Re: Winter Wheel/Tire Set Up
Tires are 245/40 18
The Blizzak LM-60 is Bridgestone's Performance Winter / Snow tire developed for the drivers of sports cars, sporty coupes and luxurious performance sedans that are looking for winter driving traction on dry, wet and snow-covered roads. The Blizzak LM-60 is designed to combine the basic tread design of the Blizzak WS60 with a high-silica tread compound to blend high-speed durability and dry road, cold weather handling with snow traction.
Since the current Multicell tread compounds used on Blizzak winter / snow tires are not designed to support H-speed ratings, the Blizzak LM-60 uses a high silica content winter / snow tread compound molded into a directional tread design that features independent tread blocks with 3-D zigzag sipes to disperse water away from the tire's contact patch, further enhancing grip. The combination provides hydroplaning resistance and greater driving and braking force on snow-covered roads.
Featuring Bridgestone's UNI-T Technology, the Blizzak LM-60's internal structure includes twin steel belts reinforced by spirally wound nylon to provide the desired high-speed durability and ride characteristics.
Blizzak LM-60 winter / snow tires meet the industry's severe snow service requirements and are branded with the mountain/snowflake symbol.
Install Bridgestone Blizzak LM-60 tires in sets of four only.
Due to the traction capabilities of the Blizzak, Bridgestone recommends using Blizzaks only in sets of four to provide the best handling characteristics and tire performance.
Winter tires are not UTQG Rated
Spec Sheet on Mogeti M118 Wheels:
Motegi Racing - Wheels
Full specs on wheels and tires? I'm local (bel air) and shopping.
