1 - 20 of 606 Posts
Does not drive a Suby
Post.
No posts should ever contain:
full nudity
pornographic images, videos, or games
pornographic cartoons or anime (hentai/ecchi)
Strategically covered nudity
Sheer or see-through clothing
Lewd or provocative poses
Close-ups of breasts, buttocks, or crotches
And no posts should contain:
On-topic material.
Sense or sensibility.
Flashbacks.
Moving on...
Re: (un)official official thread information. Please ignore:
And the thread title will change.
Occasionally.
And I might edit your posts here, if I think it's funny to do so. You've been warned...
lurking Subaru whore
Imgur: The most awesome images on the Internet
military service ribbons
http://runrocknroll.competitor.com/files/2012/10/Hor_4c_lg.jpg
http://fc08.deviantart.net/fs24/f/2008/028/1/f/USA_Grunge_Flag_by_xxoblivionxx.jpg
U.S.A. flag display days
* [single asterisk indicates California-specific flag display day]
** [double asterisk indicates day of military branch/component founding]
The flag should be displayed on all days, especially on
New Year�s Day, January 1;
Inauguration Day, January 20;
Martin Luther King Jr.�s birthday, the third Monday in January;
Lincoln�s Birthday, February 12;
Washington�s Birthday, third Monday in February;
* Cesar Chavez Day, March 31;
Easter Sunday (variable);
Mother�s Day, second Sunday in May;
Armed Forces Day, third Saturday in May;
Memorial Day (half-staff until noon), the last Monday in May;
** Flag Day, U.S. Army founded, June 14;
Independence Day, July 4;
** U.S. Coast Guard founded, August 4;
Labor Day, first Monday in September;
* California (date of admission), September 9
Constitution Day, September 17;
** U.S. Air Force founded, September 18;
Columbus Day, second Monday in October;
** U.S. Navy founded, October 13;
Navy Day, October 27;
** U.S. Marine Corps founded, November 10;
Veterans Day, November 11;
Thanksgiving Day, fourth Thursday in November;
* Day after Thanksgiving, fourth Friday in November;
** U.S. National Guard founded, December 13;
Christmas Day, December 25;
and such other days as may be proclaimed by the President of the United States;
the birthdays of States (date of admission);
and on State holidays.
TDW . . . . . . .
atl .
updated silly list stuffs
My Subaru Tribeca EZ36 (facelift) mod wishlist
Engine
* RalliTEK 5EAT Transmission Mount Insert
* custom stiffer engine mounts [or retrofit right D1010FE110, left D1010FE120]
* custom stiffer upper transmission mount "pitching stopper" (engine/trans connecter) [or retrofit D1040FE000]
* replace fasteners of engine mounts with ARP heavy-duty fasteners with applicable threadlock
Lubrication system
* custom external engine oil cooler with thermostat (such as a Greddy Oil Cooler Kit) in addition to stock oil cooler
* custom baffled oil pan
* FA/FB/EZ specific STI Sports Oil Filter P/N ST15208ST000
* normal use: Idemitsu/Subaru Synthetic 5W-30; severe duty: Motul 8100 X-cess 5W40 motor oil (SAE viscosity 5W-40)
Cooling system
* high-pressure radiator cap such as STI Radiator Cap P/N ST4511355010 or Cosworth 20027841 (1.3 bar)/20027842 (1.5 bar)
* Holts radweld into radiator per Subaru's warranty procedures for cooling system (via Subaru Cooling System Conditioner)
* upgraded fans (custom fans with more fanblades to fit OEM cooling system)
* optional external transmission oil cooler (that comes with towing package Trailer Hitch P/N L101SXA100) Transmission Oil Cooler part number D551SXA000 or upgraded, re-routed (external air-to-oil) transmission oil cooler
* custom heavy-duty silicone radiator hoses
* custom cooling-fan programming (for long idle periods) with fan cut-off switch (for deep water crossings)
* fine-mesh integrated radiator guard (mounted behind grille)
* STI Radiator Support Bushings Impreza 2008-2011 [B4510FG000]
Exhaust system
* custom stainless-steel cat-back exhaust with upgraded mufflers
* custom heavy-duty impact-resistant exhaust mounting with skid plates
Intake and supply sustem
* dry high-flow intake filter (STI ST1654621010 or Cosworth COS1 20002278]
Engine electronic
* high-output alternator (preferrably at least 160 amps) such as Large Case Denso Hairpin 230 Amp XP series alternator 230 Amp XP High Output Alternator for Subaru Forester, Legacy, Impreza
* wide open throttle air conditioner cutoff
* NGK Iridium IX spark plugs [P/N LFR6AIX-11, Stock No. 6619, plug gap shipped 0.044")
* custom engine tune or stock
Automatic transmission
* custom stiffer transmission mount [or retrofit D1010FE020/D1010FE000]
** miscellaneous breather tube extensions [differentials, transmission, etc]
* Exedy Friction Technics Catalog parts used for transmission overhaul/rebuild
Drivetrain
* rear differential member assembly-front (P/N 41310AG02B used in Legacy too) equipped with Whiteline Rear Diff Positive Power Kit Bushings P/N KDT905
* Bushing assembly-differential mounting R (P/N 41322AG00A used in Legacy too) equipped with Whiteline Rear Diff Positive Power Kit Inserts (rear diff, rear mount to subframe) P/N KDT903 or heavy-duty P/N KDT906
* custom-made torsen rear differential?
Suspension and axle
* custom stiffer overload springs (from custom spring manufacturers such as Coil Spring Specialties at Coil Spring Specialties)
* KYB Excel-G struts [SB105 FRONT BOOTS, 335055 FRONT LEFT, 335054 FRONT RIGHT, 341403 REAR, SB107 REAR BOOTS]
* custom thicker anti-roll bars/anti-sway bars (from custom anti-sway bar manufacturers such as Quickor Garage) with quick disconnect fasteners
* replace fasteners of subframes and miscellaneous suspension components with ARP heavy-duty fasteners with applicable threadlock
* custom reinforced or custom-built subframes
* custom front and rear (upgrade rear support brace) subframe bracing
* Cusco Front swaybar Endlinks Subaru WRX/STI 2002-2013 Cusco P/N [667 318 A] used on front and rear anti-roll bars
* Whiteline Rear Trailing Arm Front Bushing Kit Subaru Models (inc. 2008-2013 WRX/STI) Whiteline P/N [W0568] used on rear hub assembly (known as knuckle bushing/pillow ball bushing)
* custom lower chassis brace (links both ends of front crossmember (like STI Lower Arm Bar) with front subframe)
* custom heavy-duty half driveshafts compatible with stock drivetrain by The Driveshaft Shop
Brake system
* Goodridge G-Stop Brakeline Kit (stainless steel, part number 24217)
* DOT 4 racing brake fluid such as Endless RF-650 Racing Brake Fluid
* Endless CC-Rg brake pads; pad P/N [applicable to any brake lining compound] EP417 front, EP472 rear or Brembo GT brake swap (for BM/BR Legacy/Outback 2.5GT/3.6R) front (black 6-piston slotted front 1M2.8034A1) 1M2.8034A, rear (black 4-piston slotted rear 2P2.8020A1) 2P2.8020A
* custom master cylinder brace
* gold-colored heat reflecting shield wrapping on master cylinder
Steering
* retrofit Honda Ridgeline "Cooler, Power Steering Oil", Honda P/N 53765-SJC-A03 or custom external power steering cooler
* Motul Multi ATF
* reinforced tie-rod and other reinforceable material/components stiffened
Wheel
* custom 18x8 alloy-look-painted steel wheels (preferably with large vent holes for decent brake cooling and Subaru TPMS compatibility) [bolt pattern 5x114.3 AKA 5x4.5, Offset 55 (2.17)]
* regular tires: Pirelli Scorpion Zero 255/55R18
* winter tires: Dunlop Grandtrek WT M3 ROF or Goodyear Ultra Grip SUV RunOnFlat [255/55R18]
* OEM wheel locks w/ spare wheel lock adapters in emergency kit
Body
* miscellaneous unibody welding
* bedliner coated undercarriage (body only, for protecting bottom of body and unibody from damage)
* "stealthy sliders", reinforced unibody lip (for off-road abuse)
* custom front and rear off-road/push bumpers with tow-hooks, winch mount, rubber push-guard, light mounts, etc. mounted to unibody
* custom mechanical rear hatch door-handle connection (interior emergency exit knob, exterior locks like older Subaru models, for when battery is dead)
* custom bulletproof [Handgun/Pistol Protection - T4 (NIJ IIIA/European B4)] ceramic plates, kevlar sheets, and/or bullet resistant fiberglass sheets installed on all doors, hood, tailgate/rear hatch and firewall from trusted manufacturers such as BLS Textiles (supplies Ford CVPI and PI Sedan ballistic plates) BLS Textiles Contact Us or custom installed by Texas Armoring Armored Cars, Bulletproof Vehicles, Armoured Sedans & Trucks
* clear Plasti Dip throughout exterior of vehicle with painted surfaces
Body equipment - exterior
* hidden brake cooling ducts
* custom triangulated strut-tower brace with additional engine bay/front end bracing (such as cowl plate stiffening, triangulated bracing from area near struts to front-end, etc)
* Primitive Racing Tribeca [H6] Front Skidplate 3/16" or 1/2" steel custom v-shaped front skidplate
* Primitive Racing 2010-2013 Outback [5EAT] Transmission Skidplate or 1/2" steel custom transmission skidplate
* Primitive Racing 2010-2013 Outback H6 Rear Skidplate or 1/2" steel custom v-shaped rear skidplate
* 1/2" steel custom v-shaped passenger compartment skidplate
* secondary smaller side rearview mirrors (similar to Volvo police package) mounted on door window frame
* metal mesh fog lamp covers (imitates STI fog light covers that let light shine through while protect lights)
* rally underfender (known as fenderliners or fender liners) mud guard (made of Ultra-high-molecular-weight polyethylene [UHMW-PE]
* Subaru bumper corner molds
* door jam guard (anti-door ding)
* custom blend-in light reflectors (light reflector same color as paint)
* custom rear bumper small low-profile underspoiler/diffuser
Body equipment - interior
* RalliTEK 52mm Oil Pressure Gauge or other
* additional gauges [oil temp, oil pressure, volts, AT oil temp, R.diff temp] by Auto Meter (low-key such as Z-Series Gauges)
* interior fire extinguisher mounts (preferrably under front seats)
* Subaru all-weather floor mats
* custom rear seatback protectors (2nd and 3rd row seats)
* bucket seat reinforcement (anti-stab plates)
* custom/retrofit Panasonic Toughbook hidden storage/charging mount
Electronic
* upgraded Hella Twin Supertone horn kit (300hz/500hz) P/N 003399801 and/or PIAA Automotive Supererior Bass Horn (330hz/400hz) P/N 85115
* upgraded headlight and fog light bulbs
* US Army blackout (TruckLite) headlights and taillights retrofitted and integrated for near-factory look/undercover
* heavy-duty battery (preferrably at least 720 CCA 70-amp hour, OEM/stock CCA is 490) such as Deka Intimidator - AGM - Valve Regulated [9A35/85]
* heavy-duty grounding kit (8ga cables/wiring) by Paranoid Fabrications or custom
* integrated or external rear fog lights
* Volvo-style integrated Side Positioning Lights, preferably LEDs (allows corners of vehicle to be seen in daytime as well as night)
* integrated, low-profile surveillance cameras throughout vehicle (various angles allow for maximum evidence) such as Pro-Car Cam with DVR
* twin Subaru Baja Sport Activity Lights retrofit P/N H1410LS200 or PIAA driving lights mounted in front of grille
* Subaru Mobile Internet (Autonet Mobile in-car Internet Service) P/N H001SAJ200
* additional power outlets throughout interior
Climate
* gas-mask-filtered cabin filter (ABEK-P3, CO, Hg, Reactor, P; one or combination of multiple filter classifications layered), NBC (nuclear, biological, chemical) protection
Other
* full-size spare w/ regular tire or winter tire (as equipped)
* complete tool/emergency/EMT/CLS/roadside/hazmat kit w/ USA Level A/Europe Type 1 hazmat suit
* chock blocks and drip pans for parking
* Subaru/Robin R1700i Inverter - Silent Generator
additional Accessories
* hood protector
* front bumper underguard (w/ bedliner product)
* bumper corner molding-rear (2 pair)
* rear bumper cover
* security system shock sensor
* detatchable trailer hitch
* Subaru severe weather companion
* luggage compartment cover, black - retractable
* cargo net, rear
* cargo net, rear seatback
* compartment separator/dog guard
* rear dome/reading light (w/ custom additional low-key red light)
* auto-dimming mirror/compass
* cargo tray - gray, 7 passenger
* crossbar kit, aero
* heavy duty roof cargo basket
* battery warmer
my Subaru off-road rig silly list
My Subaru Leone (1st or 2nd generation wagon preferred, 3rd generation if no 1st or 2nd available) unrealistic off-road dream mod wishlist categorized opposedforces style
NOTE: double star "**" indicates modification overlaps another category
Engine
* twin-carbureted Subaru EA81 OHV [designated EA81S] (cam-in-block) with forged-internals (rebuilt) or EA81 OHV retrofitted with custom twin-carb (new 1985 DL wagon short-block P/N 10103AA160, very likely EA81 part number)
* head and port polish
* custom balanced-performance camshaft
* heavy-duty engine mounts (preferably Safari Spec rally)
* kevlar heavy-duty timing belt
Lubrication system
* Purolator PureONE PL24457 or Classic L24457
* custom baffled oil pan w/ high capacity
* 10W-50 Motul motor oil
** custom engine oil cooler kit
Cooling system
* Subaru "cooling system conditioner", Holts Radweld P/N SOA635071
* custom heavy-duty silicone hoses throughout engine bay (radiator hoses P/N ST451624S000, etc)
* custom aluminum radiator shroud
* STI radiator cap P/N ST4511355010 or custom
** power steering fluid cooler
** custom transmission oil cooler kit
* STI Group N or Greddy or Ron Davis Racing radiator retrofit (reinforced + oversized) with oversized cooling fans with stock programming
** fan cut-off switch for deep water crossings
* heavy-duty water pump
Exhaust system
* custom-installed Bosal muffler
* reinforced custom muffler mounts optimized for ground clearance
* exhaust security butterfly valve (seals exhaust from anyone or anything from entering)
Intake and supply system; turbocharger
* custom retrofitted Subaru EJ intake w/ common air filter part
* custom intake oil catch (if necessary)
* custom black heavy-duty silicone hoses throughout engine bay (vacuum hoses, intake, etc)
* custom Walbro fuel pump
* snorkel intake for deep mud/water crossings
* puncture-resistant fuel-cell replacing fuel tank w/ high capacity
** Gortex-protection for intake
Engine electronic
* NGK Spark Plugs
* NGK spark plug wires
* high-output (220-amp or higher) alternator (WRC or heavy-duty) with idle boost feature
* heavy-duty starter (WRC or other heavy-duty)
* water-resistant or waterproof-ed sensors and electronics
* upgraded distributor w/ custom tuning capability
Manual transmission
* retrofitted early-model Subaru Outback/Forester 5-speed manual with 4.111 final drive axle ratio and heavy-duty viscous-coupling center differential similar to Subaru rally cars w/o DCCD (full-time Continuous AWD)
* dual-range Australian-market Subaru EJ-compatible transmission retrofit 1.447 low-range ratio
* custom pitch stopper (reduces engine/transmission movement under harsh driving)
* custom heavy-duty transmission mount
* Exedy Stage 1 Organic clutch kit
** extended diff and misc. component ventilation/breathers
** Gortex-protection for breathers
Primary Drivetrain
* 75W-90 GL-5 synthetic gear oil
* retrofitted early-model Subaru Outback/Forester 5-speed manual rear differential 4.111 final drive axle ratio
** upgraded heavy-duty driveshafts and total drivetrain replacement with heavy-duty components from STI or The Driveshaft Shop
** reinforced outrigger bushings
* Torsen (Helical LSD) T-2 front LSD and Torsen rear LSD (or any applicable torque-sensing LSDs for front and rear) OR Cusco LSD (Type MZ front P/N LSD 180 B15, Type MZ rear P/N LSD 183 K2)
* custom rear differential cover optimized for maximum cooling w/ numerous cooling fins (at least 15 cooling fins)
Suspension and axle
* heavy-duty wheel bearings or STI NSK/STI Group N wheel hub/bearing retrofitted (5-bolt 5x100 retrofit)
* STI Group N reinforced half driveshafts or Tomioka Racing Subaru Rear Axle or The Driveshaft Shop
* custom 2-inch or higher strut lift kit
* KYB struts (234028 front, 343056 rear shocks, SB103 strut boots, SM5365 mounting kit) w/ overload springs from Pedders Suspension or King Springs (KFFS-45 front, KSRS-03 rear)
* Pedders/Whiteline suspension bushings
* custom reinforced suspension components (control arms, other suspension components)
* quick-detach fasteners for anti-roll bars
* STI GpN strut mounts (if possible)
Brake system
* 2006-2007 WRX brake master cylinder P/N 26401FA031
* custom Goodridge stainless steel mesh brake hoses
* Grimspeed or Cusco or custom brake master cylinder brace (and clutch cylinder brace)
* STI/Motul brake fluid (DOT4)
* Subaru WRX (USDM MY2006-2007) 4-pot front calipers and 2-pot rear calipers painted black retrofitted (RF 26292FE041, LF 26292FE051, RR 26692FE040, LR 26692FE050)
* Hawk HPS pads (HB700x.562 front, HB179x.630 rear)
* heavy-duty parking brake cable
* heavy-duty parking brake lever w/ anti-theft lock
* WRC/rally-style wheel scrapers (scrapes mud, gravel, etc out of wheel rims)
* WRC/rally style stone guards
Steering
* Motul Multi ATF for power steering fluid
* STI Power Steering Pump or custom heavy-duty
* Whiteline/Pedders Suspension steering bushings
* Momo steering wheel
* custom quick-ratio steering rack
Wheel
* 16" black steel wheels
* snow rated all-terrain tires such as BFGoodrich All-Terrain T/A or General Grabber AT2
Body
* custom side-cowl plate (reinforces unibody around rearward portion of fender)
** custom B pillar brace w/ Sabelt racing belt harness
* custom chassis/subframe brace
* custom reinforced heavy-duty subframe bolt-on (bolted on for easier servicing)
* unibody welding and miscellaneous reinforcement
* custom underbody strut bottom/underbody bracing
* slightly-thicker glass windows w/ moderate black tint
* custom off-road towing package from Pedders Towing Solutions
* heavy-duty (WARN brand?) winch mounted on rally bumper
* rally-style front bumper lip (able to take off-road abuse while making front-end more aerodynamic plus light downforce with quick release feature)
* heavy-duty off-road rear bumper, unibody-mounted
* easy-to-reach large tow hooks on front and rear unibody
* custom strut-tower braces
* bedliner coated undercarriage (body only, for protecting bottom of body and unibody from trail damage)
* side mirror rounded-mirror attachment (for lane checking)
* late 1990's Subaru windshield wiper retrofit
* PIAA windshield wipers or Bosch Aeroblades/Icon
* custom classic rally-style rear spoiler
* 1/2" steel MRAP-inspired custom v-shaped front skidplate
* 1/2" steel MRAP-inspired custom v-shaped rear skidplate
* 1/2" steel MRAP-inspired custom transmission skidplate
* 1/2" steel MRAP-inspired custom v-shaped passenger compartment skidplate
* RallyArmor or custom UHMW-PE mud flaps cut/adjusted for maximum coverage and adjusted for suspension travel (touches level ground when suspension bottomed-out) while short enough to avoid unwanted grabbing between tires and obstacles
* heavy-duty unibody-mounted Safari rally-style front bumper "roo guard" with fine-mesh radiator guard or custom Trail Armor by Bushwacker or custom Dee Zee grille guard
* custom Yakima or Subaru-factory roof rack retrofit
* Yakima oversize cargo roof rack w/ spare tire mounts
* Yakima bike racks
* rally underfender (fenderliners) mud guards (made of Ultra-high-molecular-weight polyethylene [UHMW-PE], aluminum, stainless steel, or kevlar)
* custom front hood guard (bug deflector)
* custom rain guards
* custom front and rear brake cooling ducts
* police-style spotlights
* custom headlight wipers
* rally-style rear diffuser
* door jam guards (anti-door ding)
* flame-retardant hood insulator
* engine splash/ford guard
* heavy-duty weather stripping (water seals) throughout vehicle (doors, hood, etc)
* heavy-duty "clear bra" material applied on headlights, taillights, turn signals, etc.
* all mirrors w/ heavy-duty "clear bra" material applied
* heavy-duty door hinges w/ teather (for predictable quick vehicle exit)
* custom Bushwacker Trail Armor or other custom lower door cladding/guards
* custom Bushwacker Trail Armor or other custom tailgate cladding/guard
* custom Bushwacker Trail Armor or other custom taillight guards
* custom Bushwacker Trail Armor or other custom oversize fender flares/cladding
* Recaro Expert seats with anti-stab plates
* retrofitted color-matched Autometer/Stewart-Warner/Lamco gauges (oil pressure, oil temp, fuel pressure, volt meter, ammeter, trans temp, rear diff temp, etc)
* custom door stabilizers (stiffen door mounts and allows door to reinforce chassis)
* ultra-wide rearview mirror (with compass and exterior temperature display, non-electronic)
* non-glare anti-reflective full dash
* custom all-weather floor mats and/or spray-on bedliner whole interior of unibody
* detatchable passenger/pet cage segregator
* cargo segregator cage
* rear-passenger harness locks (essentially a child seat belt lock requiring a key to unlock)
* simplified waterproof interior (for easy cleaning)
* waterproof non-slip material for seats
* ABC/FIA/WRC approved fire extingushers mounted underneath seats
* STI shift knob (titanium)
* custom reinforced doors
* STI 5-speed manual shift pattern (carbon-fiber) sticker
* side-impact beams and reinforcement in doors and hatch, anti-intrusion bars in every exterior door (reinforcement bars with anchoring in relation to door mounts and other structurally-rigid points)
Electronic
* high-end Panasonic automotive battery or Deka battery (heavy-duty AGW battery)
* high-output headlight bulbs (such as PIAA replacement bulbs or Sylvania Silverstar replacement bulbs)
* PIAA or Vision X rally lights
* PIAA fog lights (yellow) in stock-appearance fog light location
* rear fog light
* custom-mounted corner LED (plus side-mounted turn signals) wig-wags [corner LED lighting] (Federal Signal or other reputable brand)
* rear spot lights (IPF lights from ARB) function when in reverse gear (driver can see behind)
* rear LEDs for lateral and rear visibility for reverse gear (at least 270 degrees of visibility)
* reverse gear chime (same one used for trucks)
* Casette + MP3 + USB + AM/FM + WB (weather band) radio + CB and HAM radio, intercom, and phone
* multiple electrical outlets
* Subaru battery heater
* train horn with air compressor
* Federal Signal Rumbler w/ multiple additional sirens
* Subaru engine block heater
* LED interior lights with dim and dim red retrofit
* rear-mounted (cargo/trunk area) heavy-duty automotive auxiliary battery
* several Hamsar Diversco spotlights and general illumination for outside visibility 360 degrees throughout roof and undercarriage
* Dakar rally-style/Baja off-road rally-style taillights (high mounted taillights and turn signals)
Manipulation/controls
* retrofit STI sport pedals
* STI short-throw shifter w/ STI shifter bushing P/N C1010FA001 and B0220FG300
* hydraulic clutch conversion (clutch master cylinder P/N 37230FC000)
* STI/Goodridge stainless steel mesh clutch hose (P/N ST372514S000 or custom)
* Motul brake fluid for clutch (DOT 3 or 4)
* Subaru/MOMO steering wheel w/o airbag
Climate
* custom climate control vents for rear passengers
* Gortex-protection for vents
Other
* ARP heavy-duty fasteners throughout vehicle with ARP heavy-duty threadlock applied
Subaru XV tires
daily:
http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Geolandar+H%2FT+G95A&partnum=255HR7GEOHT&vehicleSearch=true&fromCompare1=yes&autoMake=Subaru&autoYear=2014&autoModel=XV%20CrossTrek&autoModClar=2.0i%20Premium
off-road:
http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Geolandar+A%2FT-S&partnum=165HR6GEOATS&vehicleSearch=false&fromCompare1=yes
my future Subaru XV Crosstrek Premium categorized by purchase priority
Safety, security, convenience, cargo, etc
* Security System Upgrade - Shock Sensor
* DVR 027 720p dashcam or other dash cam
* Wheel Locks
* Heavy-Duty Roof Cargo Basket (rebranded Yakima)
* multiple Kabletek 9/16in x 10ft Flexweave Cable w/strap (cables to secure roof accessories)
* multiple MasterLock Covered Laminated Padlocks 6127KALJ (locks cables to secure roof accessories)
* multiple MasterLock Motorcycle Locks 8218DPS (locks roof accessories to roof rails)
* UltraGauge or Torque Pro App w/ dedicated tablet or other OBD-II based parameter monitoring
* Engine Block Heater
* Battery Warmer
* 110 Volt Power Outlet
* Center Console Tray
* Cargo Net - Rear
* Rear Vision Camera P/N H001SSC700 with compatible mirror such as Subaru OEM or OEM-supplier Gentex 50-GENK335S Auto-Dimming Rearview Mirror w/ 3.3" Rear Camera Display & Compass
* Hella or custom LED DRLs (aimed for 360 visibility, side-visible LEDs get amber, forward-facing white, rear-facing red)
Chassis reinforcements, body protection
* clear Plasti Dip throughout vehicle (all painted surfaces with clear coat)
* Primitive Racing 3/16" front skidplate (no access holes)
* Primitive Racing 3/16" rear differential guard
* Headlight Armor clear headlight protective film
* Headlight Armor yellow fog light protective film
* All-Weather Floor Mats
* Anti-Slip Mat
* Rear Seat Back Protector
* door jam guards (anti-door ding) or custom anti-door ding door jam guards made of UHMW-PE with design consideration of aerodynamics and paint protection
* Rear Bumper Cover
* Body Side Molding
* Hood Protector
* Side Window Deflectors
* Sunshade (windshield)
* RallyArmor UR mudflaps or other rally-quality mud flaps w/ hook to retract for severe off-roading
* custom metal mesh fog light covers (imitates STI fog lamp covers on bugeyes that let light shine through while protect lights)
* Car Cover
* Car Cover Bag
*** Subaru Bumper Corner Molds
* STI Flexible Strut Tower Brace OR Cusco Front Strut Bar Type OS P/N (694 540 A)
* Cusco Rear Strut Bar Type OS P/N (694 541 A)
* custom rear subframe bracing (reinforcement + additional bracing to unibody) or Cusco Powerbrace Rear Member Side P/N (687 492 RS) and Cusco Powerbrace Rear Member P/N (692 492 RM)
*** STI Flexible Draw Stiffener, Rear P/N ST20168ZR000 (if possible, connects bottom surface of the floor with the side frame) or Cusco Powerbrace Floor Center P/N (692 492 C)
*** STI Flexible Support, Rear P/N ST20156PF000 (if possible, pillow ball bushing in the middle of the support plate where the sub-frame connects to the body) or Cusco Powerbrace Floor Center P/N (692 492 C) as listed above
*** STI Trailing Link Set P/N ST20250MF000 (if possible, pillow ball bushings and links stiffened)
* Cusco Rear Lateral Link FRONT SIDE adjustable P/N (692 474 LA)
* Cusco Rear Lateral Link REAR SIDE adjustable P/N (692 474 L)
* Whiteline Front chassis Brace KSB723 (for 2012+ Impreza)
* Whiteline Front Brace - control arm support KBR14 (for 2012+ Impreza)
*** Cusco Brake Cylinder Stopper or custom master brake cylinder brace (braces brake cylinder to rigid location such as strut tower mounts)
* Cusco Powerbrace Rear End P/N (694 492 RE)
* Cusco Front Sway Bar P/N (695 311 A26)
* Cusco Rear Sway Bar P/N (692 311 B20)
* Cusco Strengthened End Link (667 318 A) with quick-release pins
* Cusco adjustable rear trailing rod pillow-ball type P/N (965 474 T)
* miscellaneous Whiteline bushings (for 2012+ Impreza)
* W0506 Front Control arm - lower inner front bushing
* W53353 Front Control arm - lower inner rear bushing
* KDT901 Front Gearbox - positive shift kit bushing
* KSR207 Front Steering - rack & pinion mount bushing
* W63225 Rear Control arm - upper inner bushing
* KDT907 Rear Crossmember - mount bushing
* KDT910 Rear Crossmember - mount insert bushing
* KDT906 Rear Diff - mount in cradle bushing
* KDT903 Rear Diff - mount in cradle insert bushing
* KDT905 Rear Diff - support outrigger bushing
* W0505 Rear Shock absorber - lower bushing
* W0568 Rear Trailing arm - lower front bushing
* rally-style heavy-rubber front bumper lip (able to take off-road abuse while making front-end more aerodynamic plus light downforce and quick-release feature)
* Trailer Hitch
Change in conjunction with maintenance interval
** STI Sports Oil Filter P/N ST15208ST000 [new FB-specific] or ST152084S000 [old Subaru-specific] (if possible)
** Idemitsu/Subaru Synthetic 0W-20 for daily driving; Elf Excellium NF/Total Quartz Energy 9000 in 5W-40 for heavy-duty urban;
Motul in 10W-40 "6100 Synergie+" for heavy-duty mountain pass, "300V CHRONO" for severe-duty off-road/rally/extended mountain pass drive
* Bosch Aeroblades/Icon windshield wipers
* upgraded PSX24W fog light bulbs such as PIAA, Hella, Sylvania, etc
*** STI Air Cleaner Element P/N ST1654621010 (if possible, can substitute ST1654621010 with Cosworth P/N 20002278)
** DOT 4 brake fluid such as Endless S-Four or Motul RBF 600 Factory Line
* Hawk HPS brake pads P/N front HB432F.661 or Brembo sport brake pads
* SPT Radiator Shroud P/N SOA8431080 (if possible)
* custom radiator shroud (closes gap between radiator and core support) if SPT not compatible
** STI Radiator Cap P/N ST4511355010 (available from local Subaru dealers)
*** STI Radiator Hose Set P/N ST451624S000 or Samco Sport P/N TCS135/C with CK135/C
*** STI/Goodridge Stainless Steel Mesh Brake Hose Set P/N ST265504S010 Goodridge P/N SSU0700 or 24218 (if possible)
*** high g-force resistant fuel-pump + fuel filter and/or full fuel system
*** STI/Goodridge Stainless Steel Mesh Clutch Hose P/N ST372514S000 (if possible)
*** STI short-throw shifter for 5-speed manual (5MT) such as P/N C1010FA001 (if possible)
* Exedy Stage 1 Organic Clutch P/N 15801 (if possible)
Cosmetic, entertainment, etc
* German-spec rear fog light and fog light controls
* Tweeter Kit
* Upgraded Speakers
* Roof Spoiler
* black-painted brake calipers
* black plasti-dipped front grill with horzontal "wing" changed to brushed aluminum-look
Heavy-duty/towing upgrades
* Subaru Trailer Hitch
* custom motor oil cooler
* custom transmission/front differential oil cooler
* STI Rear Differential Cover P/N ST383164S000 or custom rear differential cover w/ more cooling fins than stock
* custom power steering controller motor cooling fins and/or air cooling ducts to power steering controller motor
* heat reflecting shield wrapping on brake master cylinder and clutch master cylinder
* German market Subaru XV 1.6 dual-range 5-speed manual gearbox w/ applicable interior parts and controls
- OR FULL 2014 Subaru Forester (SJ chassis) 6-speed manual gearbox swap
w/ custom "granny gear" crawler 1st gear (similar to the "G" gear of the Porsche 959 and 1st gear crawler gear of light-duty trucks and minibuses)
w/ 2nd-6th gears custom-fitted with regular 5-speed manual gear ratios for USDM Subaru XV, ALL gears custom reinforced for FA20 DIT
* chock block and drip pans for parking
* all-terrain tires, Yokohama Geolandar A/T-S 215/65R16 tires with 2003 Subaru Forester 2.5X 16 inch steel wheels
* run-flat tires, Bridgestone Potenza RE960AS Pole Position RFT (225/55RF17
Run Flat) for improved control in case of blowout/tire leak
* front and rear clutch-type Cusco LSD; Type RS/1way front, Type MZ/2way rear, FD of 4.444
* Phase II MY1999+ STI 14kgf viscous coupling center differential OR PPG Torsen center LSD from RalliSpec
TREK 3-series modlist
Front Suspension
$322 - $356 RockShox Recon Silver TK w/ SoloAir 26" 80mm Recon Silver TK | SRAM or better
Wheelset/rim
$249.99 Bontrager Rhythm Comp TLR Disc front wheel Bontrager: Rhythm Comp TLR Disc (Model #09770)
$62.58 AlexRims EN24 rear rim (V-Brake compatible all-mountain rim) Alexrims - cycling wheels
OR $xx.xx Mavic XM 317 (rim brake compatible mid-range XC rim) XM 317
Hub
$xx.xx Shimano Deore rear hub
OR $47-55 SRAM X7 rear hub SRAM X7 Hub | SRAM
Tires
$65.15 Schwalbe Marathon Plus MTB tire (front and rear) Art.No. 11132412, ETRTO 54-559, 26 x 2.10
OR $54.35 Schwalbe Smart Sam Plus Art.No. 11100700, ETRTO 57-559, 26 x 2.25
OR $34.85 Schwalbe Nobby Nic HS411 Art.No.11100203.01, ETRTO 57-599, 26 x 2.25
Rear Derailleur
older model Shimano Deore LX/XT, SLX
Handlebar
$69.99 Bontrager Race Lite (Model #11252) 750mm width
P/N 425432 Bontrager: Race Lite (Model #11252)
Stem
$59.99 Bontrager Race Lite 4-Bolt 40 Degree 31.8 GC stem Bontrager: Products > Components > Stems
Headset
$68 Cane Creek 40 (forty) complete headset 40-Series
Brakes
$89.00 Avid BB7 Mountain front brake BB7 Mountain
OR $xxx.xx Interloc Racing Design (IRD) Dual Banger Mechanical Disc Brake front brake Dual Banger Disc Brake
Grips
$34.99 Bontrager Evoke RL grips (420763) Bontrager: inForm Evoke RL (Model #09146)
TREK DS modlist
Tires
Marathon Plus Tour HS 404 ($63.05, Art.No. 11150405, 700x40c, balanced on/off-road) Marathon Plus Tour HS 404 | Schwalbe North America
OR WTB All Terrain tire (700x37c, GMS 37/38, balance on/off road) All Terrain | WTB
OR Michelin Protek Cross Max (42mm wide?) MICHELIN Protek Max - Tires city | MICHELIN Motorcycle - United States - Bike-website
Brakes
~$260.00 Hayes Prime Comp hydraulic disc brakes (if Hayes Dyno Sport low stopping power not fixable even after replacement swap of new Hayes Dyno Sport brakes) Prime Comp | Hayes Disc Brake
Cassette
$77 SRAM PowerGlide 980 Cassette SRAM PowerGlide 980 Cassette | SRAM
Chain
$43 SRAM PowerChain 991 Cross Step SRAM PowerChain 991 Cross Step | SRAM
Montague Paratrooper silly list
Fork
Tires
OR Schwalbe Marathon Plus MTB tire (front and rear) Art.No. 11132412, ETRTO 54-559, 26 x 2.10
w/ puncture-resistant (thorn resistant) inner tubes
Seatpost
Cane Creek Thudbuster LT (30.9 mm diameter?)
Shifters
Shimano Alivio SL-M430 (9-speed)
Front Derailleur
Shimano Alivio FD-M430
Chain
Shimano Alivio CN-HG50 (8-speed)
OR SRAM PowerChain 890 (8-speed)
OR Shimano Deore CN-HG54 (9-speed)
OR SRAM PowerChain 991 Cross Step (9-speed)
Cassette
SRAM PowerGlide 990 Cassette (9-speed)
Crankset
Shimano Alivio FC-M430-L or FC-M430-S
Brakeset
Avid BB7 Mountain mechanical disc brakes
w/ Avid G2 Cleansweep rotors (180 mm front, 160 mm rear)
Avid Speed Dial 7 Levers
Headset
Cane Creek 10-Series
Pedals
Truvativ Hussefelt Pedals
Discussion Starter #14
Ditch the auto dimming mirror with compass on the crosstrek. Replace it with an Outback mirror with the integrated LCD and wire in a reverse camera. That way you can check the mirror easily and see the reverse view there.
I'm lost :(
http://carlsensubaruparts.com/subaruparts/index.cfm?action=accessories&siteid=216558&makeid=32&startrow=1&jointvehid=0&catalogid=201&manufacturerid=1001&categoryid=0&subcat1=0&subcat2=0&subcat3=0&subcat4=0&subcat5=0&partnumber=&description=mirror&overlayExtids=&overlayIntids=
AWDfreak's generic upgrade list
AWDfreak's generic mod list
AWDfreak's generic automobile upgrade modification list - more-REALISTIC version as of 6 March 2019
* stainless-steel brake hoses (extended if additional lift to suspension) w/ upgraded brake pads
* high-performance all-season tires w/ steel wheels, lightweight alloy wheels, or stock wheels with tire diameter and revolutions per mile identical to stock setup while retaining sidewall aspect ratio of between 50 series to 65 series (suitable for light off-road use) [if high-performance all-seasons not available, sportiest touring all-season option will suffice]
* skidplates in front, rear diff, trans, (perhaps fuel tank), etc
* cooling system upgrades such as heavy-duty silicone radiator hoses, additional heat exchangers (such as engine oil cooler, power steering cooler if hydraulic, transmission oil cooler, etc), high-pressure radiator cap, etc
* available unibody, chassis, and suspension/driveline bushing reinforcements
* applicable LSD's if no traction control
* mobile device and/or laptop mounts such as RAM Mounts X-Grip
* heavy-duty battery (AGM battery for even more-severe applications)
* lifted suspension through use of custom overload lift springs and replace/upgraded shocks (if suspension lift necessary); or overload stiffer springs to withstand heavy-duty use
* stiffened sway bars/anti-roll bars/stabilizer bars to reduce body roll, if body roll excessive
* hidden custom brake and cooling ducts
* police-style push bumper (custom-setup that does not interfere with airbag deployment and does not scratch other vehicles)
* fine-mesh radiator guard for lower fascia (if not properly protected)
* stiffer/stronger transmission and engine mounts (but NOT solid mounts), if available
* complete tool/emergency/roadside/CLS kit
* full-size spare tire conversion (if vehicle not equipped with full-size spare and still has an OE location to fit said full-size spare tire)
* various vehicle parameter monitoring [OBD-II and gauges]
* various winter accessories such as mirror heaters, wiper heaters, seat heaters, battery warmer, engine block warmer, etc
* various exterior protection including but not limited to clear headlight/taillight films yellow or clear foglight film, custom door jam guards, rear bumper cover, body side molding, hood protector, side window deflectors, mudflaps w/ custom hook-on-body (for heavy off-roading and reversing) etc
* various interior protection such as all-weather floormats w/ rear seatback protectors, roll-open sunshade, window tint, and/or custom vinyl flooring (remove carpet)
* blind-spot mirror attatchment such as Maxi View Blind Spot Mirrors
* surveillance dashcam
* DRL's + aux lights such as driving lamps
* various interior electronic accessories such as additional 110V power outlets, auto-dim mirror w/ compass, etc
* rear gurney flap on tailgate/trunk spoiler
* OEM bumper corner molds (if available)
* various blacked-out or matte-color interior parts (for anti-glare purposes)
* dry high-flow drop-in air filter, resonator delete, cat-back exhaust (if available)
* fluids and maintenance: group IV oil such as Motul motor oil, DOT 4 or DOT 5.1 brake fluid, genuine OEM or high-quality gear oil such as Motul gear oil, genuine OEM coolant/antifreeze or OE-grade coolant/antifreeze
* additional anti-theft countermeasures
Re: bboytaktix fan club thread.
for racefreak156
http://www.cars101.com/subaru/outback/outback11backupmirror3.JPG
DEDICATED MOUNTAIN BIKE silly list
Christini Venture Series AWD bike kit, M (18") medium frame, Kit 1, White Brothers XC 1.0 (100mm travel) front fork
Cassette
* Shimano SLX CS-HG81-10 (w/ Dyna-Sys)
Chain
* Shimano SLX CN-HG74 (w/ Dyna-Sys)
Crank
* Shimano SLX FC-M660-10 3X10 specific (w/ Dyna-Sys)
Front Derailleur
* Shimano SLX FD-M661-10 (w/ Dyna-Sys)
Rear Derailleur
* Shimano Deore XT RD-M780-SGS-L (w/ Dyna-Sys)
Shifters
* Shimano SLX SL-M660-10R (w/ Dyna-Sys)
Brakeset
* Avid Elixr 7 Trail Hydraulic Disc Brakes, HS1 rotors (180mm front, 160mm rear)
Tires
* Schwalbe Hans Dampf 11600247.01 or 11600264.01
Headset
* Cane Creek 110-Series
Stem
* TRUVATIV AKA Stem 1 1/8 inch diameter
Handlebar
* TRUVATIV AKA Riser Bar
Seatpost
* TRUVATIV AKA Seatpost 27.2mm diameter
Pedals
* Shimano PD-M424 MTB pedals
Saddle
* Fizik MTB GOBI XM MUZZLE
Grips
* ODI Cush MTB Grips
My Subaru Tribeca EZ36 (facelift) more-realistic silly list mod wishlist
Engine
Lubrication system
* custom external engine oil cooler with thermostat in addition to stock oil cooler
Cooling system
* larger radiator cooling fans (custom fans with more fanblades to fit OEM cooling system)
* fine-mesh black painted integrated radiator guard (mounted behind grille)
Exhaust system
* custom stainless-steel cat-back exhaust with high-flow mufflers
Engine electronic
Drivetrain
* custom torque-sensing LSD or custom clutch-typle LSD
Suspension and axle
* custom thicker anti-roll bars/anti-sway bars (from custom anti-sway bar manufacturers such as Quickor Garage) with easy access manual quick disconnect fasteners
* custom reinforcement of subframes
Brake system
* Goodridge G-Stop Brakeline Kit (stainless steel, part number 24217) or custom stainless steel brake lines
* Hawk Performance HPS Street brake pads (front HB533F.668, rear HB671F.628) or Brembo GT brake swap (for BM/BR Legacy/Outback 2.5GT/3.6R) front (black 6-piston slotted front 1M2.8034A1) 1M2.8034A, rear (black 4-piston slotted rear 2P2.8020A1) 2P2.8020A
Steering
* Motul Multi ATF or Subaru Idemitsu HP-ATF
* reinforced tie-rod and other reinforce-able material/components stiffened
Wheel
Body
* custom front and rear low-profile off-road/push bumpers with tow-hooks, winch mount, rubber push-guard, light mounts, etc.
* clear 3M Scotchgard Paint Protection Film Pro Series throughout exterior of vehicle on commonly-scratched painted surfaces
* hidden front brake cooling ducts
* blind spot mirror attachment
* Headlightarmor GT Yellow small fog light vinyl overlays
* WeatherTech Side Window Deflectors P/N 72402
* additional gauges [oil temp, oil pressure, volts, AT oil temp, R.diff temp] by Auto Meter (low-key such as Z-Series Gauges or Sport-Comp II)
* interior fire extinguisher mounts (preferably under front seats)
* Weathertech Floorliner DigitalFit P/N 44537-1-2-3
Electronic
* upgraded Hella Twin Supertone horn kit (300hz/500hz) P/N 003399801 and/or PIAA Automotive Superior Bass Horn (330hz/400hz) P/N 85115
* upgraded headlight and fog light bulbs (high beam HB3, low beam HID D1S, low beam halogen H7, fog light H3)
* reverse PIAA 1500 Backup lamps P/N 01540
* heavy-duty battery (preferrably at least 720 CCA 70-amp hour, OEM/stock CCA is 490) such as Deka Intimidator - AGM - Valve Regulated [9A35/85] or OPTIMA® Batteries 8040-218 D35 YELLOWTOP
* Volvo-style integrated Side Positioning Lights, preferably LEDs (allows corners of vehicle to be seen in daytime as well as night) including custom blackout function (simulates blackout lighting of military tactical vehicles) with separate relay/switch (independent of ignition switch position)
* Smittybilt License Plate Light Mount [P/N 2815]
* PIAA 580 Driving XTreme White Plus Halogen Lamp Kit P/N 05862 w/ PIAA H4 Night Tech Twin Pack Halogen Bulbs P/N 10704 retrofitted
Climate
Other
* chock blocks, jack platform (prevents sinking of jack) and drip pans for parking
* hood protector P/N E231SXA100
* front bumper underguard P/N E551SXA000 (w/ bedliner product)
* bumper corner molding-rear P/N E7710AS200 (2 pair)
* rear bumper cover P/N E771SXA100
* security system shock sensor P/N H711SXA000
* trailer hitch P/N L101SXA100
* Subaru severe weather companion P/N SOA868V9500
* Subaru roadside emergency kit P/N SOA868V9510
* compartment separator/dog guard P/N F551SXA200
* rear dome/reading light P/N H461SXA000 (w/ custom additional low-key red light)
* cargo tray - gray, small P/N J501SXA100MW
* crossbar kit, aero P/N E361SXA400
* battery warmer P/N J6010FS000
My Subaru XV Crosstrek silly list 3-stage mod timeline
Initial mods:
* shock sensor
* engine block heater
* primitive racing skid plates
* UltraGauge OBD-II electronic parameter monitor
* DVR 027 720p in dash camera
Stage 1:
* wheel locks
* battery warmer
* Tweeter Kit
* Upgraded Speakers
* Cargo Net Rear
* Car Cover
* Car Cover Bag
* STI Air Cleaner Element P/N ST1654621010 (if possible, can substitute with Cosworth P/N 20002278) or other dry high-flow filter
Stage 2:
* Anti-Slip Mat
* Rear Bumper Cover
* Body Side Molding
* Hood Protector
* Cusco Front Strut Bar Type OS P/N (694 540 A)
* Tweeter Kit
* Upgraded Speakers
* Roof Spoiler
* FULL brake swap for full 2006-2007 WRX 4-pot brake conversion w/ custom silver-painted calipers w/ black Subaru logo
* FULL NATURALLY-ASPIRATED ENGINE BUILD for 170-200 HP on FB20 with supporting mods such as hollow cams, port polish, headers, custom stainless steel exhaust, custom engine mapping, etc
* baffled engine oil pan and fuel tank
* FULL Subaru XV Hybrid steering system swap
* FULL Subaru XV Hybrid suspension swap
Stage 3:
* FULL FA20 DIT engine swap w/ applicable custom parts/tuning
* FULL German market Subaru XV 1.6 dual-range 5-speed manual gearbox w/ applicable interior parts and controls, rebuild and reinforced for FA20 DIT
* Anti-Slip Mat
* Rear Bumper Cover German-spec
* Body Side Molding German-spec
* custom fog light trim, matte black
* custom or Australian-market aftermarket overload lift springs
* Trailer Hitch
* additional driving lights, fog lights, and work lights
* FULL WRX STI 2008-2014 Brembo brake swap
* front grill with horzontal "wing" changed to brushed aluminum-look
* all-terrain tires, Yokohama Geolandar A/T-S with Enkei RPF1 wheels color-mat ch
silly list of Subaru XV Crosstrek (ricer) stickers plan
find logos on Product Logos
rear window:
Symmetrical AWD white P/N 91572FE040 (if debadge stock Symmetrical AWD logo)
ABS tan WINDOW P/N 91531AA830
VDC text custom stickers http://logos.subaru.com/logos/gif/vdctext.gif
engine bay:
Subaru Boxer http://logos.subaru.com/logos/gif/subaru_boxer.gif on top of plastic intake manifold
door sides, above door ding panel:
Subaru XV custom stickers; Subaru P/N 93079FG010, XV w/ "Crosstrek" cut out http://logos.subaru.com/logos/gif/XV_Crosstrek_Vertical.gif
Symmetrical AWD white changed to black P/N 91572FE040 (remove if FA20 DIT engine swap completed)
door sides, below door ding panel:
Subaru Legacy RS door side sticker "4CAM16VALVE TURBO INTERCOOLER 4WD" transfer (4WD changed to "Symmetrical AWD" logo) if FA20 DIT engine swap completed
front grill:
Subaru XV logos custom; Subaru P/N 93079FG010 and Subaru XV rear badge
interior:
custom XV Crosstrek sticker on roof map lights console
additional bike lights silly list
TREK 3-series
2 X Cateye "Nano Shot Plus" HL-EL625RC
OR 2 X Cateye "Volt1200" HL-EL1000RC
1 X Light and Motion Vis 180 Micro
1 X Dinotte 400R Daytime
AND/OR 1 X Design Shine DS-500 Taillight w/ 6200mAH battery, 11.1V 1.0 Amp charger, 12" and 18" velcro cinch strap
2 X Light and Motion Urban 550 headlights transfer from DS
TREK DS
AND/OR 1 X Light and Motion Vis 180
1 X Light and Motion Urban 700 transfer from Paratrooper
1 X Light and Motion TAZ 1000
1 X OR 2 X Cateye "Rapid 5" TL-LD650 taillights
1 X OR 2 X Cateye "Rapid 3" TL-LD630-F safety headlights
Christini Venture Series AWD bike, full-suspension
2 X OR 1 X Light and Motion Seca 2000 Enduro
2 X Light and Motion Vis 180 OR 1 X Light and Motion Vis 180 Micro
* blind-spot mirror attatchment, secondary smaller side rearview mirrors (similar to Volvo police package) mounted on door window frame (or towing mirrors)
* upgraded horn
* DRL's + aux lights + corner LED lights (if applicable)
* various exterior protection including but not limited to clear headlight/taillight films yellow or clear foglight film, custom light mesh protectors (allow light to pass through while protecting lights), custom door jam guards, rear bumper cover, body side molding, hood protector, side window deflectors, mudflaps w/ custom hook-on-body (for heavy off-roading and reversing) etc
* various interior protection such as all-weather mudflaps w/ rear seatback protectors, roll-open sunshade, window tint, and/or custom vinyl flooring (remove carpet)
* various interior electronic accessories such as additional 110V power outlets, auto-dim mirror w/ compass, upgraded speakers, etc
* countless unibody, chassis, and suspension/driveline bushing reinforcements (overlooked reinforcement includes "stealthy sliders", reinforced unibody lip)
* extensive, thick tube-frame reinforced skidplates in front, rear diff, trans, fuel tank, etc
* cut-off switches for:
- electric engine cooling fan
- ABS
- stability and traction control
* high-output alternator w/ heavy-duty battery and heavy-duty grounding kit
* front, center, and rear LSD's
* upgraded clutch (higher clamp and higher temperature resilience), short-throw shifter
* custom crawler 1st gear
* stainless-steel brake hoses (extended if additional lift to suspension) w/ upgraded brake pads, brake calipers, and brake rotors
* thicker anti-roll/sway bars w/ quick disconnect fasteners of stainless-steel clevis pins w/ stainless steel cotter rings and stainless steel flat washers
* all-terrain tires (winter "snowflake" rated) w/ steel wheels, lightweight alloy wheels, or stock wheels
* heavy-duty unibody-mounted Safari rally-style front bumper "roo guard" with fine-mesh radiator guard or buy from Australian off-road bumper manufacturers
* custom front rally-style lip able to take light off-road abuse w/ quick release feature, rear gurney flap on tailgate/trunk spoiler w/ quick release
* custom removable light-reflector and headlight/taillight blocks (completely blocks headlight/taillight assemblies from accidentally giving away position, completely eliminates light reflector from exposing location), custom blackout taillights w/ green stealth headlight, red stealth interior lighting removable inserts
* fluids and maintenance: high-flow sports oil filter, Motul motor oil, Endless S-Four DOT 4 brake fluid, genuine OEM or Motul gear oil, genuine OEM coolant/antifreeze, Motul or Idemitsu power steering fluid
* parking brake and/or shift linkage lock (prevents theft of vehicle, gear cannot be shifted out of, parking brake locked)
hwat weapon list
kewl beans (no), just basic stuff
Benchmade 482 Megumi [Nakamura Design - Made in U.S.A.] 482 Megumi
Mossberg 500 All Purpose Mossberg & Sons | 56420
Sig Sauer P229 https://www.sigsauer.com/CatalogProductDetails/p229.aspx
Colt LE6920 Colt's Manufacturing Company LLC > Catalog > Colt Rifles > Colt LE6920 Series or Heckler & Koch (H&K) MR556A1 Heckler & Koch - USA
Springfield Armory M21 Tactical Springfield Armory
1 - 20 of 606 Posts
