1 - 2 of 2 Posts
I had this motor custom built for a project that I ended up going a different direction with. This thing was build to be able to handle a 800+whp sequential trans beast of a Subaru reliably.
I have over $17k in receipts for this build.
Asking $14,200OBO
Everything is brand new.
The engine was broken in and engine dyno’d at Herbert Performance (not with dry sump) from memory the engine made 430/410 on low boost (Approx 16lbs) with a GT30r
Specs
- EJ25 oe new case halves
- 100mm Darton T sleeves + 1/2” head studs
- SCAT billet crank
- Manley Rods
- icon pistons
B25 CNC port and polished heads
- beehive springs
- supertech valves/buckets DLC coated
- single AVCS GSC S2 cams
- kevlar timing belt/new water pump
- custom valve covers to accept Dry sump lines
- Dailey engineering Dry sumo
- LS7 style 6qt oil tank/ mounting hardware.
If you have any questions please don’t hesitate to ask. If I can’t personally answer them you or I can refer to the mad men at Herbert Performance.
Thank you for viewing my ad
-Steele
1 - 2 of 2 Posts
