RA piston metallurgical/hardness analysis results
12K views 14 replies 6 participants last post by  mheyman
Making 500, 600, or whatever record whp on an RA block doesn't imply the pistons will last using that much juice on a regular basis. They are cast pistons in the end. . . .1. When I say a high power engine or build, I’m referring to a modified EJ street car that will see frequent WOT/redline runs for many thousands of miles. I’m not referring to a racing engine that will be rebuilt regularly. . . .
Another issue regarding high power RA’s blocks. Sleeves are another limiting factor. In addition to the limitations of the pistons, EJ sleeves also crack. Even though there is no consensus about a specific power level at which sleeves can crack, EJ sleeves are at risk of cracking above 450-500 whp. . . . out any issues. Unfortunately for the rest of us, sleeves can crack above a certain power level (I’m not going to get into the 702 vs 7xx discussion). The RA block has the same sleeves as any other EJ257. I wouldn’t build a high power car on a semi-closed deck short block.
. . . Not enough RA’s out there. How many are out there? How many of the 500+ whp ones are beat on daily? I think no one knows the answer, I certainly I don’t. Time will answer how well these high power RA blocks will hold. I suspect it will be similar to any other EJ that has been tuned and used similarly.
You don't need to consider RA blocks Plenty of people have built and DD 400, 500 and even 600 AWHP STIs. Almost every Subaru specialty shop has built a "bunch" . How many cases of cracked sleeves have we ever heard of? Not sure I can remember even one, and closing decks was never mostly to prevent sleeves from cracking. They mostly improve HG issues.
I too have argued this very exact concept/idea on here and or Nasioc. Sure its seems like the RA blocks can handle more power but the results are always so scattered. "So an so made 400-500whp for X amount of miles without issues on the RA block" is something I commonly hear about on the internet. What isnt talked about is how the car is used. And when I mean used, I mean how its driven by the owner on a consistent basis. Daily driven, sure but how is it daily driven?? Driving a 400-500hp sti and never ever putting your foot into it begs the question of why.
Why? because that means the driver isnt to confident of it lasting at that level either on stock block. That, and also being a 4-500whp car as a daily on public roads. Lets make no mistake, im talkin wheel hp and not crack hp.[/QUOTE]
Why? Cause people are rightly conservative when learning to drive a drive a high power car. I know it took me a long time before I could really make use of my medium powered STis power. I was not particularly concerned about blowing it up. Actually I was never comfortable with the PS2 that were on the car at the time. Years later I found the car far more confidence inspiring with other tires.
owns 2020 Subaru STI
understood - but I believe my case is underrated - not in small part due to the "crack HP" numbers we see getting thrown around.
IE people relate unrealistic high numbers and think I was comfortable with that . . . when the whole experience was based on a false premise . . .
See the ratings of . . . say IAG blocks. Have a certified shop install one and you have a 2 yr warranty for unsleeved blocks for applications to over 1000BHP.
Cracks? Chris, you mentioned sleeves on a shop car not too long ago. You still build with them?
