bolt from the diff casing to get ground bracket off to thoroughly clean?
Thank you friend. Im changing the fluid as well been the 30k suggested miles. Wandt forsure if it would mess up a gasket in the diff housing. This ground is a pain. Ill figure it out. Noticed the 2015+ models ground is elsewhere. I see why. Thanks once again.
It's a steel gasket and plenty stiff cover. Loosening one fastener won't affect anything. Ive removed them, one-by-one on a couple occasions.
1 - 4 of 4 Posts
