41 - 60 of 591 Posts
Re: AWDfreak has more posts than bboytaktix in this thread.
I don't get this whole ranking thing. Please explain. I am too intrigued. You have really pulled me into this one, with my name in the title and all
Okay. Well your rankings link on previous page lead me to a list of my posts and not my rankings so was hard to tell. The one you just linked had actual rankings and made some sense to me.
My username is relevant in this thread. Because race name.
lurking Subaru whore
rankings in terms of post-whore rank
the higher, the better
if you click on this you will see the rankings of the previous thread
more posts, the better
unnecessary multi-quoting is highly encouraged
Subaru and Yakima work together in the North American car market
http://www.yakima.com/shop/bike/roof/forklift/
#8002098
https://www.subaruonlineparts.com/product_info.php?products_id=1610
E361SAJ300
http://www.yakima.com/shop/cargo/gear-baskets/loadwarrior/
#8007070
https://www.subaruonlineparts.com/product_info.php?products_id=1619
E361SSA200
oddly enough, my local dealers have such good deals that the Subaru-branded Yakima products are actually cheaper than buying them at actual Yakima dealers :D
bboytaktix, are you trustworthy enough to carry the title of the whore of the post-whore thread?
because I know I will NOT be the one to carry on this thread's legacy
you should already know the answer to that. Be ready. I'm ready. RAWRRRR
#8002098
E361SAJ300
#8007070
E361SSA200
A perfect example of proper depiction of artwork in the house.
it is a difficult one to maintain
you have to post content that is one or more of the following, while retaining "safe for work" rating:
annoying
funny
revolting
ridiculous
informative
useless
random
provocative
technical
whatever the **** is on your mind
activation of random generator
'tis not hard to make
it just requires effort
and ATTENTION TO DETAIL (part numbers are massively important)
I had two similar events in my trucking career with a family of ducks crossing the road... Thankfully, no one passed me, which is weird because people are usually very intolerant of big trucks, so they blow by us without thinking there might be a reason we're parked on the road with our 4-ways on.
However, I did accidentally squish quite a few dozen animals over the years, so I do try to balance my Karma once and again! :lol:
*quack-quack* ;)
*quack-quack* ;)
It's not just big trucks. Even in accident scenes, I have seen people line up BEHIND accident scenes even when the HAZARD LIGHTS are on.... and then they honk and give you the angry look as if there was something they could have done :rolleyes:
It's good that you've blocked traffic to save the duckies, because someone trying to avoid the duckies at high speeds would be a genuine traffic hazard!
lifetime-achievement: top-rated comment
100 MPH on DIRT! Jon Burke wins the High Desert Trails Rally 2013 - YouTube
AWDfreak . 11 hours ago
Yup. There's no mechanical grip in the air as far as I'm aware.
· 11 in reply to neddy781
Can't even begin to think what the reception was like. - Imgur
I realize I'm really late to this, but on the left is Justin Beiber, on the right is my 3 month old. I know they're hard to tell apart. - Imgur
Subaru 5MT 5-speed manual transmission sticky clutch sticking clutch pedal stuck clutch pedal
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/ACM1474778/SB-10001726-7772.pdf
Service Bulletin No.: 035203
Component(s): POWER TRAIN
NHTSA ID Number: 10001726
All Products Associated with this Service Bulletin expand
Details close
1 Associated Document close
Manufacturer: Subaru of America, Inc.
SUMMARY:
CLUTCH PEDAL STICKING. *TT
SB-10001726-7772.pdf Service Bulletin Document 33
Subaru of America Bulletin Number:03-52-03; Date: 05/19/03
APPLICABILITY: 1995~2002MY Legacy;
1997-2003MY 2.5L Impreza; and
1998~2003MY Forester Vehicles.
All models have Manual Transmission.
SUBJECT: Clutch Pedal Sticking
INTRODUCTION
In the event you encounter a customer complaint of the clutch pedal not returning completely after being engaged, or has a spongy pedal feel or a light feel in the shifting pedal while shifting, the following repair method should be followed. This condition may affect certain manual transmission vehicles with a hydraulic clutch system under certain weather conditions.
PROCEDURE
To correct this condition you must replace the parts in the chart that match your vehicle using the following procedure:
For Natural Aspiration models with hydraulic clutches
1) Remove the intake chamber from the backside of the intake manifold.
2) Remove the clutch hose and the clutch operating cylinder. In this procedure it is not necessary to remove the master cylinder, the clutch pipe and bracket.
3) Replace the clutch hose and the clutch operating cylinder with new parts as listed in the chart. Note that two pieces of gasket (P/N 114130151) used on the connector of the operating cylinder must be replaced with new ones when replacing the clutch hose. Tightening torque of the bolt is: 37 ± 3 Nm (3.8 ± 0.3 Kgm) or 27 ± 2 ft. lbs.
4) Bolt the operating cylinder onto the transmission.
5) Add brake fluid.
6) Bleed the air from the system.
7) Bleed the air from he system.
8) Install the intake chamber.
For Turbo models
1) Remove the intercooler.
2) Remove the clutch operating cylinder hose. In this procedure, the clutch master cylinder, clutch pipe and bracket are unnecessary to be removed.
3) Replace the clutch hose that was removed with the new one listed in the chart. Note that two pieces of gasket (P/N 114130151) used on the connector of the operating cylinder must be replaced with new ones when replacing the clutch hose. Tightening torque of the bolt is: 37 ± 3 Nm (3.8 ± 0.3 kgm) or 27 ± 2 ft. lbs.
4) Add brake fluid.
5) Bleed the air from the system.
6) Install the intercooler.
7) Check the following items:
a) Insure there is no leakage from the line, check whether fluid leakage occurs after the clutch pedal has been fully depressed.
b) Check whether the clutch performs normally.
[presumably parts required for models affected]
02MY ~ WRX (5MT) - Unnecessary to replace - 37251AA003 - 114130151 X 2
Legacy (5MT) - 30620AA042 - 37251AC001 - 114130151 X 2
Impreza (5MT) - 30620AA042 - 37251AC001 - 114130151 X 2
Forester (5MT) 30620AA042 - 37251AC001 - 114130151 X 2
This change was incorporated in production after the following VIN numbers:
Legacy - All - 3G*00000 - Beginning of the 03 MY
Impreza - Sedan - 2G522233 [unreadable, may not be actual number] - April 10, 2002
Impreza - Wagon 2G355444 [unreadable, may not be actual number] - April 10, 2002
Forester - All - 3G713250 [unreadable, may not be actual number] - April 10, 2002
How to loop a YouTube video:
1) take the original, bare video URL (make sure video code is without the "&" in it)
2) erase the "watch?" in the URL
3) change the "=" to a "/" (forward slash)
4) after the video code, put "&loop=1" in the URL
Similar music samples!?!?!? :eek:
O SON DO AR - Luar Na Lubre - YouTube
Macross Frontier {Aimo} Full - YouTube
Macros Frontier - Aimo (acoustic remix)
SA Stage 5 - Lullaby of Deserted Hell - YouTube
OC ReMix #2603: Touhou Chireiden: Subterranean Animism 'Lullaby of Flame' by DDRKirby(ISQ) - YouTube
