1 - 5 of 5 Posts
are the speaker adapter plates for those STi's without factory stereos? ie i have a factory stereo (didnt ask for it thats for sure) will i have to buy adapter plate?
im too lazy to take off the panels till i know if i have to fab up some mounts or not
The door panels in the STi have 3 square holes (in the 0-60-120 degrees) position. If your speakers have, say, 4 mounting holes, you'll need to use an adapter.
how much should i ask for almost new oem sti parts?
I installed Infinity Reference 6000cs on the fronts. Mounting depth 2 1/16". Without using 1/2" spacers, they won't fit. The metal to window depth is about 1.75" only. In other words no speakers will fit unless you use spacers. I made mine, but check EastCoastScooby at the NASIOC car audio forum.
Correct. Lowering the window will touch the speakers a little bit. I did have to use the spacer provided with my Alpines.
1 - 5 of 5 Posts
