1 - 1 of 1 Posts
ProLightz deal of the day Dec 9th
08-14 WRX & 08-11 Impreza 2.5i Bi-xenon retrofit package
If you've been looking to build your own high performance Bi-xenon headlights
this is the ultimate retrofit kit you've been waiting for !
Includes :
Morimoto Mini D2S 3.0 BI-XENON projectors
Used Matsushita Gen4 ballasts:
These bulletproof ballasts are the same as the OEM STI HID ballasts and bolt up directly
to the OEM headlight housing for a perfect OEM type installation .
Osram Xenarc 66240 bulbs
OEM STI HID headlight harnesses :
No cutting splicing or soldering involved ! Simply remove your existing headlight harnesses
and put these ones in their place. They already have the correct connector to power the ballasts
and plug in directly to your vehicle harness without any modification.
High beam splitters :
These plug n play high beam splitters are designed to run both your OEM high beams AND the high beam
feature on the projectors at the same time = crazy high beams !
ProLightz 08-14 WRX stainless hardware & spacer kit :
Our stainless mounting hardware & spacer kit takes the guess work out of projector mounting and spacing.
Deal of the day price : $310 . ONE KIT ONLY .
First come first serve . You snooze you lose ! lol
Will.
819-230-3445
[email protected]
https://www.facebook.com/prolightz.hid.led
1 - 1 of 1 Posts
